A2159 Touch bar No backlight
  • m_12adel
    • 12
    I have MacBook Pro A2159 EMC 3301 board 820-01598 that Touch bar is working but with No Backlight, I replaced it with a new one , have the same issue
    Checked both connecters J5110 , J5100 from board side and from Touchbar side , it have no issue
    so if anyone know how to make sure backlight voltage is exist , and which pin?
  • mon2
    • 14679
    Re: A2159 Touch bar No backlight
    From a review of the signal names, this is a single lane MIPI DSI design.
    So you have your
    MIPI DATA_P/DATA_N lanes - the pair = single lane design
    MIPI CLK_P/CLK_N lanes - always required on every MIPI design
    The above are used to configure and stream out the display data.
    Since you can see the display data - the above MIPI lines are ok.
    Backlight will be a power rail also present on the same connector.
    Check PP3V3_G3HSW_DFR on J5110 and post the voltage measurement. This voltage rail is passing through a load switch @ U5111. This load switch is enabled through pin # 1.
    Do also check if the load switch is being enabled or not.
    • m_12adel
      • 12
      PP3V3_G3HSW_DFR on J5110 pin 18,20,22 is 3.3V
      I couldn't check Voltage on U5111 but R5110 is 7.5kΩ
      side question: can I power on board outside frame without power button?
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • trepachka
        Converting HP EliteBook 840 G7 non-touch to touch if possible
        by trepachka
        I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
        The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
        I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
        04-27-2024, 11:15 PM
      • r1kku
        A2159 Touch Bar sensor is not working.
        by r1kku
        Hello, I have an MacBook Pro 2019 A2159 but the Touch Bar touchscreen is not working.
        I disassembled the laptop and I saw that L5100 is burned, I removed it and I connected that rail and it seems to be working. It's a problem if I leave it like this? Or I need to install a new inductor?
        06-07-2024, 09:04 AM
      • Prott
        Surface Pro 4/5 - no touch after LCD change
        by Prott
        I have a question that's driving me a bit nuts recently.
        Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
        - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
        - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
        01-25-2023, 12:42 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
