Asus Gl553VW turn on no windows boot
  • questore
    • Dec 2015
    • 506
    • csongrád
    #61
    Re: Asus Gl553VW turn on no windows boot
    You probably have a bad CPU Phase Controller IC. Mine have the second controller IC burned and same symptoms happened. Check all Phase resistanses, and if any of the 3 is different than the others then replace it.
    • questore
      • Dec 2015
      • 506
      • csongrád
      #62
      Also check the solved on here:
      https://www.badcaps.net/forum/showthread.php?p=1048094
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • DynaxSC
        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
        by DynaxSC
        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
        The behaviour is also really very strange, i.e.:
        • The disk shows always up in BIOS - so it is recognized, so far so good
        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
        02-23-2025, 01:33 PM
      • Safio
        please HELP Asus ROG GL753VE turn on no windows Boot
        by Safio
        ASUS GL753VE and when i want to install windows it shuts down, in bios the laptop stays on forever without problems, I have replaced paste, also nothing seems to be heating up as far as i can see ( fan blowing warm air heat sink temperature is normal) tried different hard drives (ssd, M.2 and few others) did all the troubleshooting i could find on google (CMOS reset, battery removal and discharging the MOBO etc..) ran memtest to check the Ram and all come back good, replaced the mem ram and still same, tried live usb system also still same shut off issue, i know there is few threads out there...
        04-23-2021, 12:50 AM
      • futadmytro
        Asus g713qm-es94 stuck on boot bios problem
        by futadmytro
        sn^M4NRKD02753616E
        MB- g533-6050a3250201-MB-A03
        Stuck on boot after ROG logo, did not enter to bios
        In flash bios , laprop boot but have video issue
        orig bios...
        06-25-2025, 08:07 AM
      • mr.malcom
        HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
        by mr.malcom
        this is a very strange Problem:
        Notebook hang instantly on Boot. BIOS is accesable.
        Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
        Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
        i have tried:
        - only one RAM Stick, another working RAM, both RAM channel
        - BIOS Flash to newest Version F.50, BIOS Reset
        - Memtest86 hang instant at Test 2
        - HP UEFI Diagnostic wont find...
        02-26-2022, 05:19 AM
