XPS 15 9570 will not charge but battery works
  • madjid911
    • Dec 2016
    • 410
    • France
    #81
    Re: XPS 15 9570 will not charge but battery works
    Originally posted by mon2
    Yes, do not trust the fake charger.
    Remove pq100 mosfet.
    Short the PR100 pads to bypass the pq100 mosfet.
    Using only the original power adapter, measure the ps_id pin voltage to ground again. This is assuming the voltage output of the real charger is ~19v.
    The single wire identification device from Dallas Semiconductor is a parasitic design. It leans on the pull-up resistor on the mec5105 side to power itself.
    hello my friend, I haven't found another charger yet. I ordered PU200 to replace it
    • madjid911
      • Dec 2016
      • 410
      • France
      #82
      I changed ic intersil, but no result, so I checked all the resistors, PR1905 was at 200Kohms, while on the diagram is 2ohms, I replaced it, and now when I plug in the miracle charger it starts , thank you very much for your help without you I could not have fixed
      • mon2
        • Dec 2019
        • 14659
        Very good to hear. Thanks for your update. It will help future readers.
        • madjid911
          • Dec 2016
          • 410
          • France
          #84
          hello, for the laptop it starts without problem, but the sound does not work, at first I thought it was due to a driver to install, I installed everything, I tried it in Windows 7, 10 and 11, now I'm sure it's not a driver problem but it comes from the motherboard, the ALC3266 chip was shorted, I replaced it twice, but still no sound, no more short circuit, the chip is well powered, I tried the jack port, no sound also, so I don't think it comes from slaps, do you have any ideas please? THANK YOU
          • mon2
            • Dec 2019
            • 14659
            Test with Linux.
            • madjid911
              • Dec 2016
              • 410
              • France
              #86
              Test with Linux.
              I tried with Ubuntu, the result is the same, no sound
              • mon2
                • Dec 2019
                • 14659
                Which driver for Windows has been installed?
                Found this one:
                Realtek High Definition Audio Driver | Driver Details | Dell Canada
                • madjid911
                  • Dec 2016
                  • 410
                  • France
                  #88
                  Found this one:
                  I took the original one on the Dell site with the laptop reference, but I also tried yours, I still have no sound
                  • mon2
                    • Dec 2019
                    • 14659
                    If the audio IC has been soldered correctly and no surrounding parts are missing, the driver is most likely the fault. This audio IC (codec) resides on the HDA bus so each of the required drivers must be present.
                    Try some of the ideas here:
                    No Audio / Distorted Audio on the Alienware 13 R3, 15 R3 and 17 R4 | Dell Canada
                    • techfreak9356
                      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                      by techfreak9356
                      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                      09-14-2023, 11:10 PM
                    • razenxd
                      How can I charge that battery pack?
                      by razenxd
                      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                      Now, I have noticed a few things.
                      The "dead" battery, while connected to charger and NOT Charging will...
                      12-05-2024, 06:11 AM
                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                      by sam_sam_sam
                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                      I bought this from an eBay seller but unfortunately they only had one
                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                      I bought three of from them to also make battery packs with this output power limit in mind
                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                      04-23-2025, 05:50 AM
                    • Klevjetack
                      Charge a L19D3PDA battery externally from the laptop
                      by Klevjetack
                      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                      03-05-2024, 07:26 AM
                    • gadgettree
                      Acer Nitro AN517-52 FH51M LA-J871P Works on battery only. Won't charge.
                      by gadgettree
                      Hi there,
                      I am having trouble diagnosing this gaming laptop.
                      The laptop does not power on with AC Power only. The battery also does not charge. The laptop turns on when the battery is plugged in, regardless of whether or not the charger is plugged in until the battery dies of course.
                      So something is stopping adapter power from getting to the laptop. I checked Adapdet to make sure that the motherboard knows when the adapter is plugged in. That works fine.
                      I suspect the first Mosfet isn't turning on but I am unsure how to properly diagnose that...
                      02-28-2024, 05:27 PM
