MacBook Pro 2016 A1706 (820-00239) No boot/POST
  • reid
    • Feb 2011
    • 16
    I'm working on a 2016 MacBook Pro A1706 with touchbar, 820-00239 logic board. The board seems to power on and takes about 700 mA from the USB-C port, the CPU gets warm, the trackpad clicks, but there is no chime and the caps lock light doesn't turn on.
    The board is in good condition and there is no signs of liquid damage or any damaged components.
    I've tried flashing a different BIOS - I'm not 100% sure if the file I flashed was good or if there is ME Region issues, but there was no change in the behavior at all. The SPI termination resistors all seem to be okay.
    All voltages seem to be present except both PPVCCGT_S0_CPU, which I think is normal based on reading other posts, and PPVCCEDRAM_S0_CPU, which I'm assuming is the problem. PPVCCEDRAM_S0_REG_R and _REG_F are both 1.05 V.
    PPVCCEDRAM_S0_CPU doesn't seem to be shorted, it measures about 100 ohms/0.100 in diode mode. I don't have another similar board to compare this to.
    PPVCCEDRAM_S0_CPU voltage seems to be controlled by PM_OPC_ZVM_L and should be turned on when PM_OPC_ZVM_L is high (?). This comes from a level shifter, U7790 which should shift CPU_ZVM_L up to 3.3 V.
    The power voltages around U7790 and U7760 all seem to be okay: PP1V0_S3, PM_SLP_S3_L, and PP5V_S0. R7792 measures okay as well.
    Both CPU_ZVM_L and PM_OPC_ZVM_L measure 0 V. Diode mode reading for CPU_ZVM_L is 0.295 and PM_OPC_ZVM_L 0.530.
    Since CPU_ZVM_L comes directly from the CPU, I'm wondering if it's a bad CPU, but I'm not sure if there is something else that could be causing this CPU output to be low. I haven't tried to remove U7790 yet because it's right below the CPU.
    If anyone has any suggestions for further troubleshooting, or if I've misunderstood some of these circuits, your help would be much appreciated! Thanks!
  • mon2
    • Dec 2019
    • 14309
    Re: MacBook Pro 2016 A1706 (820-00239) No boot/POST
    What is the voltage showing on the Type C port ? Is it 5v or 20v ?
    • reid
      • Feb 2011
      • 16
      It's 20 V. Starts out around 20 V, 750 mA, then goes down to 680 mA and seems to stay there.
      • mon2
        • Dec 2019
        • 14309
        Your case is listed here:
        https://repair.wiki/w/A1706_2016-201...ar_MacBook_Pro
        Not charging battery (machine turns on), charger taking 20 V, 700 mA
        Continue to post your updates for future readers.
        • reid
          • Feb 2011
          • 16
          Thanks for the link! I think my board has a different problem. In Louis' video, the board still boots up and seems to work other than not charging the battery.
          My board doesn't boot, but seems to charge fine. With the battery plugged in, I get around 1 amp on the USB-C at 20 V, and then it eventually increases to 1.8 amps. The board does respond to the power button, so it can be shut down by holding the button and even when off it still takes about 1.8 amps charging. When I said it was taking 700 mA before, that was with the battery disconnected and the board out of the case. Sorry for the confusion!
          The battery was fairly low when I measured, but Q7065 had 11.3 V on source, 2.17 V on gate and 10.75 V on the drain.
          There's nowhere to measure PPVCCEDRAM_S0_CPU on the top of the board, so I haven't been able to confirm if that's still 0 V with the battery connected.
          • mon2
            • Dec 2019
            • 14309
            Are you confident that the fault is not just a bad LCD?
            If you remove the keyboard and then attempt to boot with a LCD - what are the results? You may have to use tweezers to turn on the logic board. Locate the shorting pads for the on/off function.
            The current draw seems respectable for a normal boot, I would say.
            Do you have the backlight voltage? (With LCD attached)
            • reid
              • Feb 2011
              • 16
              The machine could have a bad LCD, I've personally never seen this LCD work and don't have another logic board or screen to test with at the moment. Visually the screen flex cables look perfect and there's no damage to any LCD cables or connectors.
              I think I'd need to remove the LCD to be able to connect it to the board outside of the case to measure the backlight voltage, unless there's an easy way to measure on the top/CPU side of the board... I definitely can't see the backlight turn on, and don't see anything on the screen with a bright light on it.
              I've tried a few combinations of trackpad, keyboard and LCD disconnected. The LCD cable makes no difference, unplugging the trackpad causes the fans to spin on max, unplugging the keyboard causes no fans because they're powered through that connector.
              I've also tried to reset the PRAM with an external keyboard (and with the internal), but it doesn't respond - there's no change in the current drawn and definitely no chime. Since there's no chime, no caps lock activity and no external video output when the LCD is disconnected, it still seems like a logic board issue to me but I'm still new to fixing boards and definitely not an expert.
              Thank you for your help!
              • iganas
                • Mar 2016
                • 14
                • Denmark
                Hi reid, I have exactly the same issue on the same board. Have you managed to fix yours?
                • reid
                  • Feb 2011
                  • 16
                  No I never got it working. I think the last thing I tried was injecting voltage onto PM_OPC_ZVM_L which did turn on the PPVCCEDRAM_S0_CPU rail. But the laptop still didn't boot. I gave up on it but I still have the board so if you figure anything out let me know!
                  I'm assuming the missing PM_OPC_ZVM_L is a symptom of what the real problem is, and not the problem itself.
                  • jma46
                    • May 2020
                    • 24
                    Hi, I have a similar problem, the board I have responds to pram reset, the mouse pad feels like its working, the backlight is on but no image? I replaced one of the CPU mosfets which was getting hot, ramps to 20v .8 ma draw then settles around .35ma. Wont boot with touchbar connected, doesnt draw any amps, but seems to be booting unplugged.
                    Sorry just to add, Caps lock lights up, my next step is to connect speakers and see if it chimes and also any usb activity
                    • mon2
                      • Dec 2019
                      • 14309
                      Caps lock lights up
                      press the caps key after you see this led lit. Does the same led toggle on/off? If yes, the operating system has booted and you are at the login screen.
                      • jma46
                        • May 2020
                        • 24
                        Hi Mon2 yes caps lock toggles, backlight ok but no image, is it either flexgate on the data cable or something else?
                        • mon2
                          • Dec 2019
                          • 14309
                          Yes, may be flexgate. Test with an external monitor to be sure.
                          • Mateusz200
                            • Apr 2024
                            • 9
                            • Polska
                            Hi, did anyone solved problem from this topic? Have same issue with a1706 and running out of ideas.
                            • mon2
                              • Dec 2019
                              • 14309
                              What is the voltage & current draw showing on your power adapter? 20V ?
                              What is the voltage to ground of PPBUS_G3H @ F7000 ? (check both sides of this fuse)
                              • Mateusz200
                                • Apr 2024
                                • 9
                                • Polska
                                there is 20v and around 1A without battery (current is floating after pressing power switch), PPBUS_G3H is 13v
                                • mon2
                                  • Dec 2019
                                  • 14309
                                  Any liquid damage?
                                  https://repair.wiki/w/MacBook_Pro_A1706_No_image_repair
                                  • Mateusz200
                                    • Apr 2024
                                    • 9
                                    • Polska
                                    I got this board from intenet but doesn't seem to by any liquid damage. It's like it turns on and probably post but no image.
                                    • mon2
                                      • Dec 2019
                                      • 14309
                                      Does the keycaps LED toggle after a normal boot time? Any boot chime? Any fan spin? Do you see the mouse LED light flicker if using an external USB mouse? Do you have an external USB hub to test with external video / monitor? Tested with a PRAM reset?
                                      • Mateusz200
                                        • Apr 2024
                                        • 9
                                        • Polska
                                        So, I did SMC or PRAM reset, fans starts to spin after power on when cpu gets little hot, no chime and keycaps led, external devices have power, and there is no video on external screen via hdmi. I’ll do smc and pram resets once more just to be sure. Should caps light up even without keyboard backlight?
                                        • Danielreinaa
                                          HELP need password bios Macbook A1706
                                          by Danielreinaa
                                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                          09-07-2024, 03:47 PM
                                        • capon5153
                                          Macbook A1706 works perfectly but no data on USB C
                                          by capon5153
                                          hello,
                                          so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                          i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                          06-22-2025, 09:42 AM
                                        • B2L_Repairs
                                          Macbook A1706 touchpad and keyboard not working. Please help
                                          by B2L_Repairs
                                          Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                          10-09-2023, 04:56 AM
                                        • obelix24
                                          A1706 - Macbook pro - one USB-C port only 20V 0A
                                          by obelix24
                                          I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                                          I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                                          There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                                          There were some broken pads under CD3215 but i've recreated them.
                                          What should be...
                                          05-22-2024, 08:04 AM
                                        • johnbeton
                                          Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
                                          by johnbeton
                                          I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
                                          Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
                                          This is what I measure so far:
                                          Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
                                          PPBUS_G3H = 0,79v
                                          PPBUS_HS_CPU = 0,79v
                                          PPBUS_HS_OTH5V = 0,79v
                                          PPBUS_HS_OTH3V3...
                                          05-21-2024, 02:06 PM
