HP Elitebook Screen blank - backlights but no image
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I'm trying to fix this laptop screen
    Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
    OK so I have the original screen which works but has lines across the bottom quarter of the screen
    I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would not work - backlights OK but no image. An external VGA monitor works fine
    So I thought I would try to fix the screen with no image. I checked the voltages on all the test points on the TCON PCB. They are the same, or very close, on both screens
    I then booted into windows with the internal screen attached, using the external monitor as a second display. in both cases Windows knows the screen is there.
    So basically I can't see any difference between the the one with lines on the display and the one with no display.
    I identified the main chips (Backlight PSU, Gamma, Image?, and a couple of eeproms - see pics. I could only find datasheets for the EEPOMS.
    I was thinking maybe the screen with no image would also not detect - but that is not the case. What do the EEproms do? Are they like a BIOS chip on a GPU for example? I'm now thinking of swapping the chip that I think handles the graphics (The parade Wise View chip) and maybe the EEproms to see if I can get the blank screen to work
    In fairness I don't have as much knowledge as I would like -
    Apart from the obvious voltage, PWM and BL_ON signals on the LVDS, there are also signals called DPRX_AUXN, DPRX_AUXP, DPRXOP and DPRXON. Any idea what these are? Is there a standard pin-out for LVDS or tutorial?
    What do the EEPROMS do? Is the data unique to each model of screen (like a motherboard BIOS) or unique to each individual screen (like a HDD eprom)?
    Any suggestions of anything else I could check, or should I just start swapping parts over?
    Here are two videos (unlisted so you need these links to view) if you would to see what I have tried so far:
    part 1 - https://youtu.be/dk3crSH8uo0
    part 2 - https://youtu.be/pm-8aTGbKj0
    Follow me on YouTube
    Learn Electronics Repair
  • diif
    • Feb 2014
    • 6978
    • England
    Re: HP Elitebook Screen blank - backlights but no image
    Looks like a Dell laptop ? The eeprom holds the Extended Display Identification Data (EDID), I'm guessing this wrong on the non display screen.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Hi diif
      Yeah that would make sense.
      it is a HP Elite laptop
      Given that it did work after the new screen was fitted, then put in storage for a few weeks and did not work when it came back out, what would cause the eeprom to fail?
      There are two EEPROMS, do I need to swap both or just one?-
      • piernov
        • Jan 2016
        • 4439
        • France
        These are eDP not LVDS. AUX is for display identification (EDID is communicated over that bus), 0 is the first (and unique on this panel since it's low resolution) eDP data lane.
        HPD is also part of eDP and it's the panel presence signal.
        Can be confirmed by looking at the schematics of the laptop.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Hi Piernov
          I didn't think to look for the laptop schematic as the laptop itself works
          So the DPRX0N and DPRX0P (I used zeros instead of O this time) are Negative and Positive (differential signals) and the same for AUX P and N-? - these are like PCIe lanes, kinda?
          The display identification works (as tested in my YT video) just no video. I will try swapping the Eeproms from the other panel first. It seems more likely that an Eeprom may be have got corrupted rather than the video output chip to fail.
          I'll also go google for eDP see if I can learn something new.
          Cheers.
          • piernov
            • Jan 2016
            • 4439
            • France
            These are differential pairs yes.
            Also you need to clarify what "no video" means. No image and/or no backlight and what color is it showing.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              No image and backlight working. I did link to the videos which show the fault clearly. You can see that that it is a dark grey colour. There are a few feint horizontal lines when first powered on but they fade away to an even grey
              This video
              3mins : 0 secs
                • 22127
                Whats the laptop model number and do you know the old screens part number .
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  Hi SMDFlea
                  I posted photos of both screens part numbers in the OP - you can see them both on the second photo - They are identical. Is that what you wanted or something else, in which case I will post the info
                  I didn't post the laptop pmoel number, I'll do it tomorrow morning
                  • dicky96
                    Sun Seeker
                    • Mar 2017
                    • 1825
                    • Spain
                    Also - today I looked at the signals DXPR0N and DXPR0P - there is too much noise on my scope to see the differential signals properly. But I looked at the signals coming out of the video chip to the panel and in both cases they are are sending data to the screen though I have no idea if the data signals are good or bad. However they look kinda similar
                    I've now removed both the Eeproms and the 'video' chip from the working panel that has lines in the bottom quarter. Tomorrow I will solder them to the panel with the blank screen and see if it makes any difference.
                    Rich
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      OK, the model number as requested HP Elitebook 8440p
                      I swapped the large QFN (Parade DP619) and both the Eeproms from the screen that had a picture but lines on it.
                      The result of this is that it made no difference. The backlight still comes on, there are some initial feint horizontal lines across the screen that fade away to an even grey after several seconds. Using an external VGA I can see that the laptop still detects both screens in display Properties.
                      I'm at a loss now to understand why it does not show a picture. I feel like I am missing something obvious - but what? Can anyone suggest what else I can test, just for the sake of sanity?
                      Rich
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        If all the usual LCD driving voltages are good (VGH/VGL/VCOM/…) I'd guess it's a defective row/column driver or FFC.
                        • dicky96
                          Sun Seeker
                          • Mar 2017
                          • 1825
                          • Spain
                          Hi Piernov
                          I am home now but I just looked at the photos I uploaded. There is a test point called VCOM so that will be the same on both panels as I measured all test points and compared them.
                          I can't see any test points for VGH/VGL,though I need to look a the actual boards to double check. So quite possibly I did not measure those.
                          I found this link that taught me a bit about these voltages and how they are generated.
                          https://pcbartists.com/design/power-...matic-tft-lcd/
                          I saw some voltages around -6.5V on several test points on both panels so that sounds like it could be VGL
                          Do I also need AVDD ,DVDD, VIH, VIL? Or is that for TFT panels only, which mine could be I guess.
                          I'm pretty sure all the Gamma voltages are there - they measured the same on both panels, and the test points are clearly marked. I just noticed there is a coil L1 near the RT9965 chip which I assumed generates Gamma, and I didn't check voltage there.
                          I failed to locate a datasheet for RT9965, but is it likely that this IC generates gamma and also generates VGH, VGL? There is another chip marked OP1 near here that I should look at, plus a few transistors. The other four 6 pin devices nearby are marked D11, D12, D32, D33 which I am assuming are diode arrays, and this kinda makes sense if OP1 is in a circuit similar to the example on in the above link ,rather than RT9965.
                          Although quite a pointless repair, I am learning quite a lot about LCD panels here, so it's a useful if somewhat frustrating experience so far
                          Thanks for your assistance.
                          Rich
                          PS what's a FFC? Google says it's Fulham Football Club
                          • mon2
                            • Dec 2019
                            • 14726
                            FFC :
                            https://en.wikipedia.org/wiki/Flexible_flat_cable
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              FFC i think means Flat Flexible Cable
                              • dicky96
                                Sun Seeker
                                • Mar 2017
                                • 1825
                                • Spain
                                Thanks Mon2, Vince. Google did not tell me that for some reason, and I thought Google knew everything.
                                OK, there are test points at all the inputs from the FFC on the panel PCB, and they are reading the same voltage on both panels. Plus I also examined the socket on both and they look fine. Obviously the cable is OK as one of the panels works ( albeit with lines on the screen)
                                  • 22127
                                  Whats the part number on IC5
                                  • dicky96
                                    Sun Seeker
                                    • Mar 2017
                                    • 1825
                                    • Spain
                                    Here is the chip IC5, and also the other one OP1
                                    I could not find a datasheet
                                      • 22127
                                      iML7975 and iML7822 ,theres no datasheets.From what ive read the 7975 is there to reduce screen flicker.
                                      https://cdn.badcaps-static.com/pdfs/...bba237f832.pdf
                                      https://monitor.net.ru/forum/threads/483355/
                                      • dicky96
                                        Sun Seeker
                                        • Mar 2017
                                        • 1825
                                        • Spain
                                        I was given an bin file for the EDID eprom ,and compared that with the contents of the 402WP Eproms from both my screens - both the eprom contents are identical to the file
                                        I decided to have another look on both screens to see if I could find the LCD supply voltages
                                        Vcom has a test point and is 3.326V
                                        VGL has a test point and is -6.94V
                                        VGH, DVDD, AVDD, VIH, VIL I can't find.
                                        Is the information on this link correct for LCD screens in general? As it gives min, max and typical voltages for all of these.
                                        This says that VGH would be ~ 16V and AVDD would be ~ 10.4V but I can't see any voltages on either panel in that range.
                                        Basically all the voltages I see are either less than 8V apart from 22.37V on test point VON, and a 22.18V and 19.4V in the area of the circuit that appears to be for Back light voltage generation.
                                        So that does not make sense either - I have looked for 16V and 10.4V on all the capacitors in the RT9965 / iML7975/iML7822 area of the board and can't find anything close to those values - on either panel.
                                        It's so annoying when I can't fix something because I can't figure out what's wrong with it! I don't care now if I can fix it or not, I just want to understand exactly why it does not work
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                          by mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                          11-25-2024, 05:22 PM
                                        • Bloopeta
                                          Samsung UE55JU6800K No Picture
                                          by Bloopeta
                                          Samsung UE55JU6800K with no image on screen.
                                          I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
                                          Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
                                          I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
                                          Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
                                          05-03-2024, 10:42 AM
                                        • 4thommo
                                          JVC-32C675 Backlights on but blank screen
                                          by 4thommo
                                          Hi all,i have this problem and so far I have visually checked the main board and flashed the main board with the files in the first picture. The flash seemed to go ok,first the front red LED flashed quickly and then slowed up before the TV turned itself off and on but it is still the same. I see there are exact matching main boards available but I don't want to commit to that incase it's something else. Any help would be greatly appreciated.
                                          PSU 17IPS62
                                          MB 17MB110P
                                          Panel VES315WNDS-2D-N14
                                          08-04-2025, 07:42 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
