VCCGT mosfet damaged igpu?
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    acer predator g9-791g, i had previous thread about short 19v, but i solved this problem by replacing mosfet, in fact both two phases, just as a precaution.
    Mosfet that went is responsible for phase B of VCCGT (iGPU) [u8004].
    [Schematics] https://www.badcaps.net/forum/showpo...75&postcount=6
    Damage?
    https://imgur.com/a/VoquX0n
    https://imgur.com/a/9UWjBLp
    can improperly soldered mosfet do this?
    https://cdn.badcaps-static.com/pdfs/...a40e178c24.pdf
    originally manufacturer for this mosfet was coded T, i received from manufacturer G, if this has anything to do.
    Without power adapter plugged in, computer restarts till recovery window. Without drivers and no power supply it boots OK. So i'm not sure if it's mosfets or not.
    I'm not a professional. So i may ask weird questions.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: VCCGT mosfet damaged igpu?
    look more like VRAM damage or bad cable
    • mosfetratus
      Sure Not
      • Feb 2019
      • 174
      • Resistron
      igpu uses system RAM, i used prime95 stress test and ms memory diagnostics tool, didn't find any problems.
      bad cable? Without drivers screen is Ok.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        so it is bad memory or GPU. i see u have there gtx970M. it is in mxm and u remove it or it is still there?
        • mosfetratus
          Sure Not
          • Feb 2019
          • 174
          • Resistron
          Mosfet which gone bad is high side that connects to CPU's iGPU.
          Open board view, it will be easier to see. U8004 mosfet.
          Where to buy CPU without insane prices? alibaba?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            put MATS test on vram to check
            • mosfetratus
              Sure Not
              • Feb 2019
              • 174
              • Resistron
              nvidia gpu is fine. I can play games with it. iGPU is the problem, which means CPU replacement.
              Look at the block diagram, only way to bypass CPU is to use display port.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Honestly speaking, there is no reliable source to buy soc's. Best is to get one from unrepaired board where you know cpu is fine(some tests has to be carried to be sure). Reballing it is a nightmare though and to solder it properly requires very good skill and machine/tools. If this is your first attempt to replace soc, be prepared for disappointment as it does take time to hone your skill.
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • redbaron1007
                  Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                  by redbaron1007
                  I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                  Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                  09-09-2025, 11:10 AM
                • AppleLover123
                  Asus X712EA 3 volts after the first mosfet
                  by AppleLover123
                  Hey guys,
                  i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                  I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                  Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                  I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                  Now i thought something...
                  12-15-2024, 07:49 AM
                • MicroSMD Lab
                  ASUS ROG Zephyrus GPU Mosfet repeat failure
                  by MicroSMD Lab
                  The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                  I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                  01-10-2024, 06:36 AM
                • Scotchmist
                  Asus GA502D keeps blowing mosfet
                  by Scotchmist
                  I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                  I have removed the mosfet and can run the laptop no problem
                  The MOSFET is FDPC5018SG
                  Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                  08-24-2024, 02:23 PM
