my vertyanov jig wont work, Lenovo NM-273
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3596
    • slovakia
    Hello.
    I have problem with my Vertyanov JIG v3.3 that wont work.
    I test it with NM-273 which works correctly. connection test with JIG works ok, but when i connect board JIG cannot check connection with board
    Im using SW from this site, but windows tells me it is Trojan in it. I dont care so i turn defender off, but still no connection to IT8586E. Board is powered, GND cable is connected.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3596
    • slovakia
    Re: my vertyanov jig wont work, Lenovo NM-273
    this piece of sh.. freaks me out.
    i managet to get it to work. read from nm-A273, write to nm-A361 and when i try to flash nm-A273 nothing work again. same setup same everything and this crap still wont connect
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3596
      • slovakia
      how to get it to work normaly. not 1of20 times?
      • Djosla
        • Dec 2012
        • 246
        • Montenegro
        Hello KTM.
        Check all connections and also check for power supply for kbc +3valw. Sometimes you just need to press the power buton once prior preograming to get it to work. I know it sounds nonsence but try it.
        Option 2 is to remove PR337 and connect the PU904 jumper contacts to get that 3v.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3596
          • slovakia
          Originally posted by Djosla
          Hello KTM.
          i have all ALW power but this piece of sh.. connects 1 of 20 times
            • 20942
            Pin 11 must be powered as well
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3596
              • slovakia
              thats ok but why it work 1 of 20 times on same boards?
                • 20942
                Most of the problems aren`t with the programmers.Use a very short gnd cable and check the KB connector closely ,is it 0.8MM or 1MM ,sometimes its hard to tell. This model can have a problem if the bootloader gets corrupt.To solve it GPG2 has to be pulled high for the mirror function to work,see page 44 in the schematic ,after you moved the resistor attach the charger it will pull code from the EC in the bios but not all of it, then unplug charger,move resistor,attach JIG and then you should be able to program it fully.EDIT: not all chips support that mirror function.
                • resistor83
                  lenovo 330s-15ikb, led num lock key always on and numbers don't work
                  by resistor83
                  hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                  I tried updating the bios but the problem remains
                  https://s...
                  05-29-2025, 08:06 AM
                • dhs6512
                  Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
                  by dhs6512
                  Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
                  Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
                  Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
                  When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
                  Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
                  When connecting...
                  10-29-2024, 11:04 AM
                • Lcd22
                  Lenovo s145-15api work fine after bios flash for some time, like a few restarts or power cycles.
                  by Lcd22
                  Hi! I have a Lenovo s145-15api Ryzen 5 3500u, he need a bios reflash, i made that (tried with ch341a and ezp2023+). I tried a lot of dumps, and all do the same, so i think is a hardware problem. So after reflash, laptop work fine a short time, after some restart or power on/off, the laptop have again same symptoms, need a new bios. Do it again and again and same result. What are u think is the problem?
                  08-28-2024, 10:38 AM
                  Lenovo 3000 Series Schematic
                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                  3000 C100 laptop with Braille keyboard
                  Lenovo 3000 C
                  C100, C200 - 15-inch XGA screen
                  Lenovo 3000 N
                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                  N500 - 15.4 inch screen.
                  Lenovo 3000 V
                  V100, V200 - 12.1-inch WXGA models
                  Lenovo 3000 G
                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                  10-04-2024, 06:05 AM
                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                  09-06-2024, 06:40 AM
