Lenovo Thinkpad W530 CPU VCORE STRANGE ISSUE
  • rayliu11
    • May 2017
    • 7
    Would love some advice from the true professionals on this thread!
    I have a W530 Thinkpad which has a puzzling issue that I've spent the week troubleshooting.
    The laptop would refuse to start up unless the board was slightly pressed down in a certain area. I spent a very long time trying to pinpoint where to push on the board and pushed on various components to see if it was a contact issue. The location couldn't really be isolated.
    When it refused to start, CPU VCORE would not come on. The Discrete GPU VCORE Power Good comes up along with the PCH Power Good as well. On the CPU DC-DC Converter, the Enable signal is pulled high as well. The signals would come up for a second or two before the board shuts down when VCORE doesn't come on. If parts of the board are pressed from certain angles, then VCORE comes on and the whole board powers up. It has been near impossible to pin point which component is making bad contact.
    Schematics are attached.
    [MOD EDIT] Link to schematic https://www.badcaps.net/forum/troubl...-thinkpad-w530
  • FrozenHaxor
    • Jun 2015
    • 266
    • Poland
    Re: Lenovo Thinkpad W530 CPU VCORE STRANGE ISSUE
    I've replaced several ThinkPad boards with directly soldered BGA CPUs due to failed connection between the CPU and the board since they use a tragic epoxy-like underfill that makes it impossible to reball, and those thin CPUs are a challenge to reball as is, their asymetric construction makes them prone to warping during the process. I consider attempting such repairs a waste of time and just replace the entire board if possible.
    Often when you try to desolder those CPUs with 100% underfill in the BGA layer you will either rip parts of the board off, rip pads off or rip traces off. They never came off cleanly for me, something always gets damaged.
    • rayliu11
      • May 2017
      • 7
      This board has a socketed CPU so I'm not sure how a BGA failure would occur. I have tried multiple CPUs with the same symptoms.
      The board also has a K1000M GPU. Could a failure on the GPU cause it to not have VCORE and shut down like this?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Yes GPU failure can cause this symptom. Try mildly heating the gpu(Dont overheat to kill it) and see if it makes the difference.
        • FrozenHaxor
          • Jun 2015
          • 266
          • Poland
          Definitely, those BGAs pose same problems on those boards as CPUs, does yours have black underfill under the GPU?
          • rayliu11
            • May 2017
            • 7
            It does not seem to make a difference when heating the GPU. The past day, I actually managed to use the schematics to disable the GPU. I have removed the inductors that provide GPU Vcore and the GPU no longer heats up on boot. However; the symptoms are still the same, requiring parts of the board to be bent for it to boot up on the integrated graphics.
            • FrozenHaxor
              • Jun 2015
              • 266
              • Poland
              Do you have access to freeze spray? Sometimes it can pinpoint fault point really good as it causes rapid dimension changes of materials from temperature difference. I often use it.
              • Soulzink
                Samsug washing machine. Power supply DC41-00189a board issue
                by Soulzink
                I am trying to fix a samsung washinmachine power supply main board.
                I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                The power supply board reference is the following: DC41-00189a
                I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                04-19-2025, 06:26 AM
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • Stephen
                A2991 Logic Board issue, 20volts 0 amps help!
                by Stephen
                Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                09-10-2025, 03:16 PM
              • Stephen
                A2991 logic board issue, 20volts 0 amps help!
                by Stephen
                09-10-2025, 03:15 PM
              • notallbad
                TCL 55RP620K power board issue
                by notallbad
                Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                0% p_dim at 1.65v and a_dim at 1v
                50% p_dim at 3.3v and a_dim at 1.65v
                100% p_dim at 3.3v and a_dim at 2.88v
                Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                Leds are 2 rows of 15 6v leds.
                On inspection of the power board found diode MBR3200 shorted so replaced with...
                07-12-2025, 05:45 AM
