A2159 No Backlight just 12V not 46V
  • Strolch
    • Nov 2017
    • 244
    • Deutschland
    I inserted a board from the A2159 into a Mac A2189 and connected the display. Before I did that, the MACBook A2159 worked perfectly. Now there is no more picture! I have no more 46V on the C84 ..... only 12V. I read you should be careful about the video board. Unfortunately too late! Is the U8400 now defective or what can be defective? Thank you for the help.
  • mon2
    • 14401
    Re: A2159 No Backlight just 12V not 46V
    Not in front of my schematic database but does the lcd work?
    Shine a flashlight in front of the screen while it is on. Can you the desktop icons, graphics?
    • Strolch
      • Nov 2017
      • 244
      • Deutschland
      hi, no its dark. i have just 12Volts at the Capacitor line C84.... not 46V
      • mon2
        • 14401
        1) C84 ? Confirm the full cap # - unable to find this capacitor.
        2) Voltage on F8400, pin # 2 ?
        3) voltage of PP5V_S0SW_LCD ?
        4) voltage of PPVOUT_S0_LCDBKLT ?
        • Strolch
          • Nov 2017
          • 244
          • Deutschland
          C8460, C8461, C8462... I will look. THX
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • DanPoka
            by DanPoka
            02-15-2025, 05:05 AM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
          • m_12adel
            A2159 Touch bar No backlight
            by m_12adel
            I have MacBook Pro A2159 EMC 3301 board 820-01598 that Touch bar is working but with No Backlight, I replaced it with a new one , have the same issue
            Checked both connecters J5110 , J5100 from board side and from Touchbar side , it have no issue
            so if anyone know how to make sure backlight voltage is exist , and which pin?
            09-20-2022, 04:33 AM
          • canadaboy25
            LG Flatron 24EN33TA No Backlight When Cold
            by canadaboy25
            I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
            I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
            03-07-2023, 12:23 AM
