A1707 820-00928 Backlight issue
  • mon2
    • 14668
    hi. have an a1707 that appears to work ok if the lid is partially open @ 30 degrees or so. At 90 degrees or more , the backlight always goes off.
    Confirmed that the LCD is ok by using my phone as a flashlight and shining on front face at an angle - can see the desktop text / icons, etc.
    If we attempt to close the lid, the backlight comes back on again at about the 30 degree mark.
    Is this related to FLEXGATE?
    Can check for the boost regulator operation next but thought to ask for ideas.
    Thanks.
    PS: Did hear the fans spin quite loudly when the screen was dark but not sure if this is an issue or not be concerned with for now.
    PS#2: Sure looks to be flexgate issue - OMG, the repair guide:
    https://www.youtube.com/watch?v=JLrKuK7IK3I
    No stage light issue but could very well be the break of the flex cable as noted.
  • MobileXT
    • Oct 2012
    • 214
    Re: A1707 820-00928 Backlight issue
    Thanks.
    Send it to apple is under recall program here https://support.apple.com/13-inch-ma...klight-service
    • piernov
      • Jan 2016
      • 4439
      • France
      This is only for 2016 13", not 2017 15", even if they have the exact same problem. There have been a few reported cases of Apple replacing the LCD assembly for free even on 15", but you have to be extremely lucky.
      • mon2
        • 14668
        Thanks. This is a large 15" from what I can tell.
        There is a youtube video on the issue which is that the flex cable breaks the connection near the bend. The repair is to cut the ribbon cable and attach extensions and solder directly onto the backlight connector pads.
        Sounds like the same issue. Opening and closing the lid must have broken the rather rigid cable that is from the display.
        Master Liu has a video on the display repair but not sure that we want to do this. Using very thin disks, remove the the lcd and replace the cable.
        Root cause...If apple / Foxconn are listening...drop this flex cable vendor.
        If this is NOT flexgate, any other ideas to test?
        The display has the contents but backlight goes off.
        Can review the backlight power rail and its enable pin on Monday.
        If power rail is on then all related to contacts and flex cable.
        • mon2
          • 14668
          Looks to be another amateur design flaw by Apple. Promote these engineers...
          https://www.ifixit.com/Answers/View/...6+no+backlight
          Would show them the door with a cattle prod at our company.
          • mon2
            • 14668
            As per my last post, this appears to be a flexgate related issue.
            Observing that when the lid is open, backlight is on while the display is < 90 degrees to the keyboard.
            After this range of open, the backlight is dark. However, the backlight voltage is @ 58v.
            When the backlight is working, backlight is 48-49v.
            Concerned about the dual fans are spinning like mad - temp is 104F using an IR temp on the bar-style heatsinks.
            Need to apply fresh heatsink compound to cool this down?
            Any ideas or is a replacement of the display assembly the only solution?
            We may attempt the dissection of the screen as shown by Master Liu but I for one may leave footprints in the rice paper and am very nervous about such a delicate operation. We are ok to order the proper tools from Asia once they open..
            https://www.youtube.com/watch?v=fVVq...ature=emb_logo
            • Cornito
              Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
              by Cornito
              Hello Team,
              I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
              Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
              Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
              08-08-2024, 08:09 AM
            • slimmy182
              MacBook Pro 15" 2016 820-00281 no backlight. Another flexgate issue?
              by slimmy182
              Hello, I bought this machine from a friend. It's a 15 inch MacBook Pro 2016 model, logic board 820-00281. He said that the screen would go off if open more than a certaing angle but it's perfect working whit an external display.
              The backlight screen remains stay off even if I open just a little the lid, so I never see backlight work, but I can confirm that LCD show images as using a torch I can see it on the screen. It seems also that camera is not rocognized as the keyboard backlight stay off and touchbar have full brightness.
              Is this a classic flexgate issue? I...
              10-19-2022, 12:44 AM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • Cornito
              TCL 65C715 backlight issue
              by Cornito
              Hello team,
              I'm back with another topic.
              It's a 65C715 TCL tv with backlight issue.
              But the problem is a bit strange.
              When I took this tv from the marketplace backlight didn't work but picture was ok.
              Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
              Putting all back together the tv worked fine for weeks. => Contact issue??
              Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
              06-09-2024, 02:24 AM
            • shellybelly
              Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
              by shellybelly
              Back Story
              I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
              So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
              08-27-2023, 10:40 PM
