Wistron JE70-CP MB - turns off after 32 sec.
  • GlobalPlayer
    • Nov 2019
    Hi together,
    I am new at this forum and just for learning an understanding i took this old mainboard from a 17" Packard Bell Laptop.
    Battery is dead and I run it with a power adapter only.
    It turns on, I get image on the the screen, fans start running and I can enter bios or bootmenü (I removed the hdd). After exactly 32 seconds it turns off and I can start over again.
    I checked it with a stop watch, every time exactly 32 seconds, doesn't look like a faulty cap or something like this to me.
    More than a system check fails at the same stage but when I can enter bios or bootmenu the system check should already be completed, right ?
    i removed both RAM-Modules, tried with only one or the other, i applied new heat sink and replaced the 3V Button Cell, same result.
    In the schematics I found sheet 43 (Run Power) and measured some voltages but I have no idea what can cause the system shut down.
    Some hints for me ?
    Thanks a lot in advance
    GP
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: Wistron JE70-CP MB - turns off after 32 sec.
    clean bios me
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Check U55 ic.
      • GlobalPlayer
        • Nov 2019
        Thank you mcplslg123, that was Bullseye !
        U55 was the culprit (or one of the external temp.sensors).
        I couldn't find out which one but most likely GPU-Sensor.
        So i lifted up the DXP3 leg of U55 and and tried what happens.
        You know what ...it stays on.
        Fan turns on and off, everything looks ok.
        Thanks again and a happy new year !!
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Glad you fixed it. happy new year to you mate.
          • Stephen
            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
            by Stephen
            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
            03-15-2024, 09:37 AM
          • www
            LG L192WS-BN backlight turns off after 1 second
            by www
            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
            03-24-2024, 05:26 PM
          • BMCappelletti
            Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
            by BMCappelletti
            Hi everyone.
            Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
            Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
            Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
            02-18-2025, 12:22 PM
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • andrhouseolly
            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
            by andrhouseolly
            Hi.
            I kindly ask you to help me solve the problem.
            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
            The board turns on, there is no image.
            Read more. When the power supply is connected, the front panel indicators light up briefly.
            When you press the power button, the button indicator lights up. The board works
            there is no image, there is no matrix initialization, there is no image on HDMI.
            When turned on, the fans do not spin, but when they warm up they start spinning.
            When you turn off the button, the fans spin up to full speed for a short...
            05-11-2024, 03:14 PM
