Asus X751LD Black screen
  • infoplus
    • Aug 2017
    • 83
    • ALGERIA
    Hello everyone
    i have a ASUS laptop come shorted to ground internal memory
    # power on taking only 0.14 A in power supply
    # After removing and Disabling internal memory same think
    Found that signal 1.35V_ON present only in pin 83 of IO messing in PD8300
    After making jumper the laptop turn on but the voltage in little but higher 1.4v ????
    Taking 0.45 A almost voltage there
    the fun spinning half turn and stop... after 10s spinning full speed
    # Coil of nvidia vcc worm with normal voltage 1.07v !!??
    # I already Flash bios only but i'm not sure about the file is suitable for my BRD or not
    i'have not EC file for ITE8585E
    Please help me thanks in advance
  • questore
    • Dec 2015
    • 500
    • csongrád
    Re: Asus X751LD Black screen
    Where did you find your short? IC and pin number?
    • infoplus
      • Aug 2017
      • 83
      • ALGERIA
      Short in 1.35v Line Ram vcc (Internal ram short to ground) ... after removing embedded ram short circuit gone
      and after connecting DC JACK i get 1.4V
      • infoplus
        • Aug 2017
        • 83
        • ALGERIA
        Any suggestion help me please
        • infoplus
          • Aug 2017
          • 83
          • ALGERIA
          Mosfet and coil in nvidia graphic rail heat up and voltage is normal ???
          • questore
            • Dec 2015
            • 500
            • csongrád
            Post power on sequence values for make it easyer to help:
            You can find the points and sequence in the pdf in this thread:
            https://www.badcaps.net/forum/showth...ghlight=X751LD
