A1706 820-00239a question mark and not charging
  • Harryrepair
    • Jul 2016
    • 82
    Hello community,
    i am troubleshooting this machine since 3 weeks.
    It had a liquid damage.
    What i did so far:
    Changed pch and isl95828 (cpu controller)
    Machine is turning on now and shows me question mark.
    It does not charge the battery.
    First i‘d like to work on ssd.
    R9350 and the trace is ok
    J9600 is ok
    R9406 Input 5V - NO OUTPUT
    R9401 Input 5V - 5V OUTPUT (should be 2.7V?)
    I appreciate all help and hints!
    Regards
  • mon2
    • 14662
    Re: A1706 820-00239a question mark and not charging
    Guessing that you have seen the following video since you mentioned R9350?
    https://youtu.be/WbuRSUitwCw
    • Harryrepair
      • Jul 2016
      • 82
      Yes, there are couple machines with problems at this probe point.
      Mine is fine ppvin is passing to R9350
      • piernov
        • Jan 2016
        • 4439
        • France
        Find out why it's missing then, broken resistor, broken trace, short to ground…
        • Harryrepair
          • Jul 2016
          • 82
          Changed R9406 and R9401
          Why is the output of R9406 5.1V although it should be 2.7V?
          SSD_RESET_L is high? This signal comes straight from U0500,isnt it?
          • Harryrepair
            • Jul 2016
            • 82
            Changed Resistors, did internet recovery and device is working good.
            Merci pour votre aider
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • Thomasraud
              Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
              by Thomasraud
              i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
              QUOTED
              -It works on charger (without battery connected-only charger)
              -It works on battery (without charger connected-only battery)
              -& it also works when plugged in battery & charger, but it's not charging the battery
              //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
              and..
              QUOTE
              The IC cannot maintain the input current level
              06-28-2022, 06:47 PM
            • Scoff
              HP Probook 470 G4 - Power and Charging Problem
              by Scoff
              Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
              Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
              07-03-2023, 09:28 AM
            • SluggerB
              Help with trying to fix phone that is not charging (Pics inside)
              by SluggerB
              I have two TCL A30 phones.
              Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
              New Phone: Works fine, bought as a donor board to try and repair Old Phone
              My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
              08-12-2024, 08:11 AM
            • Wang Tingting
              Acer Nitro 5 AN515-57-536Q not charging
              by Wang Tingting
              I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
              report is also good for battery.
              Following https://www.badcaps.net/forum/troubl...arging-circuit,
              • DCIN/VCC: 19.1
              • ACIN/ACDET: 3v
              • REGN/VDD: 6v
              • CMSRC : 19v
              • ACOK: 3.3v
              • ACDRV: it is 19v, not 25V(when charging, the ACDRV
              09-10-2025, 01:46 PM
