a1706 820-00239-A charging but no 5V Output
  • Harryrepair
    • Jul 2016
    • 82
    Hello community,
    what can cause the following problem?
    All 4 USBC Thunderbolt connector do recognize the charger and work properly.
    But there is no power on 5V Devices like a simple USB memory stick.
    Furthermore the device is giving me following failure:
    System Sleep Wake failure in EFI
    Always i shut the display or the machine wants to launch screensaver it is rebooting and giving me the message after rebooting.
    Kind Regards
  • mon2
    • Dec 2019
    • 14100
    Re: a1706 820-00239-A charging but no 5V Output
    1) check the voltage on L3500, pin # 2. It should be +5v0 (or close to).
    2) if not @ +5v0, power down, remove battery and check the resistance to ground on the L3500, pin # 2.
    3) Also inspect the small type C paddle boards that mate with the main logic board on the A1706 series. Have seen some bad ones that needed replacement. Often the Type C connectors just wear out or arc with fake adapters. Somewhere on this forum, have shared some ugly pix of a worn out Type C connector that halted an ipad Pro 12" (2020) from working. Issue was just the cable in this case while Apple said it was the logic board and for the client to buy another $1200-$1500 replacement.
    • Harryrepair
      • Jul 2016
      • 82
      Thanks for your answer.
      I am missing PP5V_S4_X_USBC.
      PP5V_S4 is always present.
      UPC_X_5V_EN at 3.3V
      P5VUSBC_X_PGOOD 0.2-0.6V not stable
      What can be the issue?
      • Harryrepair
        • Jul 2016
        • 82
        One more question:
        How is it possible that PP5V_S4 is always present but the lines resistance to ground is 6ohms?
        • mon2
          • Dec 2019
          • 14100
          1) PP5V_S4 rail is generated as shown on sheet 72 / 119 of the PDF schematics.
          With a resistance of 6 ohms to ground, using ohm's law calculator:
          https://ohmslawcalculator.com/ohms-law-calculator
          Feed this calculator 5 Volts and 6 ohms, yields 0.833 A.
          The rail can support up to 1.58A so it is ok.
          2) Since PP5V_S4_X_USBC is missing, power down & remove your battery.
          Place your meter in resistance mode (OHMS) and place red lead on pin # L3500 and black lead to ground.
          What is the resistance reading ?
          3) Using your meter in voltage mode, check the voltage of PPBUS_G3H @ pins 8 & 9 of Q3501 mosfet. This local switching power supply rail accepts the higher PPBUS_G3H voltage and steps it down (BUCK regulator) to generate the missing PP5V_S4_X_USBC rail.
          It is possible that the issue is linked to this page # 33 - the mosfet may not be switching or the regulator is not enabled.
          4) Check if the regulator is enabled by monitoring the voltage on UPC_X_5V_EN = pin 15 of U3500.
          It is interesting to note that this UPC_X_5V_EN logic level is generated by the CDC3215 USB Type C controllers. So respectively, we need to make sure that each of the CDC3215 controllers are working properly. Any of these being damaged can tank this circuit and halt the operation of the logic board.
          See here from Piernov:
          https://www.logi.wiki/index.php/CD3215_Bootup_Sequence
          and this video on CD3215 debugging:
          https://www.youtube.com/watch?v=6fEQS1MsZIw
          Q: On your USB Type C power supply, do you ever see +20V negotiated by your logic board? What is the value of PPBUS_G3H for your logic board ? If you do see +20V then the CD3215 should be ok which will imply that they should be capable to ENABLE this UPC_X_5V_EN logic level. Post your value for UPC_X_5V_EN. If this signal is ENABLED ok, then the issue is drilling down to the U3500 region.
          The +20V USB Type C power delivery contract will only be selected if the CD3215 are not damaged. A bad (Apple power adapter clone) can cause damage to the CCx lines which are required for USB Type C power delivery negotiations. Also a hot removal of a charging adapter which will use 20V can cause such damage. The CCx pins are very close to the VBUS pins on the Type C connector and a sloppy pull-out places the +20V onto the CCx lines and damages the PD controller. New generation of parts allow for tolerances to protect such damage.
          • Harryrepair
            • Jul 2016
            • 82
            Thank you mon2 for spending so much time with helping me.
            Before i go on, here is a short explanation about the history of this macbook.
            it was liquid damaged. I took a spare board and changed
            1.SMC
            2.U7800 SN650839 (Power Management Controller/ is this the pch?)
            3.isl95828 (CPU Controller?)
            After this work the macbook came back working and usable.
            Charging on every Port with 20.3V.
            I mention that all cd3215 are ok so far.
            PROBLEM 1:
            No one port recognizes any 5V source, i tried with a simple USB Drive on usb-c adapter.
            I checked this adapter-USB Drive combination on a working macbook before.
            PROBLEM 2: (possibly a result of problem 1?)
            Instead of hibernating / switching to wallpaper mode AND when in standby (Display shut)
            the machine does reboot by itself and giving me the ERROR :
            Sleep/Wake failure in EFI
            All other functions were OK.
            From this point i did :
            1. new (known working) BIOS with ME clean (old SN copied)
            2. "POST TOPIC" Found this 5V Line (U3500,UB700) with problems.
            Today i took out both isl95870 USB controller and 3 resistors which were found with about 17ohm instead of 2.2
            R3501 / R3506 / RB706
            Why was on RB701 PIN2 PP5V_USBC_T_VCC passing 5V?
            PP5V_S4 has now 130ohm to ground
            UPC_X_5V_EN was at 3.3V
            BUT
            P5VUSBC_X_PGOOD was only 0.2-0.6V
            I want to put in new isl`s and resistors but ran out of spare parts.
            I think something is pulling down PP5V_S4
            • mon2
              • Dec 2019
              • 14100
              Try the SMC reset = step # 3 here:
              https://softwaretested.com/mac/macbo...%20work%20fine.
              • Harryrepair
                • Jul 2016
                • 82
                Today i changed the mentioned 3 resistors and both isl U3500/UB700.
                5 V is back.
                No i get the message that computer is disabled.
                Because i changed the bios chip?
                • mon2
                  • Dec 2019
                  • 14100
                  Hi. See here:
                  https://discussions.apple.com/thread/250159484
                  Good idea to ask in the BIOS forum as well.
                  • Harryrepair
                    • Jul 2016
                    • 82
                    i changed the bios chip back to original. Before it was a donor with ME region free and SN number copied.
                    Now the machine is running with 5V Output.
                    Sleep Wake failure is still present, so i had 2 different problems.
                    Everytime the lid is closed, this macbook reboots by itself.
                    • mon2
                      • Dec 2019
                      • 14100
                      Try a SMC and PRAM reset.
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
                      • FrancescoV
                        Onkyo HT-R390 no sound output, video output ok
                        by FrancescoV
                        Good morning everyone,
                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                        The firmware reported is the following:
                        M:1.00/11107BLP
                        D:?.??/????????
                        O:1.00/11107AL
                        The DSP firmware given the question marks seems corrupt.
                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                        05-11-2025, 02:59 AM
                      • guzq
                        MBP13 2016 A1706 820-00239-A Charging BUT not detect external drive (NO 5V output)
                        by guzq
                        All 4 USB-C port have 20v, can charge, turn on fine and work properly BUT doesn't detect external drive / USB on all ports (No 5v output)
                        L3500 = 0V / DM = 0.332
                        LB700 = 0V / DM = 0.337
                        PP5V_S4 = 5V (R3501, R3506, RB701, RB706)
                        UPC_X_5V_EN = 0.198V / DM = 0.539
                        UPC_T_5V_EN = 0.215V / DM = 0.543
                        From schematic, UPC_X_5V_EN & UPC_T_5V_EN sending out from CD3215
                        What should i check before replacing CD3215 ??
                        02-17-2022, 08:47 PM
                      • Scoff
                        HP Probook 470 G4 - Power and Charging Problem
                        by Scoff
                        Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                        Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                        07-03-2023, 09:28 AM
                      • SluggerB
                        Help with trying to fix phone that is not charging (Pics inside)
                        by SluggerB
                        I have two TCL A30 phones.
                        Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                        New Phone: Works fine, bought as a donor board to try and repair Old Phone
                        My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                        08-12-2024, 08:11 AM
