SAMSUNG NP350E7C-S0BFR charge battery 80% only
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    I changed the battery but the problem is the same. no bios update on the official site. thank you
    battery life cycle extension is disabled in bios
  • mon2
    • 14666
    Re: SAMSUNG NP350E7C-S0BFR charge battery 80% only
    Do you have schematics / boardview files for this unit ?
    Perhaps the charger IC is observing that the current draw is at the peak value when the battery is @ 80% ?
    Are both tested batteries from a known good source? Do the batteries work in another unit to charge to 100% ? If yes, the charger IC and related parts needs to be reviewed.
    Which charger IC is on the logic board ?
    • lotas
      • Jan 2016
      • 4787
      • Russia
      Samsung laptop battery only charges up to 80%
      Samsung laptop battery charges up to 80% percent, the charge does not go further.
      Most likely, you set the charge level yourself or someone set up your laptop for you. By default, many Samsung laptops have a program that offers to increase battery life and set the maximum battery level (for example, 80%).
      To change the settings, you need to go:
      Start > All Programs > Samsung > Samsung Battery Manager > Samsung Battery Manager.
      or
      Start > All Programs > Samsung > Battery Life Extender > Battery Life Extender.
      After you click on this name, a program will open with which you will be prompted:
      Charge up to 100% or
      Charge up to 80% and increase battery life
      By choosing one of the proposed options, you can turn off the battery level to 80%, or vice versa turn on
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
      • razenxd
        How can I charge that battery pack?
        by razenxd
        it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
        At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
        Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
        Now, I have noticed a few things.
        The "dead" battery, while connected to charger and NOT Charging will...
        12-05-2024, 06:11 AM
      • guruji
        samsung galaxy book 3 np940xfg battery charge
        by guruji
        hello
        I have a samsung laptop galaxy book 3 np940xfg board is BA41-03013a venus3-14.The laptop turns on when connected with battery but the battery has random charging it charges till 70% and then it starts going in reverse the percentage.removed the board and disconnected the battery and attached the 65watt adapter the boot rom for tbt 3v is absent and the laptop does not power on. another strange issue in both the usb-c ports when you reverse the cable the power indicator light does not glow.they using a common dual port CYPD6228-96bzxi and 2 thunderbolt chips intel JHL8040R.
        my...
        08-14-2025, 08:12 AM
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
      • Klevjetack
        Charge a L19D3PDA battery externally from the laptop
        by Klevjetack
        Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
        03-05-2024, 07:26 AM
