LCD monitor motherboard not powering up
  • Dergal T Stonkerson
    • 8
    • Ireland
    I have a faulty motherboard controlling G150XG01 LCD monitor. Pictures attached of two separate motherboards. I have being searching online for a schematic of the boards, none of the codes on the boards are giving any results when searching. Is it possible to get schematics for these? Is it possible to repair these surface mount pcb's, what are the common faults?
    Thanks in advance for any help/advise.
  • harp
    • Jun 2022
    • 642
    • Planet Earth
    All motherboard not powering up?
    Have you check power supply? It is common fault to all electronic.
    Have you some port on it that output video signal to external monitor?
    Maybe is screen /backlight problem...
      by momaka
      03-15-2023, 10:17 PM
    • Nagy Daniel
      ASUS TUF Gaming A17 FA707RM-HX038W / Motherboard DANJMMB1AA0 Rev: A // not powering on
      by Nagy Daniel
      I'm new in the world of repair, and I have a laptop that does not turn on.
      I don't know exactly the past of this laptop, I got it in a non-functional state.
      The LDO3 and LDO5 are present, and it provides 3.3 and 5V.
      When I started to diagnose the motherboard, the regulator for the LDO3V and LDO5V was quite hot, I checked it with a thermal camera, and the 3V from the DNBSWON was missing, so I replaced the IC Chip from a donor board (the ic chip is from the same type of motherboard)
      Now, the regulator is fine, it's not heating,...
      03-05-2025, 02:57 AM
    • duraven
      TT 94V-0 E326167 motherboard not powering up
      by duraven
      Hello! Embedded Software Engineer here, for fun trying to investigate a friend's laptop not powering up problem – first time opening a laptop.
      • The physical power button has been broken on the laptop and the friend advised that they needed to poke the area with a pen to get it to start
      • Eventually the pen poking stopped working and now the laptop does not power on at all.
      I have stripped down the laptop down to the motherboard but I cannot simulate the button press or otherwise see anything happening when the power is applied.
      Motherboard model TT 94V-0 E326167 <see image...
      10-28-2023, 03:54 AM
    • glovecaps
      Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
      by glovecaps
      I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
      My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
      The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
      11-25-2024, 04:23 PM
    • starbio7
      Searching for XPS 420 desktop motherboard schematic(s)
      by starbio7
      Am trying to repair my desktop motherboard that suddenly wont boot.
      I noticed that a surface mount capacitor has blown and also there is now a short between +12V rail to GND.
      Any help is appreciated.
      07-14-2025, 02:10 AM
