hello, laptop is yoga 12 thinkpad with described issue. all lines EXCEPT BYPASS (bidirectional, i don't know what this line is for) via schematic are present (clock, data, vcc etc.). checked resistors, values are correct and lines are continuus. i flashed the latest bios (and tried different configurations) and checked conditions under linux, same problem. do you think i should replace and/or reflash the kbc? haven't had this issue, that these devices stopped working completely. thanks for help
clickpad and trackpoint not working - la-a342pp
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by MMH3Hello,
i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
Never ever i experienced problems with that.
Now i have one 5050sff machine, where this jumper isnt working at all.
I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
The history of the machine is that i used it in my office... -
by DynaxSCHi,
I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
The board is generally working now, all PCIe ports are working, Windows installs normally.
However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA... -
by obelix24Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID and after replacing UT610 it was working but here i'm not able to find anything related to... -
by SysengThis sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...-
Channel: BIOS Requests ONLY!
- Loading...
