IPad activation lock
  • davg
    • Sep 2008
    • 536
    I salvaged a IPad 4 from the e-waste recycle with a broken screen. It will take a charge and it is reset to factory default but when I try to set it up I get the Activation Lock screen and need to contact the owner for the apple id and password which would be highly impossible. What are the alternative other than returning it to the e-waste?? Since it has 64 gb of storage It would be a great fine to dedicate to running my OnSong app and music. I did scan this thread but unable to find any help so I though i'd make a new post. any help would be greatly appreciated. The obvious question is it stolen but no who would want to steel a 4 generation IPad with no apple support. Just trying to help the environment
  • vinceroger69
    • Mar 2012
    • 6714
    Re: IPad activation lock
    Does something like this really work?
    https://www.youtube.com/watch?v=FjQRZuqIJeg
    • davg
      • Sep 2008
      • 536
      Tks vinceroger69
      Looks complicated has anyone tried this with success?
      • vinceroger69
        • Mar 2012
        • 6714
        Originally posted by davg
        Tks vinceroger69
        There are a few ipad 4 guides on youtube not sure if they work or not if it was a item i was given for free i would possibly try it as nothing too loose really, some one may know of a easier way though too remove the activation lock.
        • davg
          • Sep 2008
          • 536
          Tks. You are right of course however I was thinking more on the lines of a software fix but not possible I guess
          • vinceroger69
            • Mar 2012
            • 6714
            jail break maybe
            https://www.youtube.com/watch?v=4nnX3sQDZDE
            • davg
              • Sep 2008
              • 536
              I did a jailbreak on my apple tv didn't know it was possible with ipad. I know Dr. fone don't work just take your money and run
              • davg
                • Sep 2008
                • 536
                The above statement re Dr fone maybe unfair since I only tried one of its features?? It will not remove the activation lock as advertised??
                • mon2
                  • Dec 2019
                  • 14662
                  There are assorted shops that will sell you a legit serial #. Somehow they have access to them. You will then need to apply this serial # onto BGA device that is holding this locked value. Then solder it back. Believe this will work but you need to have the tools and crafty skills for the above.
                  https://www.youtube.com/watch?v=cbQlgrqTahQ
                  Send Ayman an email to ask your question and post your reply here for others as well.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1347
                    • France
                    Tks vinceroger69
                    yes it work
                    model :A???? Wifi or 3G
                    more info is needed to help you.
                    which ipad model
                    buy serial number on ebay or others and
                    Mod serial and Mac adress with purple mode for bypass icloud
                    • davg
                      • Sep 2008
                      • 536
                      Thanks guys but the process is much to extensive and would probably cost more than the 4th generation iPad is worth. I will probably bite the bullet and return it to the e-waste
                      • davg
                        • Sep 2008
                        • 536
                        Originally posted by Maxpower3
                        yes it work
                        which ipad model
                        Model A1459 iPad Pro Wifi only.
                        So in that video just what is it that is being removed and do it have to be replaced? It appears it is being scraped off with a pair of tweezers and not needed afterwards?? Hope I am not asking to many silly questions.
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1347
                          • France
                          in the video, it is a 3G model, it removes a resistance to transform it into Wifi only.
                          This was enough before for icloud bypass. but no longer works.
                          In your case, you just need to change the serial number. either unsolder the nand and reprogram it or otherwise with a purple cable
                          • zomi
                            • Nov 2011
                            • 511
                            https://www.appletech752.com/downloads.html
                            have a look there
                            • davg
                              • Sep 2008
                              • 536
                              So there is no magic trick to this?? Working with iPad repair is completely new so forgive me when I ask what is a purple cable and how does that work?
                              • petehall347
                                • Jan 2015
                                • 4440
                                • United Kingdom
                                ring apple and explain your case . they are really helpful
                                  • 31247
                                  if you give up - ebay it.
                                  someone may need a new screen or shell.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Maybe checkraln ?
                                    Code:
                                    https://checkrain.org/
                                    • lc24cxx
                                      • Oct 2018
                                      • 13
                                      • 20100
                                      Hi, you can bypass it with many software paying 10$ but every time ipad will be restored icloud lock cames back.
                                      If you are not lucky (as many) with apple customer services another option is to buy (on aliexp e..y ) new kit of serial number bluetooth and wifi mac address and change it with serial cable in purple mode with tools like magiccfg
                                      since you have a ipad pro 1 is still not supported, so you have to desolder the nand and change those values reprogramming it.
                                      • davg
                                        • Sep 2008
                                        • 536
                                        since you have a ipad pro 1 is still not supported, so you have to desolder the nand and change those values reprogramming it.[/QUOTE]
                                        Where can I learn to do this. Does a 4th gen need desoldering
