3-Beep Dell 5110
  • khelane
    • Apr 2015
    • 160
    • xxxx
    3-Beep Dell 5110
    Hello
    A Dell 5110 with a 3-beep problem
    When I turn on the device, the device starts with 3 beeps and after one second, it gives 3 short beeps in a row, then pauses again for one second and then 3 beeps until I turn off the device.
    Without RAM, the problem still persists
    Programmed BIOS.
    The motherboard is clean.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: 3-Beep Dell 5110
    Wondering with so much information you gave, how i can help. No measurements, no steps -nothing.
    • khelane
      • Apr 2015
      • 160
      • xxxx
      Rome has been replaced
      The CPU has been replaced
      The bios program has been run twice
      There are no signs of burns or damage to the board
      These two voltages are enough or the voltages of which parts to take
      3.3 v and 5 stb are present
      1.5 and 0.7 ram ok
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Consumption on dc supply
        01.With Ram
        02.Without ram
        1.8V present?? vcore present?? dramrst# present??
        • khelane
          • Apr 2015
          • 160
          • xxxx
          I checked the device again with another CPU and the beep changed from 3 beeps to 5 beeps.
          I had an image on the monitor but I did not have an image on the laptop monitor. I refluxed the graphics, the image was correct, but now I do not have BACKLIGHT.
          On pin 123 LVDS
          I have 19 volts but I do not have 5 volts on pin 5, the resistance value of R4902 is 33 ohms and it is correct.
          • khelane
            • Apr 2015
            • 160
            • xxxx
            LVDS PIN
            1,2,3 =DCBATOUT_LCD 19 V
            5 = LCD BRIGHTNESS 0 V
            15 = BLON_OUT_C 0 V
            26 = LCD_TST_C 0 V
            27 = 3.3 V
            38,39,40 = 3.3 V
            RN4901
            both side are 0 volt,I checked the i/o pins but they did not have voltage
            One note: PCH gets so hot that it can not be tolerated by hand
            • khelane
              • Apr 2015
              • 160
              • xxxx
              up
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                If the pch is hot then it is dead and game over.
                • khelane
                  • Apr 2015
                  • 160
                  • xxxx
                  ok tnx
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • cygron
                    Dell Latitude 3440 2 Beeps Problem
                    by cygron
                    Model: Dell Latitude 3440
                    Board id: DL340-HSW MB 13221-1 Rev: A00
                    Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
                    PL4503 - 3.3V
                    PL4101 - 5V
                    PL4902 - 1.35V
                    PL4801 - 1V
                    PL4701 - 1.7V
                    PL4401 - 17V
                    PL5101 - 0V
                    PU5102 pins -
                    Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
                    Pin 2, 4 - 0V
                    Pin 3 - 0.95V
                    Pin 5 - 2.87V
                    Pin 6 -...
                    04-20-2025, 03:46 AM
                  • tech_guru
                    Dell Inspiron 5558 8 Beeps
                    by tech_guru
                    Hello.
                    If you can help with this one please...The laptop does 8 beeps at boot which as I see is LCD error. The laptop shows image to external monitor normally. New screen flex and screen does not change anything.
                    So I took measurements in the LCD socket (LCD1):
                    DCBATOUT_LCD 19V
                    LCDVDD_LCD 3.3V
                    DBC_EN_R 0V
                    EDP_HPD_CONN 3.2V
                    LCD_TST_C 0V
                    EDP_AUX 3V
                    EDP_AUX# 0V
                    EDP_TX0# 0V
                    EDP_TX0 0V
                    EDP_TX1# 0V
                    EDP_TX1 0V
                    LCD_BRIGHTNESS 0V
                    BLON_OUT_C 0V
                    PANEL_SIZE_ID_CONN 0V​
                    The ones that are 0v,...
                    02-18-2025, 02:13 AM
                  • tech_guru
                    Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                    by tech_guru
                    Hello.
                    I am having a disappointing motherboard repair with this laptop and I need your help.
                    This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                    -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                    -PQ102 MDV1525URH
                    -U17 AOZ1331
                    -UE1 C8051F383-GQ
                    -PU800 SY8032ABC
                    -UI2 SY6288D20AAC
                    -PU508 RT6220AHGQUF 7P=
                    -PU100 TPS51225CRUKR
                    -PU300 TPS51212DSCR
                    Now, I get all the standby voltages, it turns...
                    02-16-2024, 09:40 AM
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
