Toshiba Satellite - Locks up when plugged in
  • rievax_60
    • May 2012
    • 897
    • australia
    #321
    Re: Toshiba Satellite - Locks up when plugged in
    Originally posted by freeman300
    All right sounds intresting.
    Any ideas how to do it? +125°C for 1-1.5h
    Quote from Wikipedia:
    Soft solder is what is most often thought of when solder or soldering is mentioned and it typically has a melting range of 90 to 450 °C (190 to 840 °F).[citation needed] It is commonly used in electronics and plumbing. Alloys that melt between 180 and 190 °C (360 and 370 °F) are the most commonly used. Soldering performed using alloys with melting point above 450 °C (840 °F) is called 'hard soldering', 'silver soldering' or brazing
    If I am about to try this how to do it? Hot air pistol?
    Like I said before. "its a long shot"
    Its best for it to be a temperature controlled hot air gun. I would try 150C.
    Can you test for ripple on the Vcore rail?
    • dromango
      • Aug 2012
      • 4
      • usa
      #322
      Is it ok to turn on the laptop without the nec token? Im about to replace the bad cap for Toshiba Satellite L305-S5894.
      • rievax_60
        • May 2012
        • 897
        • australia
        #323
        I can not predict what will happen. It is best to not do it.
        • johnwafu
          • May 2012
          • 17
          • philippines
          #324
          Ive tried it once without nectokin
          no display only and auto shutdown XD
          • dromango
            • Aug 2012
            • 4
            • usa
            #325
            I ask because, even when you guys install caps, some of you say the problem is not fixed. so I am just getting a clear idea here. well, I know its never too good to turn on something without its pieces...
            • Newtonkh
              • Aug 2012
              • 5
              • India
              #326
              what i have done so far is to remove the SuperCap ( NECTOKIN) and Solder 4 330uF Tantalum Caps to where the NECTOKIN was. U will need to carefully scratch the UV coat.
              i have done more then 30 laptops with the NECTOKIN in the last 6 months and all worked well.
              • johnwafu
                • May 2012
                • 17
                • philippines
                #327
                a have a problem with my client toshiba blackout with intermittent power.
                Ive already replaced 4 330uf same problem
                2 330uf same problem
                2 220uf same problem
                2 220 and 2 330 same problem
                check the lan because it was blinking upon pressing the power button
                remove the controller ic of the lan
                but still same problem after I on the unit shutoff no display or what
                ive noticed that the proc is not heating up
                tried new proc same problem
                any ideas sir/mam?
                ive also noticed that the nothbridge was over reheated by other tech that handled this first
                pls help me on this
                • al5911
                  • Jun 2011
                  • 5
                  #328
                  My friend have Satellite L200 that cannot boot. No post. Battery already depleted. When I plug in the power, the charging led and wireless led will automatically light up. When I pressed power button/switch, it charging led,wireless led,power led and hdd led will light up for 4-6 sec then after that only the charging led and wireless led remain light on. I already changed the NEC/TOKIN OE128. What could be the problems? I'm thinking there is shorting else where but I don't know how to look/find for it. Any help gentleman??
                  • trebo
                    • 514
                    • Wales, UK
                    #329
                    Hi Newtonkh
                    Can you tell us what the Esr was, on your suggested Tantalum Caps
                    Thxs
                    • davida999
                      • Sep 2012
                      • 6
                      • australia
                      #330
                      i have a laptop samsung with a NEC TOKIN OE687
                      can anyone suggest replace cap values. i have looked for spec sheet but could not find it
                      • davida999
                        • Sep 2012
                        • 6
                        • australia
                        #331
                        i have found the following which may help
                        where for Capacitance e.g. 128=1200uF
                        First two digits represent significant figures.
                        Third digit specifies number of zeros to follow.
                        • Notsosure
                          • Nov 2011
                          • 71
                          #332
                          Apparently there is not much info available about OE687 on the Internet.
                          OE687 refers to a capacitance of 68 followed by 7 zeros in picofarads (i.e., 680000000pF), which is 680uF (microfarads). These Proadlizers usually have ESR of between 1 to 2mΩ. Therefore, you should consider replacing it with four caps of the type T520V227M004ATE006 or similar.
                          • davida999
                            • Sep 2012
                            • 6
                            • australia
                            #333
                            OE687 refers to a capacitance of 68 followed by 7 zeros in Pico Faraday (i.e., 680000000pF), which is 680uF. These Proadlizers usually have ESR of between 1 to 2mΩ. Therefore, you should consider replacing it with four caps of the type T520V227M004ATE006 or similar.
                            thanks Notsosure
                            i did find this datasheet on the oe687 (PSGD0E687M7)
                            http://www.datasheetarchive.com/PSGD...datasheet.html
                            the mouser item T520V227M004ATE006 seems to have a min buy of 320 units on a roll.
                            could i sub the RS 470's and exceed the uF rating by nearly double or use multiple 100uF caps?
                            i'm in bris australia
                            • Notsosure
                              • Nov 2011
                              • 71
                              #334
                              The datasheet appears to be for small caps and I thought you have a large cap (i.e., Proadlizer) in your laptop?
                              If you do not want to experiment much then 7 or 8 of 100uF ceramic caps might be the easiest way to go. If you do not mind experimenting then you could try 2 or 3 of RS Stock No. 737-2832 or similar. 3 will give a total of 1410uF which is around twice the present capacitance.
                              • Notsosure
                                • Nov 2011
                                • 71
                                #335
                                Being in Australia, RS might be a reasonably priced source because of free shipping.
                                • davida999
                                  • Sep 2012
                                  • 6
                                  • australia
                                  #336
                                  thanks Notsosure, sorry about the datasheet, i'm not into board level stuff. it is a proadilizer. with the 100uf ceramics how is the ESR calculated or doesn't it relate to them?
                                  • Notsosure
                                    • Nov 2011
                                    • 71
                                    #337
                                    Their ESR is probably 1mΩ so it is not a concern at all but their temp limit appears to be 85C, which too is usually not a problem unless laptop runs very hot for some reason:
                                    http://translate.google.com.au/trans...ed=0CG8Q7gEwBg
                                    • davida999
                                      • Sep 2012
                                      • 6
                                      • australia
                                      #338
                                      thanks again Notsosure. i'm going to try the tantalums because they are easy to get`from RS. its pretty hard to source any of the other options.
                                      i really appreciate you taking the time to post advice here and in the many other posts i've seen here and elsewhere.
                                      • Notsosure
                                        • Nov 2011
                                        • 71
                                        #339
                                        You can actually get 10 of GRM31CR60J107ME39L from RS for $17 delivered, if you wish to. Of course, if you are willing to experiment with other caps then any inputs from you might help others. The choice is yours.
                                        • davida999
                                          • Sep 2012
                                          • 6
                                          • australia
                                          #340
                                          thanks Notsosure, i didn't think of searching by the part #. i will order them today.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-12X boardview and Satellite Pro R50-EC-12X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
