Dell E6540 starts with Jack, but not with Power Button
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell E6540 starts with Jack, but not with Power Button
    "coz of sio being in bga package here, pins are not exposed. So really cant diagonise deeper.Else there were lot of options to measure on sio pins.
    • pingaroon
      • Nov 2019
      • 121
      Thanks, MCP,
      I may just remove the SIO again, since the board is useless as it is.
      Would you still be willing to help?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        The pins of SIO may not be marked on mb. Make this aspect sure. If pins are not marked, it will be preety useless. As far as help is concerned , the whole badcaps family is there to help you. Personally, i'll try to help with my limited knowledge.
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          Try using a fresh new battery cell, some laptops are very picky.
          • pingaroon
            • Nov 2019
            • 121
            Hi, the bios battery was brand new, measuring 3.3v. I've abandoned this board as it's just beyond my level for now, but thank you all for your help
            • new
              • Oct 2014
              • 165
              • canada
              #26
              clearly it is the cmos battery . I had the same issue on 3 dell of this exact model they all solved by replacing the same battery then updating the bios .. you chosen the wrong way and long run . you were advised to check the cmos battery earlier.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                @new, read post#25 by OP. He has already replaced cmos cell and it was 3.3V.
                • themosttogain
                  HP Envy 13-BA1565na with intermittent power button
                  by themosttogain
                  Hope someone can give me some suggestions on this because i'm at my wits end with it...
                  I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                  Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                  07-12-2024, 03:03 AM
                • TimeRabbit07
                  Asus FX517ZC charges but power button does nothing
                  by TimeRabbit07
                  Hi all!
                  I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                  Here are its various numbers and identifiers:
                  Model short: FX517Z
                  Model long: FX517ZC-HN114W
                  SN: NANRCX01S57842E
                  CN: 3SDB 12M
                  MFD: 2022-10
                  Motherboard model: DA0NJLMBAE0 REV E
                  Symptoms:
                  The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                  History so far:
                  The...
                  09-04-2024, 05:48 PM
                • swammyw
                  DELL Latitude 7400 Posts & starts and boots after power button is pressed down 1 minute
                  by swammyw
                  Hi, i need help with the device mb:LA-G871P, DELL Latitude 7400, laptop seems to boot windows & diagnostics show no errors, sometimes it shuts down after bios logo
                  problem is i have to press and hold power button 1 minute to get it post, the little led indicator shows blink before it starts, could this be bios issue
                  i used newest bios update & flashed it, it updated all firmwares i think
                  i removed usb c controller bc i think it was shorted, it got hot when charger was inserted & i removed usb c bios chip also (ut6 & ut5) TBTA rom & chip
                  11-23-2025, 08:17 PM
                • reessi
                  Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                  by reessi
                  With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                  No corrosion any where!
                  Tried a replacement power button off ebay and the same.
                  Very occasionally it will work with the power button connected!
                  Same results with or without the battery.
                  Can it be a fault with the Audio board or the mainboard?
                  The touch Id assembly connects through the Audio board first then to the Mainboard.
                  Flex...
                  06-26-2024, 03:31 PM
