Macbook Pro 13 A1278 - cycling PPBUS_G3H
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    I have a board from year 2011. History unknown. I have only board and PSU. I was told that Macbook starts and shutdown and battery is not charging.
    I have steady 3.42V voltage and green light on charger (PP3V42_G3H = 3.48V). However PPBUS_G3H cycle between 12.9V (already too high) and 3.5V. The time priod of cycling is about 5sec. PPBUS_G3H keeps at the level of 12.9 for about 5 sec, and there is gradual drop to 3.5V and then back to 12.9V (in about 3-4 sec).
    In the repair wiki, I couldn't find what could be the problem. I suspect that U7000 chip ISL6259 could be bad, but wonder how can I be sure.
    CHGR_ACIN is about 3.5V
    Should i remove the fuse F7040 and test whether the problem is on the generating PPBUS_G3H side or futher in the circuit?
  • mon2
    • Dec 2019
    • 14206
    Re: Macbook Pro 13 A1278 - cycling PPBUS_G3H
    Hi.
    Is the power adapter the original and suitable for this logic board?
    Yes, remove the fuse and confirm if the power rail remains stable without the downstream load.
    Based on the long duration of pulsing at every 5 seconds, it likely is not a shorted cap fault.
    Could be bios communication fault. Check the voltages of your bios device onboard.
    • Adenitz
      • Jan 2021
      • 122
      • Congo
      Hello mon2 and thank you for your help.
      No, I don't have a charger. I have lab PSU set to 15V and Magsafe connector (L style) connected to the PSU.
      SPI ROM (U6100):
      PIN1: 3.29V stable
      PIN2: 3.29V stable
      PIN3: 3.3V for about 6sec then 0 V for about 3 sec then back to 3.3V and so on.
      PIN4: 0V stable
      PIN5: 3.29V cycling (6 sec 3.29V and then 0V for about 3 sec)
      PIN6: cycling same as PIN5
      PIN7: 0V stable
      PIN8 (3V3_S5): cycling same as PIN5
      I'll check PPBUS_G3H after removing the fuse and let you know.
      • mon2
        • Dec 2019
        • 14206
        See attached.
        Check & post the voltage readings on the SMBUS interface lines. Invested about 8 hours a few weeks ago to locate that the same ESD diode (D6950 = tiny little bugger) was the fault. Client had to play roulette as to when the laptop would turn on.
        Interested in the voltages at these 2 lines. These same interface lines are used to chat with the battery and U7000 (perhaps other parts on the logic board as well).
        • Adenitz
          • Jan 2021
          • 122
          • Congo
          Thank you mon2, I'll check this when I get back to this board, currently doing another job.
          BTW I have removed the fuse, and on the system side was about -0.3V, but on the side towards U7000, it was still cycling from 3.5 to 12.97V.
          • Adogabriel100
            Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
            by Adogabriel100
            Hey! This is a A1278 macbook 2011.
            Problem: Not turning on / No green light
            Im using by3200s charger.
            Voltajes:
            PPBUS_G3H = 12.26v
            SMC_RESET_L = 3.3v
            PP3V42_G3H = 3.42v
            U7000 =
            Pin 1 CHGR_AGATE = 0v
            Pin 2 CHRG_DCIN = 19v
            Pin 3 CHRG_ACIN = 4.6v
            Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
            Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
            Pin 12 PP3V42_G3H = 3.42v
            Pin 13 CHRG_RST_L = 3.3V
            Pin 14 SMC_BC_ACOK = 0.8V
            Pin 19 PP5V1_CHRG_VDD = 5.05V
            Pin 20 PP5V1_CHRG_VDDP = 5.03V...
            04-01-2024, 01:02 PM
          • Rezendes
            Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
            by Rezendes
            Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
            I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
            The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
            05-10-2024, 02:18 PM
          • pcbmaniac
            MacBook A1278 (3115) No PPBUS_G3H Issue
            by pcbmaniac
            Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
            I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
            1. U7000 Measurements:
              • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
            2. Resistors:
              • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
            Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
            • If I also decide to replace the SMC, do I need to order it pre-programmed,
            12-02-2024, 04:12 PM
          • sizar00740
            macbook pro 13 inch a1278 820-2879
            by sizar00740
            please clear me this bios efi macbook macbook pro 13 inch a1278 820-2879...
            07-30-2025, 10:21 AM
          • dbuergi
            MacBook A2141 one USB port dead and one power cycling
            by dbuergi
            I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
            Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
            04-25-2025, 11:40 AM
