lenovo y7000 blinking power light
  • bigbily09
    • Dec 2014
    • 68
    • qc
    i have here a lenovo y7000 mb code: ey515/ey517/ey519/ey520 nm-b701
    the problem is when i press the power button only blinking led power white, light already program bios with clear m.e but still same problem
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: lenovo y7000 blinking power light
    Did you make any measurements ?
    • pni
      Samsun ue49ku6450 blinking red light only when press the power button
      by pni
      Hi guys I have this tv Samsung eu49ku6450 that have a problem. When I plug in the power cord the standby led starts to blink but nothing happen. Then the standby led disappear. If I push the power button I see the standby led blinking but nothing happens and if I stop to press the button I don’t have the standby led red…nothing . I don’t understand if there is a problem in the main board or in the power board or it s a firmware problem. I tried to disconnect the main board from the power board, and I know the led should turn on when the main is unplugged but nothing happen…..so could be...
      11-28-2025, 02:18 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • lapfix
      HP OMEN NO power no light
      by lapfix
      HP OMEN : DAG35DMBAD0
      NO power ,no short ,no corrusion
      Consumption : when charger plg in = 0.004 amp
      Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
      when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
      No light at power button led
      All coils resistances :
      Pl 2001 =3v measured with kohm.
      pl 2004 = 5v measured with kohm
      pl 6001 = 49.7ohm
      pl 4012 = vccsa = 24.4 ohm
      pl 3001 =...
      11-03-2025, 07:48 AM
    • huzo
      HP 470 G5 blinking amber light no power
      by huzo
      The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
      So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
      I've tried flashing the bios...
      interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
      06-08-2023, 04:08 PM
    • roxboy1984
      Lenovo ideapad 3 no power, orange light blinks once when charger inserted
      by roxboy1984
      Hi guys,
      I wonder if anyone has encountered this. I have a Lenovo ideapad 3 that shows no signs of life except when the charger is first inserted the orange charge light comes on for a brief second and then goes off. There is no other sign of life and no fans or lights come on.
      if I check the voltage going to the battery it spikes when I insert the charger and then hoes back down.
      i tried injecting 2V but nothing gets hot. Any ideas? Im still a noob.
      11-25-2025, 06:00 AM
