How can I program a IT8225VG-128?
  • liquidzorch
    • Oct 2016
    • 135
    • mexico
    Hello. I opened a new thread since the last one was getting off topic. I need to swap an IT8225VG-128 EC chip from a razor laptop rz09-0329, since I have charging issues and WIFI issues. I can only find the chip on ebay and aliexpress but without firmware. Since this is a bga, I dont know how the EC programming needs to be done, plus, I can´t find an EC dump. I have the EC update file, where I extracted a 256 byte BIN file, but I am guessing that is not the same as a full dump.
    Any help as to what programmer it needs and where I can find the dump would be helpful.
    Thanks in advance.
    • 21102
    Re: How can I program a IT8225VG-128?
    Post the full laptop model number
    • khaahk
      • Dec 2013
      • 781
      • Estonia
      You mean 256kB not bytes? That is most likely ec full dump. For programming you need Vertyanov or RT809 or SVOD programmer. If swapping bga then you can find the needed testpoints after you have removed the ec. Find a mainboard with the same ec which has schematic/boardview.
      • liquidzorch
        • Oct 2016
        • 135
        • mexico
        Sorry. I hadn't seen the full number: rz09-03295E63
          • 21102
          Ok so its a blade pro 2020 model.
          Support page https://mysupport.razer.com/app/answ...tail/a_id/3686
          EC update - https://rzr.to/BAUxE .If you can boot into windows just run the updater. If you can`t look around the board for another ITE chip, some boards have dual chips, maybe a IT8390VG-256 .I`m sure the IT8225VG-128 is 128KB
          • liquidzorch
            • Oct 2016
            • 135
            • mexico
            Thanks. That EC update is what I have downloaded, but it won't let me install the update, it just says the EC is already on that version. (I haven't bought the new EC chip yet if that's what you meant).
            The EC bin file extracted from that update is 256 bytes, not kb. Thas't why I think its not the full bin, but maybe I am mistaken.
            I can't find any info on how I would flash a new EC chip. I want to replace this one since the laptop has various issues that others on this forum think could be the EC chip at fault.
            • liquidzorch
              • Oct 2016
              • 135
              • mexico
              Sorry, I was looking at the wrong file. The EC bin I extracted from this update is actually 256kb. The 128 byte file was extracted from rw everything (which I can see doesnt give me access to the full ec).
              • asustuf
                • Feb 2023
                • 18
                • Austria
                Hello, found this topic and it describes also my problem.
                I replaced the IT8225VG-128/CX chip from Asus mainboard G531GW rev 1.6 with a brand new, blank one.
                Now laptop does not start nor gives any signs of life (status LEDs etc.). I still have the lifted orginal chip.
                How to read flash from the old and write it to the new BGA chip?
                • asustuf
                  • Feb 2023
                  • 18
                  • Austria
                  I found some answers on youtube. Can someone who has SVOD ver4 check in the newest software(0.0.3.8) if IT8225VG-128/CX is supported?
                  • orientalsniper
                    • Apr 2013
                    • 459
                    What's the cheapest KBC programmer with full support for all chips?
                    • reformatt
                      • Feb 2020
                      • 1416
                      SVOD team have released an adaptor for 128 pin BGA EC's. Available from their store. 120 Euro so not exactly cheap.
                      https://shop.svod-project.com/index....&product_id=65
                      • charafmak77
                        • Oct 2017
                        • 81
                        • jijel
                        • grimacelord
                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                          by grimacelord
                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                          Motherboard model number: DA0PAMB46A1 REV: A
                          Secondary motherboard model number: 0PAB
                          SKU: 685K4UA
                          Serial number is: 5CD3223BJP
                          Recently reflashed this laptop with latest BIOS and once...
                          05-07-2024, 08:06 AM
                        • korsar86
                          ASUS X512FF Rev 3.1 Help to find the KBC dump
                          by korsar86
                          Asus X512FF (X512FLC) REV 3.1
                          Help to find the KBC dump for this model.
                          The laptop works. but there is a problem, after power off it no longer responds to the power button, that is, you have to reset the battery and it turns on again (autostart).
                          There is also no keyboard backlight and the touchpad does not work.
                          The multicontroller is responsible for controlling these functions. Before I replace it, I would like to flash it first. thank you
                          Attached is a picture of the sticker and the native dump....
                          11-06-2024, 02:47 AM
                        • YasaCh
                          Help me my brothers find a dump for SONY KDL-55W805B TV
                          by YasaCh
                          Peace be upon you.
                          Brothers, I need a dump for a Sony LCD smart TV.
                          Screen type and model: SONY KDL-55W805B.
                          Please provide a dump for the device.
                          The device boots up but the SONY logo doesn't appear at first and remains in this state.
                          04-17-2025, 11:16 AM
                        • AWENA
                          How to find build id in dell bios dump ?
                          by AWENA
                          Hello everyone, can anyone tell me how to find the "build id" through the HEX editor?
                          I unpacked the .exe bios from the official Dell support site (using Dell Extract) and have two updates: Model=07A1 and 07CC. How can I find "07A1" or "07CC" in the bios dump using a HEX editor?
                          Unfortunately, I can't find it. There are no such inscriptions on the motherboard either....
                          05-08-2023, 01:50 AM
                        • magneh
                          Sango J1900 - POS - corrupted bios but unable to find dump
                          by magneh
                          Hi all!
                          long shot but lets see
                          POS device, with a what I suspect a corrupted bios.
                          All power rails are up and running, but not POST.
                          On Sango site cant find any bios file.
                          Contacted them by mail and asked for it, but not sure they will even reply
                          Model: Sango J1900
                          Board: SANGO-MB-J1900
                          SN:RC18110135
                          Would someone be able to take a look at this backup dump and check if something can be done ?
                          Thanks for any help
                          Apreciate it
                          Cheers...
                          03-01-2024, 09:56 AM
