3-Beep Dell 5110
  • khelane
    • Apr 2015
    • 171
    • xxxx
    3-Beep Dell 5110
    Hello
    A Dell 5110 with a 3-beep problem
    When I turn on the device, the device starts with 3 beeps and after one second, it gives 3 short beeps in a row, then pauses again for one second and then 3 beeps until I turn off the device.
    Without RAM, the problem still persists
    Programmed BIOS.
    The motherboard is clean.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: 3-Beep Dell 5110
    Wondering with so much information you gave, how i can help. No measurements, no steps -nothing.
    • khelane
      • Apr 2015
      • 171
      • xxxx
      Rome has been replaced
      The CPU has been replaced
      The bios program has been run twice
      There are no signs of burns or damage to the board
      These two voltages are enough or the voltages of which parts to take
      3.3 v and 5 stb are present
      1.5 and 0.7 ram ok
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Consumption on dc supply
        01.With Ram
        02.Without ram
        1.8V present?? vcore present?? dramrst# present??
        • khelane
          • Apr 2015
          • 171
          • xxxx
          I checked the device again with another CPU and the beep changed from 3 beeps to 5 beeps.
          I had an image on the monitor but I did not have an image on the laptop monitor. I refluxed the graphics, the image was correct, but now I do not have BACKLIGHT.
          On pin 123 LVDS
          I have 19 volts but I do not have 5 volts on pin 5, the resistance value of R4902 is 33 ohms and it is correct.
          • khelane
            • Apr 2015
            • 171
            • xxxx
            LVDS PIN
            1,2,3 =DCBATOUT_LCD 19 V
            5 = LCD BRIGHTNESS 0 V
            15 = BLON_OUT_C 0 V
            26 = LCD_TST_C 0 V
            27 = 3.3 V
            38,39,40 = 3.3 V
            RN4901
            both side are 0 volt,I checked the i/o pins but they did not have voltage
            One note: PCH gets so hot that it can not be tolerated by hand
            • khelane
              • Apr 2015
              • 171
              • xxxx
              up
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                If the pch is hot then it is dead and game over.
                • khelane
                  • Apr 2015
                  • 171
                  • xxxx
                  ok tnx
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • cygron
                    Dell Latitude 3440 2 Beeps Problem
                    by cygron
                    Model: Dell Latitude 3440
                    Board id: DL340-HSW MB 13221-1 Rev: A00
                    Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
                    PL4503 - 3.3V
                    PL4101 - 5V
                    PL4902 - 1.35V
                    PL4801 - 1V
                    PL4701 - 1.7V
                    PL4401 - 17V
                    PL5101 - 0V
                    PU5102 pins -
                    Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
                    Pin 2, 4 - 0V
                    Pin 3 - 0.95V
                    Pin 5 - 2.87V
                    Pin 6 -...
                    04-20-2025, 03:46 AM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
                  • mohamed mm
                    Dell inspiron 5520, 7 beeps problem
                    by mohamed mm
                    I've an Inspiron laptop model 5520, board name, la 8241p, with a 7-beep problem.
                    exist voltage:
                    PL 200:3.3v
                    PL 201:5v
                    ram volt PL300: 1.5v
                    PL600: 0.9v
                    PL500: 1.0V
                    PL 202: 19V
                    Processor section:
                    PL701: 1.2V
                    PL702:1.2V
                    but PL704: 0.0V
                    and PQ705 / PQ706 are zeros on gate/drain and source.
                    PC724/PC712 : 19V.
                    bios volts:
                    EN25QH16 / EN25Q32B: 3.3v.
                    I tried to program a (W25Q32B) BIOS chip with an (EN25Q32B) BIOS dump from the internet, but during verification, it says
                    08-22-2025, 07:13 AM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
