LA-C421P BQ24780S no ACDRV
  • lazaro.089
    • Jun 2014
    • 79
    • Mexico
    Hi! I have a Thinkpad LA-C421P with no power to the system. No boardview nor schematic available. When connected it draws only 9mA.
    After checking for shorts on coils I found no shorts and only then I injected 20V to the Main 20V system line (After the sensor resistor). The Laptop boots up Ok so the problem is charger is not driving the first 2 N-Channel Mosfets.
    Following Piernov's Guide https://www.badcaps.net/forum/showthread.php?t=90356 I found out BQ24780 has:
    VCC -> 19.8V
    REGN -> 6V
    ACDET -> 2.65V
    ACOK -> 3.3V
    but CMSRC is -> 0V and ACDRV -> 0V too.
    I checked both input N-Channel Mosfets. Both seems fine, but I replaced them anyways.
    Still no CMRSC or ACDRV.
    I changed BQ, same behavior.
    I don't know what to check next.
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: BQ24780S no ACDRV
    Usually bq24780s works in conjunction with 3v 5v alw ic check it
    • mon2
      • Dec 2019
      • 14211
      Assuming that you have checked the passives (resistors) to these input mosfets from the charger IC?
      Perhaps they are missing or damaged.
      • lazaro.089
        • Jun 2014
        • 79
        • Mexico
        Yes both R3 and R4 are 4kohm and are connected fine between BQ and mofets' source and gate respectively.
        Haven't checked the IC yet. But I thought 3 & 5V IC worked with SYS voltage. Does it work with unfiltered R0 voltage?
        (Using BQ's datasheet naming conventions here)
        • Sephir0th
          • Oct 2020
          • 1282
          Could be Just a dead Charging IC. I've Challenged this behaviour before.
          FairRepair on YouTube
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3593
            • slovakia
            why nobody reads datasheets?
            CMSRC is input for charge pump
            as CMSRC is gettting voltage right after Q1 by r4, the first to check is resistance of R4
            • lazaro.089
              • Jun 2014
              • 79
              • Mexico
              Resistance between CMSRC and source of q1 and q2 is OK =4kohm.
              I've already changed the charging ic ��
                • 20918
                Re: LA-C421P BQ24780S no ACDRV
                The LA-C422P has a similar layout. https://www.badcaps.net/forum/showthread.php?t=88885 .I read on one forum that SW1 was broken causing a problem.Tape it down,if the switch is working ok and check CMSRC and ACDRV again.
                • Sametbey
                  • Jan 2021
                  • 229
                  • Turkey
                  you changed the charging chip and MOSFETs, injected 19v (+19V_SYS ) into the output, and the result is the same. Have you checked the AD_ID entry in the DC_IN input socket? he can't quit when he's not.
                  and are the pins fully soldered after the chip change ?
                  I'm not happy to be so strong. because it's not humanly
                  • lazaro.089
                    • Jun 2014
                    • 79
                    • Mexico
                    That was actually it!!! I can't believe it! Thank you SMDFlea!!
                    • rbvndonh
                      • Mar 2021
                      • 162
                      • B
                      I think in new BIOS SW1 switch is no longer considered to start laptop.
                      I have 3 L570 and no one have malfunction to start nor the button is switched or not.
                      • coltron
                        • Jan 2021
                        • 98
                        • England
                        The L560 appears visually similar and has the exact same sw1 switch near the cmos battery. (My L560 was dead from the first 19v mosfet).
                        The plastic leg of the switch was broken off (making it harder to spot). I decided to desolder the switch and bridge the contacts, but this did not bring the laptop to life, so unsoldered the bridge. Again the mosfet gate had no supply.
                        With no obvious shorts to find I took the plunge and bridged the first mosfet across source and drain. That did it, the green light came on and the laptop starts. ( The bridge across the mosfet has been removed and still starts?)
                        Not all good news though, the laptop won't post. an get the 1 33 1 beeps. The ram is a good stick of DDR3 120 but regardless of slot cleaning the beeps continue.
                        I couldn't find a schematic for the L560, but found the L570 which apart from being the next gen of processor and ddr4 is remarkably similar to the L560.
                        The beeps maybe due to another fault unrelated to the ram?, how can I tell?
                        maybe one of the 2 SW1 contacts needs to be bridged, but that doesn't seem to help nd cuts the power off.
                        Despite the beeps, the laptop will power on and stay powered on all day
                        ?, nothing on screen, (power light on lid is lit) just no processor action i think?
                        Any views on a possible line of investigation?
                        • coltron
                          • Jan 2021
                          • 98
                          • England
                          Board view would help?
                          • rbvndonh
                            • Mar 2021
                            • 162
                            • B
                            You need to solder only two top pins of SW1 to get ACDRV.
                            Try this and let know.
                            Maybe BIOS require reflashing also?
                            There could be also some bad caps..
                            • rbvndonh
                              • Mar 2021
                              • 162
                              • B
                              Do you have and can share boardview?
                              • rbvndonh
                                • Mar 2021
                                • 162
                                • B
                                Try to remove PD303
                                • pingaroon
                                  • Nov 2019
                                  • 121
                                  Thanks for the SW1 notes. Was stuck with the 20V not getting through first mosfet - resolved by taping down SW1 (bare board repair) and fixing corrupt bios.
                                  • Sushi1808
                                    • Jun 2014
                                    • 35
                                    • Slovenia
                                    Schematics diagram for Lenovo ThinkPad L560 - AILL1/L2 LA-C421P REV1.0 is now available, hope someone finds it useful.
                                    https://www.badcaps.net/forum/showth...41#post1228941
                                    • Vesko356
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      Thanks for trying to be helpful, but Schematic Requests section is here: https://www.badcaps.net/forum/forumdisplay.php?f=41
                                      Find a matching topic at the Schematic Requests section (for example this one, or this one) and upload the file there, so the people searching for it can be able to find it.
                                      Here is a tech sub forum, I have already transferred your reply here to the one of the threads I mentioned above, and I'll also leave your reply here, but keep in mind for the future.
                                      Become a Badcaps supporter
                                      Thanks to all supporters.​
                                      • janpatirkckaram1992
                                        • Sep 2020
                                        • 9
                                        • Philippines
                                        did you just solder the 1st fet drain to source?
                                        • BlackScreen_22
                                          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                          by BlackScreen_22
                                          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                          I had no problems connecting mosfets and capacitors,...
                                          08-27-2024, 12:46 PM
                                        • kotel studios
                                          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                          by kotel studios
                                          Finally got time to fix this board up.
                                          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                          04-22-2025, 05:08 AM
                                        • flerre
                                          Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                          by flerre
                                          Hi!
                                          Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                          No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                          So, could I safely assume all of these 3 mosfets are...
                                          03-13-2022, 12:14 PM
                                        • Thomas Smith
                                          Asus Tuf gaming fx506l no power, mosfet does not open
                                          by Thomas Smith
                                          Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                          Initial Symptoms:
                                          • The laptop has no power at all (no LEDs, no fan spin).
                                          • No 3.3V or 5V present on the board.
                                          • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                          Power Rail Checks:
                                          1. Charger input (FETs PKCH2BB)
                                            • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                          2. BQ24780S Charger IC:
                                            • VCC and ACDET are present.
                                            • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                            • Shunt resistor has 10Ω to ground.
                                          03-30-2025, 03:38 AM
                                        • Iherduleikgemz
                                          Asus FX505DY - Battery not charging - BQ24780S
                                          by Iherduleikgemz
                                          Hello everyone
                                          I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                          I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                          01-13-2025, 03:54 PM
