Lenovo G50-70 - power on problem
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have problem with this notebook - is totally dead, no lights, nothing. At first I changed KBC IT8586, because was hot. I ordered programmed chip from ebay. After soldering new chip I found another issue - shorted B+ . Problem was in one shorted capacitor. Now 3.3V and 5v ALW are present. I tried flash bios also. Nothing changed. Now I found bad crystal 27Mhz - YVG1 in schematic. I can't find anything else bad. Can someone help me with this? thanks.
    Motherboard: ACLU1/ACLU2 NM-A271
    I attached schematic.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Lenovo G50-70 - power on problem
    why did you find the crystal faulty? what was wrong with it?
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      I take photo of the crystal.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        If the crystal is faulty, replace it. Only after that, you can decide on other components.
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          I order it from ebay. I mean there is another problem.
          • DeniS182
            • Jun 2014
            • 328
            • Slovakia
            I replaced crystal with one from another board. Nothing changed.
            • homeless_cz
              • Oct 2017
              • 18
              • Czech rep.
              Is 3V_ALW_PCH present ? If yes then you have to check what happens on IT8586.
              Does it have +3VALW and +3VS ?
              Check this in ready state and then after pressing pwr switch:
              PWR SW on pin 110
              LID SW pin 109
              AC present pin 128
              PCH_PWR_EN pin 97
              PCH_PWROK pin 99
              PBTN_OUT# pin 86
              MAINPWON pin 79
              EC_LID_OUT# pin 2
              EC_RSMRST# pin 93
              • DeniS182
                • Jun 2014
                • 328
                • Slovakia
                3V ALW_PCH = 3.3V
                KBC - 3VALW = 3.3V, 3VS = 0.4V
                ready state
                PWR SW on pin 110 = 3.3V
                LID SW pin 109 = 3.3V
                AC present pin 128 = 3.3V
                PCH_PWR_EN pin 97 = 0V
                PCH_PWROK pin 99 = 0V
                PBTN_OUT# pin 86 = 3.3V
                MAINPWON pin 79 = 0.3V
                EC_LID_OUT# pin 2 = 3V
                EC_RSMRST# pin 93 = 0V
                after pressing pwr button
                PWR SW on pin 110 = 0V
                MAINPWON pin 79 = 0.1V
                I tried jump Q24 then 3VS=3.3V but still nothing changed.
                • homeless_cz
                  • Oct 2017
                  • 18
                  • Czech rep.
                  This means ITE hasn't met his requirements to power on the system.
                  LID SW is OK -> LID OUT is OK, AC present is OK. PWR sw is OK.
                  When you press PWR button, pin 110 goes down and 86 should go down too, then 97 high, 93 high, 79 high and all other SUSP# and SLP# signals should go high too.
                  Check the same way:
                  108, 71, 14, 111, 112,
                  If you have a oscilloscope, you should check pins 101,102,103,105 if there is some communication with SPI flash rom.
                  Does the laptop at least charge the battery? Is it indicated with charge LED?
                  • DeniS182
                    • Jun 2014
                    • 328
                    • Slovakia
                    Thanks for answer.
                    ACIN 108 - 0V
                    VR_CPU_PWROK 71 - 0V
                    WRST 14 - 3.3V
                    EC_ON 111 - 3.3V
                    VSTBY0 112 - 3.3V
                    I have analog oscilloscope and there isn't any communication.
                    101 - 3V DC
                    102 - 0V
                    103 - 3V DC
                    105 - 0 V
                    And no charge light when battery + charger is connected, but I don't know if battery is good.
                    • homeless_cz
                      • Oct 2017
                      • 18
                      • Czech rep.
                      Strange.
                      101 must be 0 to chip select, 103 is data output from SPI chip, 105 is clock for SPI chip
                      Is SPI chip OK?
                      Pin 71 is ADP_I from charge controller, shoul not be 0 but analog 0,7 to 2,7V I think depending on charge current.
                      And pin 80 PROCHOT?
                      Is ITE well soldered?
                      Anyway you should check page 53 of schematic. Check all mosfets.
                      • DeniS182
                        • Jun 2014
                        • 328
                        • Slovakia
                        PIN 80 = 0V
                        SPI chip is ok, I read bin from it.
                        I tried resolder ITE chip.
                        All mosfets from site 53 are fine.
                          • 21488
                          Check ITE pin 72 ADAPTER_ID
                          • DeniS182
                            • Jun 2014
                            • 328
                            • Slovakia
                            pin 72 = 0.3V
                              • 21488
                              According to this post on elvikom the voltage should be 0.9V with a 65W or 1.4V with 90W charger .Check the middle pin on the DC-IN jack .
                              https://www.elvikom.pl/lenovo-g50-70...in-t52478.html
                              • DeniS182
                                • Jun 2014
                                • 328
                                • Slovakia
                                I have two 65W chargers and I tried both and value is 0.3V.
                                Middle pin on the DC-IN jack is fine and on it is 0.3V too.
                                • homeless_cz
                                  • Oct 2017
                                  • 18
                                  • Czech rep.
                                  Originally posted by DeniS182
                                  PIN 80 = 0V
                                  That's the problem. PROCHOT# is signal of overheated CPU, overheated voltage regulator and under voltage protection. It can't be 0 for normal work.
                                  Check everything related to PROCHOT# and find what generates 0 and blocks normal work.
                                  On page 47 is nice diagram of power-on sequence.
                                  • piernov
                                    • Jan 2016
                                    • 4437
                                    • France
                                    Missing RSMRST# is more of an issue. Which usually requires the AC adapter identification to work.
                                    EDIT: on HP at least, may be the same on those Lenovo.
                                      • 21488
                                      PROCHOT# comes from PU1208 - RT9553A Datasheet:
                                      Should EC_ADAPTER be the same voltage as ADAPTER_ID_ON# ? Check PQ204
                                      • DeniS182
                                        • Jun 2014
                                        • 328
                                        • Slovakia
                                        PQ204 And PU1208 aren’t on pcb.
                                        • lucaszmn
                                          Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                                          by lucaszmn
                                          Problem:
                                          I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                                          Initial Findings:
                                          • My current BIOS version is N1KET58W (1.45).
                                          • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                                          • I have the ability to use command-line tools on a Linux machine.
                                          Troubleshooting Steps & Conclusions:
                                          • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • s_specialist
                                          Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                          by s_specialist
                                          Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                          07-07-2025, 11:47 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • c.daniel
                                          Lenovo V310-15IKB weird bios problem...
                                          by c.daniel
                                          Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                                          sn LR09493E
                                          MB DAOLV6MB6F0 REV. F
                                          The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                                          Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                                          Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                                          08-22-2025, 05:39 AM
