Macbook Pro 2015 820-4924 Drawing 0.08 amps not Turning On
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi gooday guys.i have a Macbook Pro 2015 820-4924 that is drawing 0.08 amps .My friend told me he was trying to change the keyboard and something touched and he heard a spark.But i don't see any visible signs of corrosion or anything burnt. I have greenlight and orange light on magsafe.Below i have listed the present and missing rails. Hope you guys can maybe lead me on the right track thanks.
    PPBUS_G3H = 12.57V
    PPBUS S5 HS COMPUTING = 12.57V
    PPBUS S5 HS OTHER5V = 12.57V
    PPBUS_S5_HS_OTHER3V3 = 12.57V
    PP3V42 G3H = 3.42V
    PPVRTC G3H = 0V
    PP5V S5 = 5V
    PP5V S4 = 0V
    PP5V S3 = 0V
    PP5V_S0 = 0V
    PP3V3_S5 = 3.3V
    Okay so now while checking the rails for short i left out PPVRTC G3H of U1900. Checking it now on Pin 1 is showing me short and beeping to ground.In diode mode it's reading 0.005V .There is a cap C1910 connected to pin 1 and it's beeping both sides. I am going to remove it and see if that is the culprit.And why PPVRTC G3H is shorted.Will report back if it made any difference.
    Last edited by platinumsteel; 05-17-2021, 03:50 PM. Reason: while double checking found a short
  • mon2
    • Dec 2019
    • 14571
    Re: Macbook Pro 2015 820-4924 Drawing 0.08 amps not Turning On
    First, remove the keyboard and trackpad to eliminate them from this puzzle.
    Then,
    1) Check the power rails on U1900. Pin 1 of this part creates the PPVRTC_G3H rail. Is it hot or any liquid damage ? This part may be defective.
    2) Check U7501, rail PP5V_S4 - voltage reading @ L7520, pin # 1 ?
    3) Check the U7501, pin 4 = EN ( P5VS4RS3_EN ) - voltage reading ?
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      Hi mon2 here are the resutls.
      voltage reading @ L7520, pin # 1 =0V
      U7501, pin 4 = EN ( P5VS4RS3_EN ) = 0V
      • platinumsteel
        • May 2019
        • 234
        • Trinidad&Tobago
        Well i ended up removing U1900 and pin 1 pad and the caps were still shorted.So removed all the caps on the line.there was about 4 of them.And their pads were still shorted.So at this point i have reached a dead ed and don't know why PPVRTC G3H is still shorted to ground.there are only 4 resistors left on the line .And well am sure you guys might agree resistors don't get shorted right ? So it seems like the PCH is toast that is the only conclusion i can come too.Pin 1 of resistors goes too PPVRTC_G3_PCH ..and that goes directly into the PCH .So can you guys confirm for me yes it is indeed a dead PCH? thanks
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3616
          • slovakia
          inject and u will see
          • platinumsteel
            • May 2019
            • 234
            • Trinidad&Tobago
            Just when i was about to go back into it .I decided to clean the little thermal paste off the CPU and noticed this below.First time i was able to literally see inside the PCH. lol Anyway we were able to find a replacement board for the customer on ebay for a reasonable price. So we will replace it with a used logic board and i will keep this board as a donor .Thanks for the input guys. Sorry i didn't notice this first. Apologies for wasting some of you all time .
            • survivalbloke
              shorted power rail - drawing 3.5 amps but no heat?
              by survivalbloke
              This board is out of an HP laptop. There is no voltage present at pin 8 of the Winbond BIOS chip. A nearby coil is a near dead short to ground. Injected 1v and it drew 2.8a but nothing was warm on the board. Then I upped the voltage to 2.5 and 3.5a were drawn, but still no heat. Is that crazy?
              02-28-2023, 04:30 PM
            • Stephen
              A2991 Logic Board issue, 20volts 0 amps help!
              by Stephen
              Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
              09-10-2025, 03:16 PM
            • Stephen
              A2991 logic board issue, 20volts 0 amps help!
              by Stephen
              09-10-2025, 03:15 PM
            • Fisher8865
              MacBook Pro A1990 stuck at 5v .592 amps
              by Fisher8865
              Hi guys
              I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
              05-30-2024, 07:36 PM
            • platinumsteel
              HP Elitebook 8470P Dead not Powering on drawing 0 amps.
              by platinumsteel
              Hi guys hope you all are fine.I have a HP Elitebook 8470P have me confused.Hoping you guys can help me figure it out.It draws 0.00 amps and does not power on at all.I notice something weird on the 19V rail tho.I have 3v and 5v on coils tho.I have no PGOOD Signal on Pin 23 of the 3V/5V TPS51123RGER IC. I have Vreg3 which is 2.4V and Vreg5 Which is 5V. I have voltage on the TRIP1 and TRIP2 lines which I was told that it should not have any voltage there.Or else the IC goes into Protection Mode.Not sure if that is true.But anyway I have attached 2 pictures.One showing the voltages in relation to...
              12-04-2020, 07:58 PM
