Lenovo S340-15IWL led on, no display, ram not working
  • Featurea
    • May 2021
    • 23
    • Polska
    I have Lenovo S340-15IWL with LA-H101P motherboard after water damage. Damage was near audio realtek chip (UA1) and input mosfets PQ312 PQ311. I cleaned everything, not soldered realtek yet, but this is not a problem. Bios has clear ME.
    Problem is that after power it takes 20mA, after switch clicking it takes 0.6A, led is still on and CPU + GPU is starting. Fan is working for 3 sec. and then it is switching off for some time, then it is switching on once again, I think because of the CPU temperature. I have all voltages on. On thermal camera I saw that onboard RAM is not starting, so I think that might be the problem. Second thougt was that I don't have one element on board, maybe you can help me identify it... I attached photo (it is before I replaced this bad capacitor)
    Do anyone know what to do?
    This laptop is after some crappy service, so please don't tell me how bad this soldermask looks - I know.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo S340-15IWL led on, no display, ram not working
    The missing element is likely to be a capacitor which you can ignore. What do you mean by "Onboard ram is not starting"?? Measure voltage on ram coil and post here.
    • Featurea
      • May 2021
      • 23
      • Polska
      RAM coil voltage after start is 1.2V. By not starting I mean that there is no temperature higher on RAM chips after start than before, measured with thermal camera. I know it should be at least 1 sec peak of some higher temperature, should it?
      • ewiase
        • May 2017
        • 3
        • Ghana
        Re: Lenovo Ideapad 330 Onboard Memory Fail
        Please I have Lenovo IdeaPad S340. The onboard memory is damage and given blue screen of death with memory management error. My mother board number is EL5C3/EL531/EL431 LA-H101P. How do I disable the onboard ram and access the extension slot only.
        • tahc81
          • Nov 2019
          • 42
          • Slovakia
          Desolder
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
          • hopkok
            Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
            by hopkok
            Hi masters, I need your help.
            I am working on Lenovo Legion 16ITHg6
            Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
            INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
            My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
            AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
            Power LED is not working as well, power button working well.
            UI26 ??? is there any firmware too? Powered by +3VALW_AG.
            Motherboard...
            05-04-2025, 09:35 AM
          • someonenotyou
            Lenovo A485/T480 USB stops working when USB2.0 is plugged.
            by someonenotyou
            Hi.
            I have 2 Lenovo laptops (A485 and T480) with identical USB problem.
            When I plug in a USB 3.x device (USB storage), the USB ports are working normal.
            But as soon I plug in USB 2.0 device (mouse, USB storage), all the USB ports stop working. Even if I plug in USB 3.x device.
            The only way to get USB working again is disconnect battery and reset BIOS.
            Has anyone had anything similar?
            I have not yet tried another BIOS, but would that be the problem with USB?
            Thank you.
            03-19-2025, 12:15 PM
          • joven016
            Lenovo Ideapad S145 need working bios HELP!!
            by joven016
            Problem is blinking power led only
            i don't know exactly if it's s145-15igm or s145-14igm
            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
            Already tested some of posted bios here
            S145-14igm - success but invalid serial and not booting on OS
            S145-15igm - success with serial and some other info in bios but still not booting on OS
            already tried installing new windows but always booting on bios setup
            windows installer flash drive detected on...
            08-21-2025, 10:55 PM
          • master3112
            Lenovo E15 Gen.3 NM-D481 No starting and charging via USB-C, The device starts only via the battery.
            by master3112
            I have a Lenovo E15 Gen.3, motherboard NM-D481 with a defective USB-C port. The device starts with battery. When connected to the USB-C power supply, it does not start or charge. 20V is present at the input of the UT5 (High voltage USB PD power switch), 0V at the output
            UT5 pin 3 (SNK_PS_EN) =0V
            RPT3 Pin1+2 LDO 3V3 present
            I suspect that the UT2 USB-C power controller is defective because the UT5 is only controlled by the UT2. However, the UT2 supplies on pin 33 (+LDO_3V3) which makes me wonder if it is defective after all. Unfortunately I don't have it here to test it.
            08-02-2025, 12:30 PM
