I salvaged a IPad 4 from the e-waste recycle with a broken screen. It will take a charge and it is reset to factory default but when I try to set it up I get the Activation Lock screen and need to contact the owner for the apple id and password which would be highly impossible. What are the alternative other than returning it to the e-waste?? Since it has 64 gb of storage It would be a great fine to dedicate to running my OnSong app and music. I did scan this thread but unable to find any help so I though i'd make a new post. any help would be greatly appreciated. The obvious question is it stolen but no who would want to steel a 4 generation IPad with no apple support. Just trying to help the environment
IPad activation lock
Re: IPad activation lock
Does something like this really work?
https://www.youtube.com/watch?v=FjQRZuqIJeg -
There are a few ipad 4 guides on youtube not sure if they work or not if it was a item i was given for free i would possibly try it as nothing too loose really, some one may know of a easier way though too remove the activation lock.Comment
Tks. You are right of course however I was thinking more on the lines of a software fix but not possible I guessComment
I did a jailbreak on my apple tv didn't know it was possible with ipad. I know Dr. fone don't work just take your money and runjail break maybe
https://www.youtube.com/watch?v=4nnX3sQDZDEComment
There are assorted shops that will sell you a legit serial #. Somehow they have access to them. You will then need to apply this serial # onto BGA device that is holding this locked value. Then solder it back. Believe this will work but you need to have the tools and crafty skills for the above.
https://www.youtube.com/watch?v=cbQlgrqTahQ
Send Ayman an email to ask your question and post your reply here for others as well.Comment
yes it work
model :A???? Wifi or 3G
more info is needed to help you.
which ipad model
buy serial number on ebay or others and
Mod serial and Mac adress with purple mode for bypass icloudComment
Model A1459 iPad Pro Wifi only.
So in that video just what is it that is being removed and do it have to be replaced? It appears it is being scraped off with a pair of tweezers and not needed afterwards?? Hope I am not asking to many silly questions.Comment
in the video, it is a 3G model, it removes a resistance to transform it into Wifi only.
This was enough before for icloud bypass. but no longer works.
In your case, you just need to change the serial number. either unsolder the nand and reprogram it or otherwise with a purple cableComment
So there is no magic trick to this?? Working with iPad repair is completely new so forgive me when I ask what is a purple cable and how does that work?in the video, it is a 3G model, it removes a resistance to transform it into Wifi only.
Hi, you can bypass it with many software paying 10$ but every time ipad will be restored icloud lock cames back.
If you are not lucky (as many) with apple customer services another option is to buy (on aliexp e..y ) new kit of serial number bluetooth and wifi mac address and change it with serial cable in purple mode with tools like magiccfg
since you have a ipad pro 1 is still not supported, so you have to desolder the nand and change those values reprogramming it.Comment
since you have a ipad pro 1 is still not supported, so you have to desolder the nand and change those values reprogramming it.[/QUOTE]
Where can I learn to do this. Does a 4th gen need desolderingComment
by GeirAndersenI tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
IPAD COLLECTION 1
+---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
+---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
+---iPad mini3 820-00008(A1599) 820-00002(A1600)
+---iPad mini4 820-00180(A1538) 820-00177(A1550)
+---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
+---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...-
by grimacelordHello.
Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
For example, when I connect the iPad to... -
by a_p3rsonHi there,
I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
This daughterboard uses an interesting...-
04-21-2025, 11:41 PM -
Apple iPad 4th Generation 820-3249 Boardview and Schematic...
Channel: Schematics and Boardviews
11-01-2024, 02:45 PM -
- Loading...
