Water Damege 820 - 01958A no Power on
  • macrepair
    • Dec 2017
    • 21
    • germany
    Hi
    I have a Problem with a Macbook Air 13 2020. It has Waterdamage. If i plug the USB C, it not starting and no boot. It do nothing. Only the T2 IC and U7800 is warm. Can you pls help me. There is no PP5V_G3S and PP3V_G3S. There is PP3V3_G3H = 3,2V but P3V3MAIN_PGOOD is missing. Is that normal ?
    I measered the Power Rail:
    PPBUS_G3H = 12,3V
    PPBUS_HS_CPU = 12,3V
    PPDCIN_G3H = 20,3V
    PP5V_G3S = 0V
    PP5V_S5_LDO = 0V
    PPVIN_G3H_P5VG3S = 12,4V
    PPVIN_G3H_P3V3G3H = 12,4V
    PPVIN_G3H_P3V3G3HRTC = 12,3V
    PP3V3_G3H_PMU_VDDMAIN = 3,2V
    PP3V3_G3S_WLANBT = 0V
    PP1SR3V3_G3H_P0V6_S3_VIN = 3,2V
    PPBUS_G3H_SSD0 = 12,3V
    PPBUS_G3H = 12,3V
    PPVIN_G3H_P1V1_S3 = 12,38V
    PP3V3_G3H_RTC = 3,3V
    PP3V3_G3H = 3,2V
    PP3V3_G3SSW_SNS = 0V
    PP3V3_G3S = 0V
    PPBUS_G3H_SPKRL = 12,3V
    PPVCC_NAND_SSD0 = 0V
    PP1V8_G3S = 0V
    PPVCC_S0_CPU = 0V
    PPVCCIN_AUX_PCH
    PP1V8_PRIM_PCH
    PP1V1_S3
    PP0V6_S3
    PPVDDCPU_AWAKE = 0,76V
    PPVDDCPUSRAM_AWAKE = 0,8V
    PP0V82_SLPDDR = 0,8V
    PP1V8_SLPS2R = 1,8V
    PP1V8_AWAKE = 1,8V
    PP1V8_S3 = 0V
    PP1V8SW_VCCQIO_SSD0 = 0V
    PP1V1_SLPS2R = 1,1V
    PP1V1_SLPDDR = 1,1V
    PP0V9_SLPDDR = 0,9V
    PPVNN_PCH_EXT_REG = 0V
    PP1V05_PCH_EXT_REG = 0V
    PP1V05_PCH_VCCPRIM
    PP1V05_PCH_CPU
    PP0V9_SSD0 = 0V
    PPVCCQ_ANI_SSD0
    PP0V8_SLPS2R = 0,8V
    PP3V_G3H = 3,0V
    PP1V2_AWAKE = 1,2V
    PP3V3_AWAKE = 3,24V
    PP3V3_S5 = 0V
  • mon2
    • Dec 2019
    • 14675
    Re: Water Damege 820 - 01958A no Power on
    P5V_G3S = 0V
    Check and post the voltage reading of P5VG3S_EN_DLY
    The P5VG3S_EN_DLY signal is driven by U7610. Investigate that this circuit is operating correcting by reviewing the INPUT to U7610 (pin # 1).
    Be sure that R7613 is still present.
    U7610 single gate IC is being powered via pin # 5 ?
    Post your readings.
    • macrepair
      • Dec 2017
      • 21
      • germany
      Post your readings.
      Thanks for the help. But now I have a bigger problem. The PP3V3_G3H is also no longer there.
      I removed the mosfet Q7680. After that I measured the pins
      https://ibb.co/17RcpLq
      • mon2
        • Dec 2019
        • 14675
        Remove all power.
        Meter in resistance mode.
        Check the resistance to ground on the inductor L7690.
        Value ?
        • macrepair
          • Dec 2017
          • 21
          • germany
          Remove all power.
          Value ?
          What do you mean with "all Power"
          • mon2
            • Dec 2019
            • 14675
            No adapter.
            No battery.
            Then take the resistance measurements.
              20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
              by sam_sam_sam
              I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
              At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
              Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
              04-09-2023, 08:04 PM
            • Ugur87
              MacBook Air M4 A3240 Brand New Water Damage no Image
              by Ugur87
              I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
              08-28-2025, 01:09 PM
            • edugimeno
              Stagg sms12p audio amp has water damage
              by edugimeno
              Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
              I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
              There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
              There is only one signal wire connecting the first boards...
              05-24-2025, 06:00 AM
            • RetroComputingGrotto
              Water Damaged Toshiba 48L1435DB
              by RetroComputingGrotto
              I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
              The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
              10-07-2024, 08:23 AM
            • x_orange90_x
              Samsung UN65AU8000FF fried by water
              by x_orange90_x
              I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
              10-16-2025, 08:40 PM
