Lenovo S340-15IWL led on, no display, ram not working
    I have Lenovo S340-15IWL with LA-H101P motherboard after water damage. Damage was near audio realtek chip (UA1) and input mosfets PQ312 PQ311. I cleaned everything, not soldered realtek yet, but this is not a problem. Bios has clear ME.
    Problem is that after power it takes 20mA, after switch clicking it takes 0.6A, led is still on and CPU + GPU is starting. Fan is working for 3 sec. and then it is switching off for some time, then it is switching on once again, I think because of the CPU temperature. I have all voltages on. On thermal camera I saw that onboard RAM is not starting, so I think that might be the problem. Second thougt was that I don't have one element on board, maybe you can help me identify it... I attached photo (it is before I replaced this bad capacitor)
    Do anyone know what to do?
    This laptop is after some crappy service, so please don't tell me how bad this soldermask looks - I know.
    Re: Lenovo S340-15IWL led on, no display, ram not working
    The missing element is likely to be a capacitor which you can ignore. What do you mean by "Onboard ram is not starting"?? Measure voltage on ram coil and post here.
      RAM coil voltage after start is 1.2V. By not starting I mean that there is no temperature higher on RAM chips after start than before, measured with thermal camera. I know it should be at least 1 sec peak of some higher temperature, should it?
        Re: Lenovo Ideapad 330 Onboard Memory Fail
        Please I have Lenovo IdeaPad S340. The onboard memory is damage and given blue screen of death with memory management error. My mother board number is EL5C3/EL531/EL431 LA-H101P. How do I disable the onboard ram and access the extension slot only.
          Desolder
