ACLU2 (G50-70) Motherboard Not Powering On
  • orestes_
    • Jun 2021
    • 14
    • Greece
    As the tittle suggests, the laptop does not want to power on. It is completely dead (no LEDs or the CPU/GPU fan spinning).
    Motherboard does received power, connector and the connector cable do work.
    I can hear a clicking sound coming from the motherboard every ~1.5s, I assume there is a open circuit somewhere that is causing all this trouble. I cannot pinpoint the location of the fault by ear, it sounds the same no matter where I place my ear.
    Nothing is hot or even warm to the touch. Super I/O chip does not appear to be damaged, so one or more conditions do not allow the unit to power on?
    Can you please advise what to check, very detailed because of my limited experience?
    Thanks.
  • mon2
    • Dec 2019
    • 14147
    Re: ACLU2 (G50-70) Motherboard Not Powering On
    hi.
    1) start with posting some clear pics of the logic board and show where the DC adapter enters the board.
    2) are you using the original DC adapter for this laptop ? What is the voltage that enters this logic board ?
    3) you should note some mosfets mating to the DC power connector. The mosfets are like solid state relays to turn on / off the power rail for the logic board. Quite often, these mosfets get damaged and produce the observed condition.
    4) For each mosfet - post the full markings on the topside of the device. This will help to locate the datasheets for further trouble shooting.
    Asus schematics are quite rare and so far unable to locate one for this logic board.
    Do you have a multimeter ?
    • orestes_
      • Jun 2021
      • 14
      • Greece
      Originally posted by mon2
      hi.
      I think you misunderstood, this is in fact a Lenovo laptop. It is the G50-70 with a 4th gen i3 and an basic AMD discrete GPU. The ACLU2 is, I think, the codename for this motherboard. There is also a thread on this forum, I think there are all the schematics needed there:
      https://www.badcaps.net/forum/showthread.php?t=72373
      1. pic attached
      2. 20V in, as the adapter states on the sticker. it is the original Lenovo one.
      3/4. there are 2 mosfets near the DC in on the mainboard, 4488A and 4407A.
      I do have a multimeter and I know how to solder but unfortunately I do not have a hot air station .
      thanks. 👍
      • mon2
        • Dec 2019
        • 14147
        See attached.
        Meter in DC voltage mode (any setting with 20V or higher is ok).
        1) check the voltage reading with the adapter plugged in on both sides of the surface mount fuse (it is the white component).
        Red meter lead on the one pad & black meter lead on any ground on the logic board (can be metal shield).
        2) If you do see the adapter voltage on BOTH sides of the fuse, continue to check the mosfets as per attached diagram.
        3) the white DOT on the part = pin # 1. See my Picasso drawing that shows how the pin order is for each mosfet.
        Check and post the voltages on each requested pin.
        Note that the pins are shorted together (on purpose) as per the schematic so you only need to check the voltage on any of these pins.
        In these tests, you are checking if the first in-line fuse is blown or not.
        Then you are checking to see if the first 2 mosfets are working properly or not.
        PS: For now, you do not need the hot air station. These mosfets, if they need to be replaced are SOIC 8 style. Using some sharp diagonal shears / cutters, you can remove them off the board and apply a fresh one. We are not there yet so for now, ignore.
        • orestes_
          • Jun 2021
          • 14
          • Greece
          See attached.
          Thank you for the detailed instructions, here you go:
          Fuse is OK (20V in and 20V out).
          With reference to Gnd:
          Mosfet #1 (4488A):
          Pin 1: 19.91 V
          Pin 2: 19.91 V
          Pin 3: 19.91 V
          Pin 4: 19.91 V
          Pin 5: 0V
          Pin 6: 0V
          Pin 7: 0V
          Pin 8: 0V
          Mosfet #2 (4407A)
          Pin 1: 19.91 V
          Pin 2: 19.91 V
          Pin 3: 19.91 V
          Pin 4: 19.91 V
          Pin 5: 20.44V
          Pin 6: 20.44V
          Pin 7: 20.44V
          Pin 8: 20.44V
          • mon2
            • Dec 2019
            • 14147
            Ok.
            1) PQ301 = mosfet p/n AO4407AL
            2) PQ302 = mosfet p/n Si4483ADY (last digit is a '3') - from the posted values, this 2nd mosfet in the design is not turning on since DRAIN pins are @ 0V.
            PQ302 is a P-channel mosfet (see attached) - specifically P-Channel Enhancement Type MOSFET (the broken dash lines inside the circle denote enhanced type).
            http://www.learningaboutelectronics....hannel-MOSFETs
            To turn PQ302 ON, the gate has to be lower than the voltage value on the SOURCE. The present reading is that the GATE (pin # 4) matches the input voltage of about 19V.
            To turn ON this mosfet, PACIN or BATT_OUT has to be a positive value such as +3v to turn on the local mosfets (2N7002) which will then apply a GROUND to the mating resistors.
            Once the local mosfets are ON, a resistor voltage divider is created which will then divide the +19V down to a lower value which will then turn on the PQ302 mosfet through the lower gate value.
            That is, when 2N7002 @ PQ307B is ON, then PR303 & PR307 form a resistor based voltage divider with +19V as the high side voltage. Together these resistors will offer a lower voltage @ GATE of PQ302.
            If the 2N7002 is OFF (default) then only PR303 is active and it will pull the GATE to be @ +19V which means that PQ302 will remain OFF.
            For these other 2N7002 mosfets to work, the 'always-on' rails must be working.
            See and check the attached. Post their values.
            • orestes_
              • Jun 2021
              • 14
              • Greece
              Ok.
              Took me a while to find them 😅.
              You can see in the pictures the said area of the PCB and how I probed them.
              It reads 0V on both of them.
              • mon2
                • Dec 2019
                • 14147
                I think the measurements were not taken properly for the black (ground) lead.
                Please see attached and repost after checking again.
                • orestes_
                  • Jun 2021
                  • 14
                  • Greece
                  indeed, I am stupid.
                  however, there is no voltage present on both of them even when with reference to ground.
                  • mon2
                    • Dec 2019
                    • 14147
                    hi.
                    1) see attached. check and post the voltages at '1' and then for '2' on PU904.
                    Meter in DC mode (20v or higher is ok).
                    Red meter at the requested test point. Black meter lead to ground.
                    We are checking if the DC adapter voltage is reaching this (+3VALW) regulator and also if the regulator is being ENABLED = told to turn ON or not.
                    2) Then repeat the same test for the +5VALW rail.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      @mon2, is there any sense in measuring voltage at PU904 when it is clear from PQ302 measurements that B+ rail is absent.PQ301 is just passing the voltage in diode mode as there is no proper biasing at gate of PQ301. PQ304 & PQ305 are there for protection purpose.@Orestes, try removing PQ304 and PQ305 one at a time and see if you get 6V approx at pin4 of PQ301 or not??
                      ps: You can safely apply power while PQ304 & PQ305 is removed.
                      • orestes_
                        • Jun 2021
                        • 14
                        • Greece
                        hi.
                        Thank you for your reply.
                        1)
                        1. No voltage
                        2)
                        1. No voltage
                        As for the other two points (for the 3V and 5V), I am not sure where exactly I should be probing for voltage? I tried probing both sides of all nearby passive components but I did not detect any voltage on all of them.
                        I am not sure I will be able to desolder them safely/resolder them back on the board if needed? I only have a T12 chinese soldering iron availiable.
                        I am attaching pictures as well.
                        May I ask this: with the information I have given you guys so far, what is your best guess as to what is the culprit? It is also making this repeating sound that you can hear in this video:
                        https://we.tl/t-DgEllpwkSF
                        (the background noise are the fans from my desktop computer. the sound that repeats every second or so is the one I am referring to).
                        Should I just buy a replacement motherboard from ebay/aliexpress for 80-90 euro and be done with it?
                        thanks.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Atleast give it a try. You wont loose anything as you're somewhat prepared to buy a replacement board. With a T12 iron and good amount of flux, you can remove PQ304/PQ305 though a hot air station would've helped a lot. This is not a tough fix and if you are not confident on your own, try some laptop repair shop nearby. that'll be a lot more reasonable and at fraction of replacement mb cost.
                          • orestes_
                            • Jun 2021
                            • 14
                            • Greece
                            are you suggesting removing these because they are possibly what's wrong with the motherboard or to further investigate what could be wrong with it?
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              You never know unless you remove those parts. Yes, my suggestion is to remove PQ304/305
                              • orestes_
                                • Jun 2021
                                • 14
                                • Greece
                                i shall give it a try in the weekend then. I will keep you posted.
                                • orestes_
                                  • Jun 2021
                                  • 14
                                  • Greece
                                  sorry guys for no updates, I haven't had any free time this past week to get to work on the motherboard..
                                  • Nagy Daniel
                                    ASUS TUF Gaming A17 FA707RM-HX038W / Motherboard DANJMMB1AA0 Rev: A // not powering on
                                    by Nagy Daniel
                                    I'm new in the world of repair, and I have a laptop that does not turn on.
                                    I don't know exactly the past of this laptop, I got it in a non-functional state.
                                    The LDO3 and LDO5 are present, and it provides 3.3 and 5V.
                                    When I started to diagnose the motherboard, the regulator for the LDO3V and LDO5V was quite hot, I checked it with a thermal camera, and the 3V from the DNBSWON was missing, so I replaced the IC Chip from a donor board (the ic chip is from the same type of motherboard)
                                    Now, the regulator is fine, it's not heating,...
                                    03-05-2025, 02:57 AM
                                  • duraven
                                    TT 94V-0 E326167 motherboard not powering up
                                    by duraven
                                    Hello! Embedded Software Engineer here, for fun trying to investigate a friend's laptop not powering up problem – first time opening a laptop.
                                    • The physical power button has been broken on the laptop and the friend advised that they needed to poke the area with a pen to get it to start
                                    • Eventually the pen poking stopped working and now the laptop does not power on at all.
                                    I have stripped down the laptop down to the motherboard but I cannot simulate the button press or otherwise see anything happening when the power is applied.
                                    Motherboard model TT 94V-0 E326167 <see image...
                                    10-28-2023, 03:54 AM
                                  • glovecaps
                                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                    by glovecaps
                                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                    11-25-2024, 04:23 PM
                                  • Docus
                                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                    by Docus
                                    Hi everyone 😀,
                                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                                    06-10-2025, 04:24 PM
                                  • Dergal T Stonkerson
                                    LCD monitor motherboard not powering up
                                    by Dergal T Stonkerson
                                    I have a faulty motherboard controlling G150XG01 LCD monitor. Pictures attached of two separate motherboards. I have being searching online for a schematic of the boards, none of the codes on the boards are giving any results when searching. Is it possible to get schematics for these? Is it possible to repair these surface mount pcb's, what are the common faults?
                                    Thanks in advance for any help/advise....
                                    08-15-2024, 04:00 AM
