ACER e1-531 not charging .
  • mo000
    • Nov 2017
    • 276
    • algeria
    hi everyone
    the laptop comes to me with water damage
    i clean it and i fix the shorted (the short not in charging circuit) .
    the laptop works fine with battery and with charger
    but when i plug in the power supply to charge the battery the voltage becomes 16 v with high amps 5A and mosfet PQ9 becomes very hot
    i change the PQ9 PQ11 and charger ic BQ25A and PR52 and pq12 pq13 witout any change .
  • mon2
    • Dec 2019
    • 14027
    Re: ACER e1-531 not charging .
    Remove all power. Meter in resistance mode (2k).
    Check resistance of:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    for each mosfet. Low readings are of concern.
    Which exact mosfet was used for PQ9 ?
    • mo000
      • Nov 2017
      • 276
      • algeria
      PQ9 (S-D) 0 ohm (S-G) 5 ohms (G-D) 5 ohms
      PQ10 (S-D) 0 ohm (S-G) 5 ohms (G-D) 0 ohms
      PQ11 (S-D) 0 ohm (S-G) 0 ohms (G-D) 0 ohms
      PQ12 (S-D) 0 ohm (S-G) 0 ohms (G-D) 0 ohms
      PQ13 (S-D) 0 ohm (S-G) 0 ohms (G-D) 0 ohms
      PQ9 mosfet AO4496
      • mon2
        • Dec 2019
        • 14027
        Wow. From the posted resistance values, each mosfet appears to be defective.
        Try the following:
        a) remove PQ9 off the logic board. Then measure the resistance again for the removed mosfet. Are the readings much different of the removed component ?
        b) with PQ9 removed - check the resistance of the PCB pads where PQ9 was soldered.
        Post the values of PQ9 (when it is not on the board) & PCB pads with PQ9 removed.
        Do not power up the logic board.
        c) Did you replace only PQ9 with the AO4496 ? No other mosfet has been replaced ?
        • mo000
          • Nov 2017
          • 276
          • algeria
          Try the following:
          the problem solved
          i replace pq9 and pq10 with AO4456
          the laptop charging fine
          thank you for help .
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • CPUFiddler
            Acer Nitro 5 AN515-45 not charging
            by CPUFiddler
            Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
            This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
            I've downloaded...
            03-19-2025, 07:44 AM
          • ronaldopdias
            Acer Aspire 3 A314. Not Charging.
            by ronaldopdias
            Laptop Model: Acer Aspire 3 A314
            Motherboard Model: DA0Z8EMB8C0 - Model: Z8E
            Charging IC: BQ24780 which I have repalced.
            Issue Description:
            I'm experiencing an issue with the charging system on this laptop. The BQ24780 charging IC is not working as expected. The main problems are:
            1. ACDET is missing (0V):, Reading 0V on the ACDET pin.
            2. ACOK is not present (0V): Is missing as well.
            3. No SMBus signals (SDA and SCL are missing): The SDA and SCL signals for SMBus communication are not present. There is no clock (SCL) or data (SDA) activity on these lines.
            What I Have...
            12-19-2024, 04:15 AM
          • Source Code
            Acer Nitro 5 not charging but working with battery
            by Source Code
            Hello Everyone
            First I must say I am trying to learn electronics. I have an Acer Nitro 5. Board is LA-861P. The laptop does not charge but when it has battery life it would power on and work fine. I have use a multimeter to check the charger and I get 19v.
            Input on PBQ3 mosfet is 19v but no output or very low voltage. The voltage on PCZ65 and PCZ48 is 2v and it keep dropping after putting the charger for a few second. Battery pin would give like 0.200v declining.
            If I put the laptop off for like 2-3 months it would start charging again but I need to do this...
            11-17-2024, 12:44 AM
            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-07-2024, 05:00 AM
