820-4924-A - No Green Light
  • m3g4tr0n
    • Aug 2011
    • 88
    Have a 820-4924-A - with no Green light on the charger.
    R7020 looks discolored and measures 31.9ohms insstead of 47ohm.
    attached a picture with voltages between dc jack and u7090.
    also getting a short to ground on PP3V42_G3H (L7095, C7099, C7010, C7008, ...)
    took off u7090 and L7095, C7099 and short still there. didn't take anything else off.
    thanks
  • mon2
    • Dec 2019
    • 14666
    Re: 820-4924-A - No Green Light
    What is the resistance to ground at c7010?
    The 3v42 rail is required for the one wire circuit to operate and light up the adapter green light.
    You may have a shorted cap but please post the above resistance reading for this rail.
    • m3g4tr0n
      • Aug 2011
      • 88
      C7010 resitance to ground
      001.5ohm (0.004 diode mode)
      • mon2
        • Dec 2019
        • 14666
        PP3V42_G3H_REG goes all over the board including powers the one-wire circuit that is not being powered due to lack of 3v42 presence.
        Remove the trackpad & keyboard cables and check again on this resistance.
        Look around for possible liquid damaged parts that may be impacting this rail.
        Something is causing for this low resistance on this line which is then forcing this rail to shut off.
        Do you have a voltage injector? Do not use it yet. Others may have other advice but please post the results from the above testing.
        • zpi
          • Feb 2018
          • 132
          • Lithuania
          Usually these boards has damaged c7090 c7091 or c7092 when PP3V42_G3H_REG is shorted. You allways can inject 1v and check if one of this caps does not get hot
          • mon2
            • Dec 2019
            • 14666
            Recommend to throw with Q-tip (what we use) some alcohol these tantalum caps. They are usually the bad boys that die over time. For us, we saw the alcohol evaporate quickly with a small amount of smoke with our 30A injector @ 0.9v. Found the bad tantalum in seconds.
            • m3g4tr0n
              • Aug 2011
              • 88
              The test was done on the board only nothing connected. I didn't see any liquid damage. I'll look again after work.
              I have a bench supply.
              • m3g4tr0n
                • Aug 2011
                • 88
                If they are damaged should they not short to ground?
                • m3g4tr0n
                  • Aug 2011
                  • 88
                  My Bench supply only has 30v 5A. Do you mean short killer? Don't have one of those yet.
                  • mon2
                    • Dec 2019
                    • 14666
                    Yes, short killer. We have the TS-30A which is working well. We dialed up to 0.9v and applied onto the rail. The point of contact would spark a bit and then we removed the injector probe. This surge pulse (a few times) was ample to locate the shorted cap for our first time use about a week ago. Very very helpful tool.
                    I think you can do the same with your power supply.
                    Lower the voltage to 1 volt on your power supply and apply onto the same rail of interest.
                    Connect black to ground.
                    What is the current draw once you attach the power supply probe (+; Red wire)?
                    Assuming that the current draw will spike, check for the caps that may be heating up. The alcohol will help a low and the heat from the bad cap will make the alcohol smoke up / dry up very quickly.
                    With tantalum caps, when they die, they present a short circuit to ground. Useless caps in my opinion. We have 1M++ of our products in the field and rule #1 for our designs...NO TANTALUM CAPS. Have devices with 10++ years of service and still kicking. Can you imagine $$ equipment just dying over a cap? If I recall correctly, Japan had a ban on tantalum caps ages ago. Can really appreciate their point of view.
                    • mon2
                      • Dec 2019
                      • 14666
                      I do not believe that you have a short on c7090 c7091 or c7092 since the voltage on this rail remains within range with Pin 1 of D7005.
                      If the value @ pin 3 of D7005 is very low then yes, one or more of these caps on this leg is shorted and drawing too much current, hence a power rail drop which in turn does not allow for the 3v42 regulator @ U7090 to turn on.
                      Please confirm the details on this leg but believe you are ok here.
                      I think you may want to consider the voltage injection @ 1V on the PP3V42_G3H_REG line which was showing a low resistance to ground. Then review which cap is heating up. My bet will be on the polarized tantalums (assuming that the board has been cleaned up enough from any possible liquid damage).
                      Locally we get the real confessions from the customer after we inform them of the neon green oxidation of the PCB, etc. - 'oh yeah, my sweetheart daughter spilled this or that...' - no kidding. Alcohol is great at cleaning up most of such damage.
                      You may want to consider a professional ultrasonic cleaning tank to handle small / mid size PCBs. We purchased 2 such units - one for phones and one for macbook size boards. This along with the cleaning solution will do a nice job to remove spills off the board. Many on Aliexpress / Alibaba - we went direct to the mfr of the cleaners.
                      • m3g4tr0n
                        • Aug 2011
                        • 88
                        Update: Macbook is working.
                        Voltage injection on the PP3V42_G3H_REG line
                        1V 1A - nothing got warm or hot (0.5xxA)
                        2V 1A - nothing got warm or hot (0.5xxA)
                        2V 2A - nothing got warm or hot (0.5xxA drops to 0.2xxA)
                        3V 2A - was drawing all 2 amps. i kept connecting and disconnecting the ground cable from the bench supply and on the 4th try it stayed on 3v and the amps dropped to 0.2A.
                        checked the caps and inductor that were shorting before and theres no more short.?????? where did the short go?? only thing i did was put IPA on U7090 and it's surrounding components.
                        pluged in adapter got a green light for 2-3 seconds then it stays on orange. Logic board with and without battery
                        • mon2
                          • Dec 2019
                          • 14666
                          Excellent.
                          The injection removed the short. One or more of the caps internally no longer have this short circuit event.
                          Consider to source a high current injector and keep the voltage low at 1v or close to. That is what we understand is the proper procedure. TS-30 is the model we purchased which works fine. Only one small complaint is that the display is not as bright as the videos nor advertisement.
                          There are a number of similar looking cloned injectors on AliExpress.
                          For your 3v42 rail, your process was fine. Just keep the voltage to a safe level.
                          For us, the current would peak to 8A while the cap was shorted.
                          Good work!
                          • m3g4tr0n
                            • Aug 2011
                            • 88
                            @mon2 thanks for your help.
                            i'll probably get the short killer in the end of the month.
                            i wasn't gonna inject more than 3v.
                            what about the orange light, is that normal? never had a mac before.
                            • mon2
                              • Dec 2019
                              • 14666
                              Orange light is to inform the user that the macbook is charging the battery.
                              Leave the unit plugged in and monitor the battery charging progress bar at the desktop. After 10-20 minutes, do you see the battery level increase?
                              There is a battery meter tool included with the operating system that will show the battery level.
                              If after charging, the macbook can continue to run on battery then all good.
                              If the macbook powers off with the adapter removed then you have a dead battery and the battery must be replaced.
                              Once the battery is 100% charged, the adapter will turn green.
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                200mA drawn on PP3V42_G3H is still pretty much a partial short to ground. SMC can cause this (but still another component could be the culprit). It should warm up more than usual.
                                • m3g4tr0n
                                  • Aug 2011
                                  • 88
                                  it's charging now.
                                  if SMC was shorted, would i need to use one from the same board model?
                                  thanks everyone
                                  • zpi
                                    • Feb 2018
                                    • 132
                                    • Lithuania
                                    Yes
                                    • MOSSEP
                                      Monitor Audio RSW12 - Green light, but no sound
                                      by MOSSEP
                                      Hi
                                      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                      I have already tried replacing all of the...
                                      01-26-2025, 08:33 AM
                                    • MOSSEP
                                      Monitor Audio RSW12 - Green light but no audio
                                      by MOSSEP
                                      Hi
                                      01-26-2025, 08:18 AM
                                    • lcdcaps1
                                      820-2610-A Sys onewire help, no green light. Please help from the gurus
                                      by lcdcaps1
                                      Hi
                                      I have an 820-2610-A motherboard that has no green light.
                                      I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                      From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                      The sys onewire circuit on this model and others is more involved
                                      I was hoping if anyone knows about this and how it works, can reply and let me know
                                      I know this is an old model but I am sure there are people who still works on these or knows about them
                                      I get 1.1v on the C7771 capacitor and will replace...
                                      11-06-2023, 01:28 PM
                                    • blazzelia
                                      MBP A1286 820-2915 green light only, no start
                                      by blazzelia
                                      Hi guys,
                                      I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                      09-30-2024, 07:20 AM
                                    • jheunne
                                      A1466 macbook no boot green to orange light help
                                      by jheunne
                                      i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                      in first image there is 0v out for lcd
                                      https://ibb.co/5XppmpkH
                                      in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                      https://ibb.co/fdJkbJs8
                                      06-10-2025, 10:52 PM
