LA-7912P powers on with AC or battery but won't charge.
  • diif
    • Feb 2014
    • 6978
    • England
    I've got a Packard Bell with a LA-7912P rev 1.0, it runs with the DC adapter plugged in and it will run from the battery if that's plugged in. It only runs on battery if the DC adapter is plugged in. It also won't charge the battery.
    My knowledge is lacking but I have measured ACOK 2.6v and ACDET 1.9v on PU4, I'm hoping i can get some further assistance, thank you.
  • mon2
    • Dec 2019
    • 14010
    Re: LA-7912P powers on with AC or battery but won't charge.
    1) is the battery a known good battery?
    2) is the power adapter the original and suitable for this box?
    3) when the unit is booted and with a battery, what does windows report about the battery status?
    4) with the adapter connected, measure and post the voltages with respect to ground on mosfet PQ11.
    • diif
      • Feb 2014
      • 6978
      • England
      Thanks mon2, yes it's a new battery, the old one was dead, the adapter is good but I'm currently powering with my bench supply so i have an idea of current draw. Not sure about number 3, windows has a password on.
      19v on D, 3.1v on S and D... that doesn't seem right.
      • mon2
        • Dec 2019
        • 14010
        To turn on PQ11, the GATE of this mosfet should be about 6 volts higher than the SRN (current sense pin) on the charger IC.
        Measure and post the voltage of SRN (pin # 12) of the charger IC.
        For this test, the battery should be attached so that the I2C bus communications can continue to detect the battery.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          ACDET 1.9v-Something is wrong.
          • mon2
            • Dec 2019
            • 14010
            @mcplslg123, but charger appears to be happy with ACOK @ 2.6v. No? Perhaps could be a bit higher...check the pull up resistor voltage rail.
            • diif
              • Feb 2014
              • 6978
              • England
              11.35v
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                09-14-2023, 11:10 PM
              • razenxd
                How can I charge that battery pack?
                by razenxd
                it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                Now, I have noticed a few things.
                The "dead" battery, while connected to charger and NOT Charging will...
                12-05-2024, 06:11 AM
              • Shinju
                Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                by Shinju
                Hey All!
                Long time forum member here with a problematic laptop issue!
                I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                The laptop would not power on with the new battery installed without the power supply being plugged in.
                When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                10-20-2021, 04:58 PM
              • ruletero
                Acer a515-43 low battery charge voltage
                by ruletero
                Hi
                Acer A515-43
                LA-H801P
                Fail: Does not charge battery, has low voltaje on connector.
                Laptop didn't want to turn on, only charge led blinked.
                I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                10-24-2022, 02:31 PM
              • pluggedDan
                MacBook Pro A1706 charge stuck at 5v when battery is plugged in
                by pluggedDan
                I have an A1706 that was liquid damaged, the logic board turns on and works when the battery connector is not plugged in, but when the battery is plugged in, the computer is stuck on 5v @ 30-40 Mah, and USB-C meter will reboot every 5 sec or so, pressing and holding down the power button will make the USB-C meter to stop boot looping, and if you keep holding it, fan will quickly spin up and turn off.
                when the battery is unplugged and plug in the charger then plug in the battery it will stay on 20V and 1.6A-2.6A but when you unplug the charger, the computer...
                10-29-2023, 02:41 PM
