LENOVO G580 no power
  • mo000
    • Nov 2017
    • 285
    • algeria
    Re: LENOVO G580 no power
    any idea
    i want to replace the kbc but the replacement needs to reprogram i don't have the adapter of KB9012 for RT809
    i try to reprogram the original one without desolder it but the rt809 can't recognize the kbc .
    • mon2
      • 14664
      No experience (yet) with KBC programming but in the end, the KBC will output some logic levels for this power supply rail(s) to enable.
      You could mimic, the KBC activity by tracing back the wiring to the KBC and this component. Then just probe, what are the logic (voltage) levels. Respectively, it should be possible to interrupt these connections and allow you to apply the voltage manually from another part of the logic board for perhaps the 3v3 enable signal, etc.
      This should allow you to 'force' the TI regulator to turn on or at least validate if it is capable of turning on.
      Is their a datasheet available for the 24 pin version of the TI part ? Or maybe it was a custom part for the laptop markets ? Just wanting to review the pinout for the larger QFN package.
      • mo000
        • Nov 2017
        • 285
        • algeria
        but in this model power enable signal not coming from the kbc .
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Mita99
          Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
          by Mita99
          Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
          Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
          Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
          04-27-2025, 07:20 PM
        • Dr.d
          Help please..Lenovo ideapad 5 14itl05 power and charging problem
          by Dr.d
          I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
          Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
          04-05-2024, 11:48 AM
