Macbook pro M1 A2338 820-02020 Liquid
  • Strolch
    • Nov 2017
    • 237
    • Deutschland
    The board has gotten wet, you can see it in the pictures. The display stays dark! No backlight. I think I have to bypass the front of the needle point too? Unfortunately I don't have a board view for my A2338! Is there a chip in the picture for the backlight?
    • 20990
    Re: Macbook pro M1 A2338 820-02020 Liquid
    schematic + boardview - https://www.badcaps.net/forum/showthread.php?t=97725
    • Strolch
      • Nov 2017
      • 237
      • Deutschland
      thx but its a BVR and I have openboardview.
      • andreacero
        • Nov 2021
        • Italy
        Hi guys, I have a similar problem, macbook pro M1 liquid damage.
        My type c tester says 5,125 V, no short on logic board, power manager isn't too much hot 30 degrees.
        What can I do?
        • bigbadbios
          a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
          by bigbadbios
          I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
          When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
          I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
          Your help is GREATLY appreciated. Thanks!
          08-18-2024, 05:47 PM
        • dbuergi
          MacBook Pro A2338 liquid damage repair for a beginner?
          by dbuergi
          i have a A2338 with water damage on the logic board. Cleaning it showed some heavier corrosion around U7000 and surrounding caps. Some are totally broke.
          I get 5,2v when using both USB-C Ports but until now i didn't make any more tests.
          Since i'm a beginner i want to know next possible steps. I'm not afraid replacing the intersil 9240hi but the other parts with 1mm or 2mm scare me and i don't know where to get replacements.
          I fixed other laptops but this ist my first apple device ....
          07-24-2024, 09:48 AM
        • fajfelek
          Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
          by fajfelek
          Hello, First of all thanks you for reading this topic.
          I need your help with identify missing parts on trackpad logic board (661-18430).
          The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
          Please help me with identity parts from blue and red area .
          06-15-2024, 01:41 PM
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
