6050A2560201-MB-A03 Won't turn on.
  • maurovalero
    • Sep 2018
    • 69
    • colombia
    Hi, working on this Hp EliteBook 840 MB 6050A2560201-MB-A02. The problem with it is that the Power white LED turns on for a while & then turns off by itself. The amps during this 4 sec process is just 0.06 & then back to 0 but battery charges very well taking around 2.7amp in the start. I re-programmed the BIOS chip which I got from this board's string on BADCAPs but no difference. 3.3v & 5v are perfect. No short to ground at all on any rails. Can someone help me diagnosing this fault further. Thanks in advance.
    ADP_EN 3,38
    LID_SW# 3,29
    ADP_DET 3,3
    RSMRST# 3,3
    KBC_PWR_ON_R 3,3
    this are the values in EC U300
  • electrocute
    • Mar 2021
    • 23
    • spain
    Re: 6050A2560201-MB-A03 Won't turn on.
    Any led blinking code sequence on caps lock key or the power led?
    • mon2
      • Dec 2019
      • 14681
      Check for damaged / shorted mosfets on page # 5 of the posted schematic.
      1) With the adapter connected & battery removed, what is the voltage reading:
      @ Q6009 - pin 3 ?
      Q6010 - Source (pin 1-2-3) ?
      Q6010 - Drain (pin 8-7-6-5) ?
      Q6011 - Drain (pin 8-7-6-5) ?
      2) Remove all power.
      Meter in resistance mode.
      Check & post the resistance for the following:
      Q6010
      Source & Drain
      Source & GATE
      GATE & Drain
      Repeat the measurements for:
      Q6011, Q6000, Q6001
      On the topic of resistance measurements, be sure to review the following excellent webpage - see resistance chart:
      http://electronicsbeliever.com/how-t...-is-defective/
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Did you check your RTC section?
        • maurovalero
          • Sep 2018
          • 69
          • colombia
          no secuence, but wifi led and mute is on during 5 seconds and them turn off.
          • maurovalero
            • Sep 2018
            • 69
            • colombia
            @ Q6009 - pin 3 ?
            Q6010
            Source & Drain
            Source & GATE
            GATE & Drain
            Q6011, Q6000, Q6001
            Q6010 Q6011
            D 19 D 19
            G 6 G 19
            S 19 S 25
            I'M sure that problem isnt in 19v line, any other idea?
            • maurovalero
              • Sep 2018
              • 69
              • colombia
              i hope your help
              • mon2
                • Dec 2019
                • 14681
                These readings do not look correct:
                Q6010 Q6011
                D 19 D 19
                G 6 G 19
                S 19 S 25
                Can you double check the values and post them again?
                The drain voltage of Q6010 should be the same at source of Q6011.
                Also interested in the voltages on Q6012, Q6000, Q6001.
                Then remove all power and share the resistance of each mosfet.
                Source & Drain
                Source & gate
                Gate & Drain
                • maurovalero
                  • Sep 2018
                  • 69
                  • colombia
                  Q6010 Q6011
                  D 19 D 19
                  G 6 G 19
                  S 19 S 25
                  Source & Drain
                  Source & gate
                  Gate & Drain
                  add picture with medicion, i found a coil near to pad6015, but is open, the problem is in 1 side have 19v and other gnd with 0.002om.
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
                  • dqtech
                    lenovo x240 nm-a091 wont turn on
                    by dqtech
                    i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                    board number VIUX1 NM-A091 REV:1.0...
                    02-07-2024, 01:57 AM
