MacBook Pro A1706 820-00239 no power
  • mon2
    • 14085
    Re: MacBook Pro A1706 820-00239 no power
    Hi. Remove all power -> meter in resistance scale (use the lowest).
    Measure the resistance to ground of both pads of where F7000 resides.
    Post each measurement with pin #1 / pin #2 reference so we can compare against the same schematic.
    BTW - is the multimeter auto-ranging for the resistance or manual adjust?
    That is, if your meter reports 'OL' = over limit so next meter scale must be used.
    If indeed 0 = dead short but suspecting it is some low resistance reading.
    Post your measurement.
    • Xenoaeuriix
      • Dec 2022
      • 36
      • Philippines
      Pin #1 to ground around 17-18K oHms Red probe to the ground
      Pin #1 to ground around 3M oHms Black probe to the ground
      Pin #2 to the ground 000.0 oHms Red probe to the ground
      Pin #2 to the ground 000.0 oHms Black probe to the ground
      Multimeter auto-ranging for the resistance I am using Zotek ZT102
      • Xenoaeuriix
        • Dec 2022
        • 36
        • Philippines
        I am not sure but maybe my multimeter is just too cheap to measure low resistance, I am not sure though.
        • mon2
          • 14085
          Your meter should be ok for the measurement.
          To clarify, leave the meter on the scale you have posted = ohms scale.
          Red probe to pin #1 of the F7000 fuse pad. Black meter probe to ground (metal shield is ok) on the logic board.
          Repeat with pin # 2 of the F7000 fuse pad. Black meter probe to ground.
          do you still read 0 ohms on pin #2 or is it 'OL' as in the posted picture? 'OL' = over limit.
          If you short the meter probes to each other, the resistance should be ~0 ohms. Is that the same reading you are measuring with pin #2 and ground ? That is a hard short circuit if my understanding is correct.
          • Xenoaeuriix
            • Dec 2022
            • 36
            • Philippines
            Thank you I am sending it now.
            • Xenoaeuriix
              • Dec 2022
              • 36
              • Philippines
              #26
              • Xenoaeuriix
                • Dec 2022
                • 36
                • Philippines
                #27
                # It changed form OL to 000.0
                # Yes it is the same reading like I am shorting both probes.
                • Xenoaeuriix
                  • Dec 2022
                  • 36
                  • Philippines
                  #28
                  Here are how it looks on my end.
                  • mon2
                    • 14085
                    Yes, agree with your readings of the resistance on the downstream side of (the removed) F7000 fuse.
                    The macbook logic boards feature a circular adhesive backed dot that is a moisture detector. They will be white, by default, from the factory.
                    Can you locate these dots on the logic board?
                    Are any of them red in color? This will mean that the logic board has had exposure to a liquid spill.
                    PPBUS_G3H travels onto many sites on the logic board. Perhaps the component that is heating up is the CPU / PCH (they are combined in a single package). This component is under a heatsink so can be easily missed if it is indeed heating up.
                    Remove all power -> Check the resistance to ground of:
                    PP1V0_SUS
                    PP1V0_SUSSW
                    PP1V0_S3
                    PP1V0_S0SW
                    Test each of the above anywhere it is convenient on the logic board. A single test measurement for each netname should be ok at this time.
                    These are expected to be low resistance rails but they should not be @ 0 ohms.
                    Post each measurement.
                    • Xenoaeuriix
                      • Dec 2022
                      • 36
                      • Philippines
                      #30
                      PP1V0_SUS
                      PP1V0_SUSSW
                      PP1V0_S3
                      PP1V0_S0SW
                      Thank you, I did find the white dots and none of them turned red. I have not attached the F7000 fuse back to the board yet. Below is the result of the components you had me measure for resistance.
                      PP1V0_SUS = 180.1 oHms
                      PP1V0_SUSSW = 181.5 oHms
                      PP1V0_S3 = 328.2 oHms
                      PP1V0_S0SW = 283.2 oHms
                      • mon2
                        • 14085
                        These are good resistance readings so cpu is likely ok.
                        Do inspect the parts for any odd looking part that may be damaged.
                        When you inject 1 volt (not higher), what is the current draw? It should peak to the 2A since it is a dead short.
                        Can you support higher currents?
                        • Xenoaeuriix
                          • Dec 2022
                          • 36
                          • Philippines
                          #32
                          Current can be set from 0-10A Volts 0-30V how far should I set it to when injecting voltage? Also, are we talking about injecting voltage to PPBUS_G3H? Thank you!
                          PS: It is new year's eve here. Happy new year!!!!
                          • Xenoaeuriix
                            • Dec 2022
                            • 36
                            • Philippines
                            #33
                            I did try to inject voltage 1V 2.4A to ppbus_g3h and found a component that is heating up to the point that I cannot touch too long or it may burn my skin. I did try to find other components cannot find others that is as hot as that component. I am uploading the image now.
                            • mon2
                              • 14085
                              Happy New Year to you and everyone on Badcaps
                              With some travel luck, hope to visit Manila / Cebu in spring. Often I travel to HK during this time for trade fairs but covid is a major nightmare in that region.
                              Have been to Cebu before but did not make it to the waterfall excursion planned by the hotel. The malls in Manila / Cebu are many times better than our local ones. Your (veggie) stir fry is amazing!!
                              1) You do not want to exceed 1 volt - rule of thumb is that stay under the lowest power rail that is on the logic board to be safe. This is to cover the case where the lower voltage rail mosfet may be leaky and can cause damage if you inject a higher voltage.
                              2) Yes, injecting onto PPBUS_G3H. Red probe onto the SMD pad for F7000, pin # 2. This is the side that is showing 0 ohms to ground on your meter.
                              Black probe to any good ground.
                              NO POWER to the logic board - just using this power supply to heat up the shorted part.
                              3) Proceed to raise the current setting but again, voltage @ 1 volt. When you do this, what does your meter show as the current draw during this event. Expecting that the max current value will be reached since this is a hard short with 0 ohms to ground. Respectively, you are intentionally trying to heat up the shorted component with this process. From my experience, if it is a cap, you will smell it and often will crack / split open under this event. Hoping yours is a similar case. Then remove the cracked capacitor.
                              Often the shorted caps are tantalum style which just plain die over time and cause a short circuit condition. For our product designs, we just do not use tantalum caps and have widgets that have been operating 24/7 for over 10 year and still ticking.
                              Curious to know of the current draw as you increase the current setting.
                              As your logic board consumes more current, the shorted part will definitely heat up. Always keep the voltage @ 1V or under to be safe.
                              • Xenoaeuriix
                                • Dec 2022
                                • 36
                                • Philippines
                                #35
                                Here is the component I am talking about.
                                • mon2
                                  • 14085
                                  Ok. That is U9400 and this linked to the nand flash.
                                  Remove all power -> meter in resistance mode.
                                  Measure the resistance to ground @ L9400 which is the switching power supply inductor for this power rail.
                                  What is the reading?
                                  • Xenoaeuriix
                                    • Dec 2022
                                    • 36
                                    • Philippines
                                    #37
                                    Pin# 1 is 11.49K oHms
                                    Pin# 2 is 11.49K oHms
                                    it keeps on moving till it stop on that value.
                                    • Xenoaeuriix
                                      • Dec 2022
                                      • 36
                                      • Philippines
                                      #38
                                      Curious to know the current draw as you increase the current setting.
                                      Oh, that was a surprise! I have never been to Cebu before but I have seen lots of places to go to due to the pandemic traveling does not really an option now you may end up with lots of road block, here in the PH protocols are being strictly implemented in a few more months everything should be back to normal since we are being asked to report back to work in the office. I do love the veggie fries too XD
                                      I am not sure how I can measure the current draw?? Is it something the multi-meter is capable of?
                                      • mon2
                                        • 14085
                                        So the output side of this regulator does not appear to be shorted.
                                        What is the voltage to ground of the EN pin ?
                                        We want to confirm that the regulator is being enabled.
                                        • Xenoaeuriix
                                          • Dec 2022
                                          • 36
                                          • Philippines
                                          #40
                                          You are right I forgot to tell my power supply has lcd display that show the current, it does take the max current the power supply is set to and continually feeding it on that setting heats up the U9400 and I cannot find other components that would heat up or at atleast as hot as U9400.
                                          Sorry I do not know what EN pin is...
                                          Sorry my bad, could it be the pin # 15 of the U9400. If so I am trying to test it now.
                                          I am getting 0V on the EN pin#15 of U9400 I will try to solder back the fuse it could be because of that..
                                          Got the fuse re attached, but same ready 0V on U9400 Pin# 15
                                          I got 0.040V on the EN pin.
                                          • Cemal Odabasioglu
                                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                            by Cemal Odabasioglu
                                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                            Observations...
                                            01-14-2025, 03:54 PM
                                          • Danielreinaa
                                            HELP need password bios Macbook A1706
                                            by Danielreinaa
                                            Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                            Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                            Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                            gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                            Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                            09-07-2024, 03:47 PM
                                          • capon5153
                                            Macbook A1706 works perfectly but no data on USB C
                                            by capon5153
                                            hello,
                                            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                            06-22-2025, 09:42 AM
                                          • dbuergi
                                            MacBook A2141 one USB port dead and one power cycling
                                            by dbuergi
                                            I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
                                            Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
                                            04-25-2025, 11:40 AM
                                          • B2L_Repairs
                                            Macbook A1706 touchpad and keyboard not working. Please help
                                            by B2L_Repairs
                                            Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                            10-09-2023, 04:56 AM
