XPS 15 9570 will not charge but battery works
  • madjid911
    • Dec 2016
    • 390
    • France
    #61
    Re: XPS 15 9570 will not charge but battery works
    Originally posted by mon2
    Connect the laptop battery pack -> attach the power adapter -> turn on the unit -> does the BIOS report the power adapter is connected ?
    The power adapter must have the PS_ID (single wire) communication working to detect the power of the adapter.
    See attached. Measure the voltage to ground of the power adapter pins.
    ADP100 :
    PIN 1-2-3 19V5
    PIN 4 0V (PR102 - PD100 - PL104 0V and No short)
    PIN 5-6-7 0V
    pu200:
    PIN8 : 3V29
    PIN1 0V153
    PIN2 1V47
    PIN3 0V
    The bios indicates at startup a low battery, by connecting the charger the message does not disappear
    • mon2
      • Dec 2019
      • 14203
      If there is no short, pin # 4 of the power adapter should not be 0V.
      Confirm that the connector pin is ok.
      Remove the power adapter and measure the voltage of the PS_ID pin to the ground (outside metal ring) of the floating connector while the adapter is not connected to the logic board.
      If the power adapter is working, the PS_ID will be a voltage higher than 0v.
      • madjid911
        • Dec 2016
        • 390
        • France
        #63
        You are really very strong, indeed the connector had a problem, a cable was unsoldered, I resoldered the cable, I now have 4V23 on pin 4, but the motherboard still does not start
        • mon2
          • Dec 2019
          • 14203
          Good.
          See attached.
          • madjid911
            • Dec 2016
            • 390
            • France
            #65
            good.
            See attached.
            pl104 pin2 5v11 falling
            psid-2 0v
            ps_id 0v
            • mon2
              • Dec 2019
              • 14203
              Is the main battery pack connected ?
              • madjid911
                • Dec 2016
                • 390
                • France
                #67
                With main battery it's the same but i think the battery is dead, if I want to turn it on I have to put the main battery and the external 11V4 power supply to start
                pl104 pin2 4V35
                psid-2 0v
                ps_id 0v085
                • mon2
                  • Dec 2019
                  • 14203
                  What is the voltage to ground of +RTCVCC_R ?
                  Remove all power, meter in resistance mode.
                  What is the resistance to ground of:
                  PBAT_CHARGER_SMBCLK
                  PBAT_CHARGER_SMBDAT
                  • madjid911
                    • Dec 2016
                    • 390
                    • France
                    #69
                    what is the voltage to ground of +rtcvcc_r ?
                    pbat_charger_smbclk
                    pbat_charger_smbdat
                    rtcvcc_r 2v94
                    pbat_charger_smbclk 29kohms
                    pbat_charger_smbdat 29kohms
                    • mon2
                      • Dec 2019
                      • 14203
                      See attached.
                      Something is wrong here to have 0v on pin #3 of PU200A.
                      Remove all power and inspect that the resistors @ PR211 and PR219 are present and of the correct values. Suspecting that PR211 is missing or defective.
                      With the resistors in place and no broken traces, pin #3 of the PU200A should be ~1v8 (ie. not 0 volts as you are reading at this time).
                      • madjid911
                        • Dec 2016
                        • 390
                        • France
                        #71
                        See attached.
                        PR219 is good 23,67KOHMS
                        PR211 present, pin1 19V5 pin2 0V resistance OL, She is dead, i'm trying to find a 240Kohms resistor on macbook i have a lot of donor motherboard but i can't find 240K :s
                        • mon2
                          • Dec 2019
                          • 14203
                          The resistor value is not critical - do you have 200k or close to ?
                          In the end, the divided voltage needs to be UNDER the Vcc of the comparator @ PU200A voltage of 3 volts.
                          We can apply into the online calculator to see the actual value you can expect.
                          • mon2
                            • Dec 2019
                            • 14203
                            See attached. Borrow the 200k from another part of the board but replace that 200k with any value you can find from 10k - 200k. It will still work fine.
                            Apply the 200k here to rebuild the broken circuit.
                            Have to leave in a bit to teach junior driving. Going to burn some rubber - fast and furious style after locating the nox. Will check back later on the progress.
                            • madjid911
                              • Dec 2016
                              • 390
                              • France
                              #74
                              YES, I found 200Kohms, by removing PR211 i saw that the track was cut, I redid
                              PR211 PIN1 19V5 PIN2 2V1
                              PU200 PIN 3 2V1
                              R5842 200Kohms 0V5
                              but still no start, we are almost there
                              PQ200 PQ201 is ok now,
                              pq209 PIN1-2-3-4 19V23; pin5 0V22
                              • mon2
                                • Dec 2019
                                • 14203
                                Mrs. Mon2 is burying with a grocery list so maybe MIA till tomorrow.
                                Check the voltage to ground of each grey coil now that the main power rail is back.
                                What is ACOK on the charger IC now ? Is that back to a logic '1' = ~3v ?
                                BBL
                                • madjid911
                                  • Dec 2016
                                  • 390
                                  • France
                                  #76
                                  BBL
                                  ACOK OV
                                  +SDC_IN 19V22
                                  should PU1900 be replaced?
                                  • mon2
                                    • Dec 2019
                                    • 14203
                                    Back - still alive.
                                    See attached. Confirm the key voltages of PU1900 to be sure to know if it is being powered.
                                    If pin #17 of PU1900 is close to the +SDC_IN voltage then ACOK should be a logic high (not 0 volts).
                                    ACOK is an open drain pin and the voltage of ACOK is defined by the pull-up resistor and pull-up voltage @ pin #18 of PU1900.
                                    Confirm that there is a positive voltage on pin #18 of PU1900.
                                    Confirm that PR1911 is ~100k ohms (no power during resistance checks).
                                    While checking voltages - check the voltages on PQ1906 with the adapter connected. Perhaps it is ON and pulling ACOK to the 0 volts.
                                    Aside from the above conditions, perhaps PU1900 is defective and needs to be replaced. From the original posting, a 35 volt adapter could have killed many parts on the board.
                                    • mon2
                                      • Dec 2019
                                      • 14203
                                      The PS_ID voltage is too high. Something is wrong with this power adapter.
                                      Can you remove it and confirm the center pin voltage to ground while the adapter is disconnected from the logic board?
                                      If still this high value, test with a different Dell adapter. This high voltage is dangerous and can kill the mec5105 since the mec5105 ec controller is operating at 3V. So the gpio pin voltage (PS_ID) must remain at or below this power rail used by the mec5105.
                                      You can remove the series inductor / ferrite bead in series with the PS_ID signal trace. Once you are 100% sure the PS_ID voltage is under 3v3 then place back the ferrite bead.
                                      The mosfet between the battery connector and the mec5105 acts like a crowbar to halt over voltage spikes to the mec5105. At this time it unknown if the mec5105 is ok or not.
                                      The above is from the comments made by others in the 'unknown adapter' thread.
                                      • madjid911
                                        • Dec 2016
                                        • 390
                                        • France
                                        #79
                                        With the original charger ps_ID pin : 0V (0V when plugged in), with the compatible charger : 10V32 (4V24 when plugged in)
                                        PU200 =
                                        PIN 16 ADP :19V22
                                        PIN 17 DCIN_ISL88738 19V05
                                        pin18 VDD_ISL88738 5V11
                                        PR1911 93,4kohms PIN1 0V; PIN2 5V11
                                        PQ1906 PIN1 0V; PIN2 0V
                                        I will try to find another original charger for dell
                                        I think I will order PU200 to save time
                                        • mon2
                                          • Dec 2019
                                          • 14203
                                          Yes, do not trust the fake charger.
                                          Remove pq100 mosfet.
                                          Short the PR100 pads to bypass the pq100 mosfet.
                                          Using only the original power adapter, measure the ps_id pin voltage to ground again. This is assuming the voltage output of the real charger is ~19v.
                                          The single wire identification device from Dallas Semiconductor is a parasitic design. It leans on the pull-up resistor on the mec5105 side to power itself.
                                          • techfreak9356
                                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                            by techfreak9356
                                            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                            09-14-2023, 11:10 PM
                                          • razenxd
                                            How can I charge that battery pack?
                                            by razenxd
                                            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                            Now, I have noticed a few things.
                                            The "dead" battery, while connected to charger and NOT Charging will...
                                            12-05-2024, 06:11 AM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            by sam_sam_sam
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
                                          • Klevjetack
                                            Charge a L19D3PDA battery externally from the laptop
                                            by Klevjetack
                                            Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                            03-05-2024, 07:26 AM
                                          • gadgettree
                                            Acer Nitro AN517-52 FH51M LA-J871P Works on battery only. Won't charge.
                                            by gadgettree
                                            Hi there,
                                            I am having trouble diagnosing this gaming laptop.
                                            The laptop does not power on with AC Power only. The battery also does not charge. The laptop turns on when the battery is plugged in, regardless of whether or not the charger is plugged in until the battery dies of course.
                                            So something is stopping adapter power from getting to the laptop. I checked Adapdet to make sure that the motherboard knows when the adapter is plugged in. That works fine.
                                            I suspect the first Mosfet isn't turning on but I am unsure how to properly diagnose that...
                                            02-28-2024, 05:27 PM
