Toshiba Satellite - Locks up when plugged in
  • rievax_60
    • May 2012
    • 897
    • australia
    #321
    Re: Toshiba Satellite - Locks up when plugged in
    Originally posted by freeman300
    All right sounds intresting.
    Any ideas how to do it? +125°C for 1-1.5h
    Quote from Wikipedia:
    Soft solder is what is most often thought of when solder or soldering is mentioned and it typically has a melting range of 90 to 450 °C (190 to 840 °F).[citation needed] It is commonly used in electronics and plumbing. Alloys that melt between 180 and 190 °C (360 and 370 °F) are the most commonly used. Soldering performed using alloys with melting point above 450 °C (840 °F) is called 'hard soldering', 'silver soldering' or brazing
    If I am about to try this how to do it? Hot air pistol?
    Like I said before. "its a long shot"
    Its best for it to be a temperature controlled hot air gun. I would try 150C.
    Can you test for ripple on the Vcore rail?
    • dromango
      • Aug 2012
      • 4
      • usa
      #322
      Is it ok to turn on the laptop without the nec token? Im about to replace the bad cap for Toshiba Satellite L305-S5894.
      • rievax_60
        • May 2012
        • 897
        • australia
        #323
        I can not predict what will happen. It is best to not do it.
        • johnwafu
          • May 2012
          • 17
          • philippines
          #324
          Ive tried it once without nectokin
          no display only and auto shutdown XD
          • dromango
            • Aug 2012
            • 4
            • usa
            #325
            I ask because, even when you guys install caps, some of you say the problem is not fixed. so I am just getting a clear idea here. well, I know its never too good to turn on something without its pieces...
            • Newtonkh
              • Aug 2012
              • 5
              • India
              #326
              what i have done so far is to remove the SuperCap ( NECTOKIN) and Solder 4 330uF Tantalum Caps to where the NECTOKIN was. U will need to carefully scratch the UV coat.
              i have done more then 30 laptops with the NECTOKIN in the last 6 months and all worked well.
              • johnwafu
                • May 2012
                • 17
                • philippines
                #327
                a have a problem with my client toshiba blackout with intermittent power.
                Ive already replaced 4 330uf same problem
                2 330uf same problem
                2 220uf same problem
                2 220 and 2 330 same problem
                check the lan because it was blinking upon pressing the power button
                remove the controller ic of the lan
                but still same problem after I on the unit shutoff no display or what
                ive noticed that the proc is not heating up
                tried new proc same problem
                any ideas sir/mam?
                ive also noticed that the nothbridge was over reheated by other tech that handled this first
                pls help me on this
                • al5911
                  • Jun 2011
                  • 5
                  #328
                  My friend have Satellite L200 that cannot boot. No post. Battery already depleted. When I plug in the power, the charging led and wireless led will automatically light up. When I pressed power button/switch, it charging led,wireless led,power led and hdd led will light up for 4-6 sec then after that only the charging led and wireless led remain light on. I already changed the NEC/TOKIN OE128. What could be the problems? I'm thinking there is shorting else where but I don't know how to look/find for it. Any help gentleman??
                  • trebo
                    • 514
                    • Wales, UK
                    #329
                    Hi Newtonkh
                    Can you tell us what the Esr was, on your suggested Tantalum Caps
                    Thxs
                    • davida999
                      • Sep 2012
                      • 6
                      • australia
                      #330
                      i have a laptop samsung with a NEC TOKIN OE687
                      can anyone suggest replace cap values. i have looked for spec sheet but could not find it
                      • davida999
                        • Sep 2012
                        • 6
                        • australia
                        #331
                        i have found the following which may help
                        where for Capacitance e.g. 128=1200uF
                        First two digits represent significant figures.
                        Third digit specifies number of zeros to follow.
                        • Notsosure
                          • Nov 2011
                          • 71
                          #332
                          Apparently there is not much info available about OE687 on the Internet.
                          OE687 refers to a capacitance of 68 followed by 7 zeros in picofarads (i.e., 680000000pF), which is 680uF (microfarads). These Proadlizers usually have ESR of between 1 to 2mΩ. Therefore, you should consider replacing it with four caps of the type T520V227M004ATE006 or similar.
                          • davida999
                            • Sep 2012
                            • 6
                            • australia
                            #333
                            OE687 refers to a capacitance of 68 followed by 7 zeros in Pico Faraday (i.e., 680000000pF), which is 680uF. These Proadlizers usually have ESR of between 1 to 2mΩ. Therefore, you should consider replacing it with four caps of the type T520V227M004ATE006 or similar.
                            thanks Notsosure
                            i did find this datasheet on the oe687 (PSGD0E687M7)
                            http://www.datasheetarchive.com/PSGD...datasheet.html
                            the mouser item T520V227M004ATE006 seems to have a min buy of 320 units on a roll.
                            could i sub the RS 470's and exceed the uF rating by nearly double or use multiple 100uF caps?
                            i'm in bris australia
                            • Notsosure
                              • Nov 2011
                              • 71
                              #334
                              The datasheet appears to be for small caps and I thought you have a large cap (i.e., Proadlizer) in your laptop?
                              If you do not want to experiment much then 7 or 8 of 100uF ceramic caps might be the easiest way to go. If you do not mind experimenting then you could try 2 or 3 of RS Stock No. 737-2832 or similar. 3 will give a total of 1410uF which is around twice the present capacitance.
                              • Notsosure
                                • Nov 2011
                                • 71
                                #335
                                Being in Australia, RS might be a reasonably priced source because of free shipping.
                                • davida999
                                  • Sep 2012
                                  • 6
                                  • australia
                                  #336
                                  thanks Notsosure, sorry about the datasheet, i'm not into board level stuff. it is a proadilizer. with the 100uf ceramics how is the ESR calculated or doesn't it relate to them?
                                  • Notsosure
                                    • Nov 2011
                                    • 71
                                    #337
                                    Their ESR is probably 1mΩ so it is not a concern at all but their temp limit appears to be 85C, which too is usually not a problem unless laptop runs very hot for some reason:
                                    http://translate.google.com.au/trans...ed=0CG8Q7gEwBg
                                    • davida999
                                      • Sep 2012
                                      • 6
                                      • australia
                                      #338
                                      thanks again Notsosure. i'm going to try the tantalums because they are easy to get`from RS. its pretty hard to source any of the other options.
                                      i really appreciate you taking the time to post advice here and in the many other posts i've seen here and elsewhere.
                                      • Notsosure
                                        • Nov 2011
                                        • 71
                                        #339
                                        You can actually get 10 of GRM31CR60J107ME39L from RS for $17 delivered, if you wish to. Of course, if you are willing to experiment with other caps then any inputs from you might help others. The choice is yours.
                                        • davida999
                                          • Sep 2012
                                          • 6
                                          • australia
                                          #340
                                          thanks Notsosure, i didn't think of searching by the part #. i will order them today.
