Hannspree Hanspad screen flickering
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    On my tablet recently screen has start to flicker...
    I noticed that the battery is quite worn out.
    So is this repairable,what could cause such issue?
    It's a no name brand tablet and finding parts in my country is impossible.
    So anything can be done,or just throw in garbage now for what I would feel sad because it's a 12 " tablet.
    Now the picture is black all the time and I don't even see the picture on it.
    https://www.youtube.com/watch?v=Qzjrz0E19v8
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: screen flickering on tablet
    Can be a bad battery , or bad connection on the screen.
    If you power it up with PSU you have the same problem?
    • mon2
      • 14664
      Can you see the display graphics if you shine your phone flashlight on the front / sides of the LCD? Try the flashlight at all angles to emulate the possible failed backlight.
      • paparazzo79
        • Dec 2018
        • 303
        • Bosnia
        Yes.
        Well the battery is bad I know that for sure,it lasted only 2 h and when it gets to around 60 % of capacity tablet becomes slugish,when at 15 % it rapidly decreases capacity and shuts down.
        I did get exclamation warning over battery sign most of the times when I wanted to charge the tablet.
        So can be the bad battery?
        In that case I can only throw it in garbage.
        But I can not use it with external power bank battery via usb port.
        Mon2,
        yes i can.
        I have a person who repairs the laptops and he told me that possible issue is ribbon/flat cable to the screen is gone...can it be that?
        In that case,can anyone repair that,or needs new flat/display cable?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Re: Hannspree Hanspad screen flickering
          Change battery first, in these cheap devices the battery also acts like a filter capacitor and this may be your only issue.
          A working TV? How boring!
          • paparazzo79
            • Dec 2018
            • 303
            • Bosnia
            Any chance of repair this,guys?
            Usually,what could cause this?
            Could it be bad battery?
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              I would suspect a partially damaged/dirty signal cable. That video shows a rolling picture not a flickering backlight.
                • 21889
                Your accounts have been merged,as have your 2 seperate threads on the same topic.
                • paparazzo79
                  • Dec 2018
                  • 303
                  • Bosnia
                  Possible to repair or throw tablet to garbage,sadly?
                  • paparazzo79
                    • Dec 2018
                    • 303
                    • Bosnia
                    It's all black from few days ago.
                    I can only see backlight with blank screen.
                    I have a guy who repairs laptop but here in Bosnia it's impossible to get parts for any laptop,tablet,cellphone,not to mention this is no name tablet.
                    So you think even if it's ribbon screen cable,I assume it's not repairable?
                    I suspect it's the battery issue.
                    • paparazzo79
                      • Dec 2018
                      • 303
                      • Bosnia
                      Here is what I did,
                      now I'm getting that exclamation battery warning sign when connecting the charger.
                      Then I thought let me connect the external power bank over it's micro USB port and check to see what will happen.
                      And tablet started to charge over micro USB via external powerbank,I let it over night and it charged to 52 %...what is happening?
                      Charging circuit faulty?Battery faulty?
                      Now tablet works normally.
                      I let it charge over it's adapter now to like 80 %.
                      • cashkennedy
                        Onn tablet screen
                        by cashkennedy
                        An ebay seller shipped me this broken tablet by mistake, and so I got my money back, but there are a decent amount of these seemingly in perfect shape but with screen issues (this tablet was clearly a return that had never been used or setup, so I don't think any physical damage occurred, also is a kids model so large bumpers on cover that isn't in picture) Is this a loose lvds cable or anything repairable beyond replacing the screen which would come with its own integrated tcon which is maybe where the problem would be?
                        The power on screens just exhibit the sideways smear, once...
                        07-14-2025, 06:12 PM
                      • Ado02
                        Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                        by Ado02
                        We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                        The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                        12-16-2024, 02:33 PM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • survivalbloke
                        HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                        by survivalbloke
                        SN: 8CG0213H8W
                        ProdID 3C311UA
                        This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                        05-08-2025, 12:21 PM
