Water Damege 820 - 01958A no Power on
  • macrepair
    • Dec 2017
    • 21
    • germany
    Hi
    I have a Problem with a Macbook Air 13 2020. It has Waterdamage. If i plug the USB C, it not starting and no boot. It do nothing. Only the T2 IC and U7800 is warm. Can you pls help me. There is no PP5V_G3S and PP3V_G3S. There is PP3V3_G3H = 3,2V but P3V3MAIN_PGOOD is missing. Is that normal ?
    I measered the Power Rail:
    PPBUS_G3H = 12,3V
    PPBUS_HS_CPU = 12,3V
    PPDCIN_G3H = 20,3V
    PP5V_G3S = 0V
    PP5V_S5_LDO = 0V
    PPVIN_G3H_P5VG3S = 12,4V
    PPVIN_G3H_P3V3G3H = 12,4V
    PPVIN_G3H_P3V3G3HRTC = 12,3V
    PP3V3_G3H_PMU_VDDMAIN = 3,2V
    PP3V3_G3S_WLANBT = 0V
    PP1SR3V3_G3H_P0V6_S3_VIN = 3,2V
    PPBUS_G3H_SSD0 = 12,3V
    PPBUS_G3H = 12,3V
    PPVIN_G3H_P1V1_S3 = 12,38V
    PP3V3_G3H_RTC = 3,3V
    PP3V3_G3H = 3,2V
    PP3V3_G3SSW_SNS = 0V
    PP3V3_G3S = 0V
    PPBUS_G3H_SPKRL = 12,3V
    PPVCC_NAND_SSD0 = 0V
    PP1V8_G3S = 0V
    PPVCC_S0_CPU = 0V
    PPVCCIN_AUX_PCH
    PP1V8_PRIM_PCH
    PP1V1_S3
    PP0V6_S3
    PPVDDCPU_AWAKE = 0,76V
    PPVDDCPUSRAM_AWAKE = 0,8V
    PP0V82_SLPDDR = 0,8V
    PP1V8_SLPS2R = 1,8V
    PP1V8_AWAKE = 1,8V
    PP1V8_S3 = 0V
    PP1V8SW_VCCQIO_SSD0 = 0V
    PP1V1_SLPS2R = 1,1V
    PP1V1_SLPDDR = 1,1V
    PP0V9_SLPDDR = 0,9V
    PPVNN_PCH_EXT_REG = 0V
    PP1V05_PCH_EXT_REG = 0V
    PP1V05_PCH_VCCPRIM
    PP1V05_PCH_CPU
    PP0V9_SSD0 = 0V
    PPVCCQ_ANI_SSD0
    PP0V8_SLPS2R = 0,8V
    PP3V_G3H = 3,0V
    PP1V2_AWAKE = 1,2V
    PP3V3_AWAKE = 3,24V
    PP3V3_S5 = 0V
  • mon2
    • Dec 2019
    • 14215
    Re: Water Damege 820 - 01958A no Power on
    P5V_G3S = 0V
    Check and post the voltage reading of P5VG3S_EN_DLY
    The P5VG3S_EN_DLY signal is driven by U7610. Investigate that this circuit is operating correcting by reviewing the INPUT to U7610 (pin # 1).
    Be sure that R7613 is still present.
    U7610 single gate IC is being powered via pin # 5 ?
    Post your readings.
    • macrepair
      • Dec 2017
      • 21
      • germany
      Post your readings.
      Thanks for the help. But now I have a bigger problem. The PP3V3_G3H is also no longer there.
      I removed the mosfet Q7680. After that I measured the pins
      https://ibb.co/17RcpLq
      • mon2
        • Dec 2019
        • 14215
        Remove all power.
        Meter in resistance mode.
        Check the resistance to ground on the inductor L7690.
        Value ?
        • macrepair
          • Dec 2017
          • 21
          • germany
          Remove all power.
          Value ?
          What do you mean with "all Power"
          • mon2
            • Dec 2019
            • 14215
            No adapter.
            No battery.
            Then take the resistance measurements.
              20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
              by sam_sam_sam
              I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
              At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
              Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
              04-09-2023, 08:04 PM
            • edugimeno
              Stagg sms12p audio amp has water damage
              by edugimeno
              Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
              I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
              There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
              There is only one signal wire connecting the first boards...
              05-24-2025, 06:00 AM
            • RetroComputingGrotto
              Water Damaged Toshiba 48L1435DB
              by RetroComputingGrotto
              I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
              The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
              10-07-2024, 08:23 AM
            • rzsn
              water damaged G513I
              by rzsn
              Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
              Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
              12-22-2024, 09:02 PM
            • abajor
              A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
              by abajor
              Like title says A2141 came in with Water Damage, customer desperately wants the data.
              The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
              I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
              That said after cleaning up the...
              12-21-2024, 07:16 PM
