Help me identify IC " B1=7 "
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Help me identify IC " B1=7 ", 5 pins
  • khaahk
    • Dec 2013
    • 815
    • Estonia
    Re: Help me identify IC " B1=7 "
    RT9715
    https://cdn.badcaps-static.com/pdfs/...1146551b61.pdf
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      thaks mate. is there any table of marking so i can search the chips?
      • Sephir0th
        • Oct 2020
        • 1289
        https://www.badcaps.net/forum/showth...hlight=richtek
        FairRepair on YouTube
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
        • corrize
          Where to find a very small fpc connector 0.3mm between 2 pins ?
          by corrize
          Hello, I search this connector (oxydated).
          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
          Do you know how to find this connector please ? What is the exact name for find it ?
          08-06-2024, 05:25 PM
        • marce002
          Macbook Isight/ webcam identify pins
          by marce002
          Hello
          Im having a hard time trying to identify GND and 5v out of a pulled out broken a1297 webcam cable.... the connector is broken.. 4 green cables and 2 red ones (gnd and 5v) ... I wanted to start detecting wich one is GND but both of them measures the same in OHMS and even in Capacitance... How can I detect wich one is 5v if both measures the same thing always?? changed multimeter and red to gnd/black to gnd also.... thanks in advance
          02-19-2022, 06:48 AM
        • Powderfanupnorf
          Dell AL440LX power on switch circuit help required
          by Powderfanupnorf
          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
          06-24-2024, 01:24 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
