HP 250G4 la-c701p constantly switching between battery and AC power
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    I have an issue with HP 250 G4.
    When AC adapter is plugged in - the laptop works just fine
    When I plug a battery, which a friend claimed that he recycled - replaced the cells inside it with new, the laptop works with the battery just fine.
    When I connect the charger, the laptop charges the battery, but in about 1-2 minute intervals switches between AC and battery. Nonetheless, charges the battery.
    The board is la-c701p v1.0. I found that the charge IC supports LEARN function(by command from the SMBus controller), which more or less is similar to the behaviour experienced by me.
    If it works with battery, works with AC charger, then the MOSFETS should be fine. I found no issues with them, nonetheless.
    Could this be a problem, caused by the battery? Because he replaced 18650 cells, but did not reset the battery controller. Or this must be issue with the charge/power IC?
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Re: HP 250G4 la-c701p constantly switching between battery and AC power
    Measured all mosfets. Everything with them is fine.
    On the G there are about 22V(my multimeter is not true RMS)
    Measured all ceramic capacitors between the AC in and Battery.
    Periodically voltages on the G of the two mosfets AC and RB just disappear fully and the system switches to battery. Then they appear again and the charge continues.
    There is neither charger OV or BAT OV. I don't understand why it periodically switches between AC+charging and battery only when the battery is present and the power led switches from white to red and vice versa.
    It switches between
    AC FET and RBFET - G - 22V - Charging and powering the system from AC.
    And
    AC FET and RBFET - G 0V, BATFET - 22V, powering the system from Battery.
    If some failure mode/protection is activated, I cant find the reason.
    The system works normally both when only on AC power or Battery.
    The only thing I can think of is some kind of issue with the recycled battery, although the battery seems to be just fine.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Try with another known good battery first before proceeding to diagnosis. Too me, it seems battery issue.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
      • trepachka
        iPad Air A1475 Boot loops after replacing battery
        by trepachka
        This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
        The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
        I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
        11-08-2024, 03:17 PM
