KB9028 Programming
+ More Options
Posts
  • reset1986
    • 308
    • italia
    Re: KB9028 Programming
    dc jack led glows orange without even programming but mb dont turn on . You need to program kbc. Are you sure u have +3V LDO on pin17 of SY8286BRAC(AWV)?? If yes, then post a clear picture of KBC9028 with surrounding components. may be some resistor is knocked off while soldering the kbc or kbc is not properly soldered and/or kbc is defective. You have +3V_EC at pin 96 of KBC?? Be very careful while measuring pin17 of sy8286brac. better not to measure on the pin directly.
    ok, I re-soldered the original kb9028q, the charge led is ok, orange,
    I press the power button, the white LEDs light up for about 10 seconds and then turn off,
    in ignition I find the 5V and 3 V on pl 4502 and pl 4501,
    3v on spi mxic (already written another bios)
    I can't find CPU power supplies, and Ram, Pl5201 marks 0.6 ohm, it should have 1 V, generated by Pu5201 (V15U 1533sf) I don't recognize the type of ic on the code,
    wiring diagram I can not find it for this motherboard, there will be some signal that does not allow the correct ignition sequence, I suspect pch, do you have advice
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I've already delivered so cant give you the measurements on ram ic anymore. If we can manage the ram ic datasheet, can be diagnosed further.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Just received another dead mb(same). KBC is badly soldered with missing surrounding components. @reset1986, can you help me with the value of those 2 resistors circled in black.
        • reset1986
          • 308
          • italia
          here, measured without welded kb9028q,
          I'm waiting for a new kb9028q already programmed
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Thanks for resistor values. Soc is bad(pch part). Even after removing kbc,3v pwm, short remains on 3V line. Injecting 1V,10A makes SOC heat up . So end of story as neither I've such SOC, nor do I have stencil for same. So returned it to customer . Feel bad for the customer. Unit was just 1 month out of warranty and goes to scrap. It was with touchscreen.
            • reset1986
              • 308
              • italia
              #26
              pity, I will soon get the kb9028q chip already programmed, I'll let you know
              • kingis85
                • Jan 2015
                • 18
                • finland
                #27
                I need some help with 9028q and svod3. I am trying to program hp motherboard diner 1.0 carrizo-l, 15286-1.
                The board dc jack got broken so the ec had 20V. I replaced it with "new" 9028q and svod3 founds it. It can read and write but not erase. I do not even understand how there is data if it is suppose to be new? Anyway it gives the error "blank check false" So does anybody know what i should try to do to get the chip fully erased?
                Hopefully somebody can give me solution here. Many many thanks
                • gurangax
                  • Apr 2020
                  • 34
                  • Malaysia
                  #28
                  has anyone tried kb9028 with a ch341a programmer?
                  I noticed that neoprogrammer has support for KB902X. Will try this later.
                  Having problem figuring the connections for this laptop model HP Envy 13-aq series. I dont have the schematics. Hopefully there are some identical models with schematics out there.
                  • gurangax
                    • Apr 2020
                    • 34
                    • Malaysia
                    #29
                    Did you solve your board problem?
                    • a_lik
                      • Feb 2019
                      • 7
                      • Indonesia
                      #30
                      i've try neo programmer with ch134a for programming kb9028q.. solder it directly to keyboard pin on acer sf314-56. but i've no luck. pm slp s3 and pm slp s4 not showing up.. the kbc respon my power button and enabling the other 3.3v 1v and 1.8v..
                      • gurangax
                        • Apr 2020
                        • 34
                        • Malaysia
                        #31
                        Are you sure the pins on keyboard connector are correct. Make sure to trace the pins from the chip directly to the keyboard with a multimeter. And make sure it is grounded properly. I dont think the board will turn on if the signal is properly grounded
                        • a_lik
                          • Feb 2019
                          • 7
                          • Indonesia
                          #32
                          yes i've flash it with 3 different ec bios.. detecting, programming and verifying succses but no luck. still missing slp s3 and slp s4.. rsmt_rst and pm powerbtn are coming.. i'm affraid my PCH..
                          • Antonynl
                            • Apr 2021
                            • 74
                            • Nederland
                            #33
                            Originally posted by khaahk
                            Vertyanov programmer lists it as this:
                            KB_pins=32 LEFT DOWN 1MM KSO3=15 KSI4=28 KSI7=31 KSI6=30 KSI5=27 KB9028Q
                            How does this pin names translate to SPI pins clock cs miso mosi?
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #34
                              Ksi4=cs
                              ksi5=clk
                              ksi6=din(miso)
                              ksi7=do(mosi)
                              kso3=gnd
                              • ken0011
                                • Nov 2018
                                • 11
                                • 3W
                                #35
                                Thanks to all who responded. @khaahk, the pinout given by you is correct. I tried my level best but couldnt program ec with SVOD1 with custom made config file as provided by @khaahk. However, i got the job done with RT8209F by manually soldering the pins on kbd connector and khaahk's input is verified ok.
                                @reset1986, KB9012/22 cant be replaced for kb9028. I already tried kb9022 on this very mb and it creates problem. KB9028 datasheet i couldnt find anywhere. I referred to Lenovo 330S schematic for basic understanding of KB9028.
                                mcplslg123: you said you can use RT8209F to program kb9028, correct? can you post the diagram? thanks
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #36
                                  Yes,KB9028 is supported by RT8209F. The pinout is already mentioned on post#34.
                                  • k_hexen
                                    • Feb 2019
                                    • 11
                                    • Узбекистан
                                    #37
                                    Works on the SVOD programmer.
                                    The first pin is the last.
                                    khaahk Kind Regards, thanks.​
                                    • sikocan
                                      KB9028 RT9809F Programming
                                      by sikocan
                                      Hi all, I'm having trouble detecting a SuperIO. ENE KB9028 using RT809F which says it supports KB9028. it's programmable through SPI Flash. From schematics I have connected the RT809F as follows. Pin 1 CS to > Pin128, Pin 2 DO to > Pin120, Pin 4 G to Ground. Pin 5 DI to Pin119, Pin 6 CLK to Pin126, Pin 8 VCC to Pin9 of SuperIO. I also rotated Pin 2 and Pin 5 thinking I made mistake. It simply doesnt get detected. I checked VCC it gets 3.3 from Power supply when DC jack is plugged in.
                                      I tried timing it like press read then Insert DC jack, or vice versa etc. No luck many times....
                                      07-28-2022, 02:59 AM
                                    • DynaxSC
                                      ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
                                      by DynaxSC
                                      I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
                                      This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
                                      Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
                                      02-10-2025, 04:52 PM
                                    • araxnido
                                      Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                                      by araxnido
                                      Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                                      When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                                      06-10-2025, 09:26 PM
                                      by SMDFlea
                                      Bad...
                                      09-02-2021, 04:40 PM
                                    • hikesync
                                      XMCQH128A​ Programming issue
                                      by hikesync
                                      Sup guys i've been having a trouble with XMCQH128A chips, this is the only model that always fails to programming. All the others models and brands like Winbond, cFeon, etc. All works fine. But i just cant do it with XMC chips, is there some specific program that i must use? (i am using NeoProgrammer)
                                      06-26-2025, 11:22 AM
