Asus X441MAR Question
  • kodox
    • Jul 2017
    • 329
    • Indonesia
    this unit came yesterday with problem that it has no picture on lcd or external monitor (vga or hdmi) but still respond on power button, after checked all power rails is present, changing DDR4 ram module known good had a same result.
    checked dramrst# on pin 108 of ram slot, it only gave 0.6 volt without ram module installed, this board don't have onboard ram & no discrete vga chip installed. i can't tested dramrst# with ram installed because i don't have boardview where i can trace other test point for dramrst# and i don't know where to measure other signal.
    from a lot of info i get, flashing the bios will solve the problem, but i doubt because of dramrst# is missing or is it 0.6 volt on dramrst# of ddr4 sufficient since ddr4 only 1.2 volt and dramrst# signal pulled up to 1.2 volt rail?
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Asus X441MAR Question
    I solve many no display lap with no dramrst present with flashing bios , so i advice you to post your old dump in the bios section and ask for clean me or repair bios
    • sysaputra
      • Feb 2021
      • 10
      • Indonesia
      Try flash with this file
      MOD Edit: Bios moved to "Bios Requests ONLY!" - https://www.badcaps.net/forum/showthread.php?p=1047992
      • kodox
        • Jul 2017
        • 329
        • Indonesia
        hmmm....
        so, you think the content on bios chip will be read/write by/to the pch and ec without dramrst# present or even without ram installed?
        how do you make sure pch not faulty because of dramrst# absence?
        thank's, i'll try it soon as i confident it's only the bios corrupted
        • kodox
          • Jul 2017
          • 329
          • Indonesia
          UPDATE:
          nothing's change after flashed the bios 6 times from different source
          LESSON:
          don't flash the bios when dramrst# signal is gone on SoC system and no boardview available to check other signals
          • tomy78
            Newbie
            • Jul 2019
            • 42
            • Indonesia
            can you send me the boardview? i need the boardview
              • 21845
              Post your request in the "Schematic requests ONLY!" section here -> https://www.badcaps.net/forum/forumdisplay.php?f=41
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • lrouw84
                Asus vivobook s510ua bios changed to x510un
                by lrouw84
                Hi there,
                I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                01-28-2023, 01:31 PM
