Help with HP DA0P5DMB8C0 IC component identification
  • robante15
    • Nov 2020
    • 58
    • El Salvador
    Laptop: HP 15-dy1074nr
    Motherboard: DA0P5DMB8C0 REV:C
    IC marking: 5V=6J K0H
    I can't seem to find schematic for this motherboard.
    From now, thank you for you help
    The problem with this Laptop is that it does not detect the charger, in ACDET I have only 2V, and in the power supply I have a consumption of 0.000A
  • Anirudhvl
    • Feb 2018
    • 25
    • India
    Re: Help with HP IC component identification
    usually acdet circuit have a voltage divider connected to dc in (19.5) and ground. Chcek the resistors.
    • R_J
      • 9559
      No schematc, but the IC is a Richtek RT3612EB
      • Sephir0th
        • Oct 2020
        • 1283
        Are you looking for the Charging Controller? This Richtek isn't it. Common Brands are Texas Instruments and Intersil/Reneseas
        FairRepair on YouTube
        • ktmmotocross
          Acer 515-54G badly burned Main power -After repair ACDET is pulled to GND when apply
          by ktmmotocross
          Acer 515-54G
          DA0ZAWMB8G0
          Board have badly burned Main power and second mosfet After repair ACDET is pulled to GND when apply power
          i dont uderstand this. Charger ic BQ24780S
          ACDET 6pin have voltage devider set to R1 110Kohm and R2 20Kohm. pin ACDET have 20K to GND. But when apply power R1 have 19V on one side and 2.3ohm on other side.
          What is pulling my ACDET down when i apply power even without BQ ic...
          12-02-2022, 12:03 PM
        • Shulgin
          Acer predator XB241YU Component identification
          by Shulgin
          I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
          After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
          In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
          I...
          05-11-2024, 11:06 AM
        • thebomb602
          ASUS GA402R IC identification
          by thebomb602
          Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
          also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
          EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
          11-21-2023, 02:30 PM
        • Tend0
          hp elitebook 840 G4 no 5v IC identification
          by Tend0
          Hello everythone
          i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
          i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
          05-31-2025, 09:13 PM
        • Tomylee
          Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
          by Tomylee
          I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
          It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
          I'm looking for help with the following:
          The exact identification or part number of the T5 component
          05-28-2025, 12:42 PM
