LENOVO G580 no power
  • mo000
    • Nov 2017
    • 276
    • algeria
    hi
    lenovo g580 LA-7981p dead no power no led
    3.3/5v is missing
    IC POWER RT8205
    vin 19v
    en 3v
    vreg5 5v
    vreg3 3v
    entrip1 0.6v
    entrip2 1.2v
    pgood 0v
    no short on 3.3/5 lines
    is that means the kbc is defective ? .
  • mon2
    • Dec 2019
    • 14240
    Re: LENOVO G580 no power
    Remove all power. Meter in resistance mode (2k scale is ok).
    Check and post the resistance for each mosfet linked to these rails:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Check mosfets PQ401, PQ403, PQ402, PQ404.
    Next check the gate voltage of each mosfet. Is this regulator even putting out any gate voltage ?
    Is B+ voltage present on the high side mosfets ?
    Personally do not know but how is KBC linked to this switching regulator?
    Looks like that PU401 is defective but share the above details.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      What is the consumption on your dc supply??
      • mo000
        • Nov 2017
        • 276
        • algeria
        what is the consumption on your dc supply??
        0
        • mo000
          • Nov 2017
          • 276
          • algeria
          all resistance no reading except (S-G) OF PQ401 and 402 shows 0ohm
          the two mosfets are ok but i change them but same results .
          gate voltage of each mosfet 0v
          yes b+ present on high mosfets
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            is +19V reaching CLR?? I think not as consumption is "0" on dc supply.
            • mo000
              • Nov 2017
              • 276
              • algeria
              yes the consumption is 0
              and +19v reach to power ic and both high mosfets
              main power rail is ok and no short .
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                @mo000, be specific in your replies as mb is not in our hand. Which power ic and high side mosfets you are talking about?? Why not check on CLR??
                • mo000
                  • Nov 2017
                  • 276
                  • algeria
                  i talk about 3.3/5v power ic PU402
                  which CLR you mean ?
                  you mean PR302 .
                  • mo000
                    • Nov 2017
                    • 276
                    • algeria
                    any idea ?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Yes PR302 but +19v is likely there as it reaches PU402. You should focus on charging IC as dc-in mosfets gates are not opening. So if +19V reaching CLR , your mosfet is working in diode mode without proper biasing. This needs to be fixed first. Improper +19V entrance to mb can cause many problems. Give us measurements on charging ic.
                      • mo000
                        • Nov 2017
                        • 276
                        • algeria
                        cahrger ic BQ737
                        pin1 +19v
                        pin2 19
                        pin3 0
                        pin4 0
                        pin5 0
                        pin6 2.7
                        pin7 0
                        pin8 0
                        pin9 0
                        pin10 0
                        pin11 0
                        pin12 19
                        pin13 19
                        pin14 0
                        pin15 0
                        pin16 6
                        pin17 18.9
                        pin18 19
                        pin19 19
                        pin20 19
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Going by the charging ic readings,problem is absence of 3v ldo but you said 3vreg is present. Are u sure 3v reg(ldo) is present?? U don't have sda/scl on charging ic and neither acok is there on pin5 which pulls the voltage from 3v ldo. So check again 3v reg is present or not. Btw, VFB1/vfb2 voltage on 3-5 v regulator??
                          • mo000
                            • Nov 2017
                            • 276
                            • algeria
                            yes 3vreg is present (pin8 rt8205e)
                            vfb1/fb2=0v .
                            this laptop drop me to insane .
                            • mon2
                              • Dec 2019
                              • 14240
                              Your +3VALWP rail appears to be absent. This rail defines the SMBUS pull-up resistor. Since the reading is 0 volts on SMBUS, most likely the pull-up resistors are not being pulled up to 3v3. Issue is with PU401 who generates the +3VALWP rail.
                              Check and post the voltages for the attached points for PU401.
                              Has PU401 been replaced before ?
                              • mo000
                                • Nov 2017
                                • 276
                                • algeria
                                the readings in attachment .
                                why pu401 has all the requirement voltages but can't generate 3.3/5v ALW?
                                btw i try to replace it but same results .
                                • mon2
                                  • Dec 2019
                                  • 14240
                                  There are different versions of the RT8205 part (PU401). The full part number is very important.
                                  Do you have the original part still available ?
                                  Post the pic / markings of the original part.
                                  What are the markings of the replacement part on the board ?
                                  The part number you must use is:
                                  RT8205EGQW
                                  Top markings are 'DT='
                                  https://www.aliexpress.com/item/4001...rch-mainSearch
                                  • mo000
                                    • Nov 2017
                                    • 276
                                    • algeria
                                    RT8205EGQW
                                    I use TPS51225
                                    • mon2
                                      • Dec 2019
                                      • 14240
                                      RT8205EGQW = 24 pin device + 1 pin for the center bottom ground pin.
                                      TPS51225 = 20 pin device + 1 pin for the center bottom ground pin.
                                      Unless you have a different version of the TPS51225, they are not pin for pin compatible.
                                      • mo000
                                        • Nov 2017
                                        • 276
                                        • algeria
                                        yes it's 24 pin
                                        The part number of the original is EM FA
                                        I also repace it with another ic withe part number EM FB
                                        but same result
                                        I think after all the problem in kbc .
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Mita99
                                          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                          by Mita99
                                          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                          04-27-2025, 07:20 PM
                                        • Dr.d
                                          Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                          by Dr.d
                                          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                          04-05-2024, 11:48 AM
